Please Need Help for Sony KDL-26S3000 - AVS Forum
post #1 of 1 Old 11-24-2007, 09:28 AM - Thread Starter
Escorpion's Avatar
I have the Sony 26s3000. I enter in to the Service Mode Menu using the Display + 5 + Volume Up + Power to see how it looks. After I saw how it looks without touching any keys in the remote I power off the tv and then turn it on. My problem is that after entering in the service mode, when i press the Freze button on the remote the TV display TEST for a couple of seconds and then goes away. Also If i press the WIDE button on the remote the service menu comes up while the TV display the TEST word in red. Now the FREZE, PICTURE, and WIDE buttons in the remote doesn't do what they suppost to do. Does anyone now how to fix this? Do I have to return my TV since I bought it 3 days ago?
Note:
All function in the TV works fine using the remote control with the exception of the Freze, Picture and Wide buttons in the remote that the tv doesn't do what they are suppost to do.
Escorpion is offline
Reply LCD Flat Panel Displays
User Tag List
