Official Olevia 247TFHD Owners Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
post #1291 of 1309 Old 09-22-2012, 05:07 PM
Elbie's Avatar
Still using mine!
Elbie is offline
post #1292 of 1309 Old 10-16-2012, 08:01 AM
hamburglar2's Avatar
I'm still using mine, bought it in 08 and it runs just the same as day 1.
Anyone else have issues trying to play Blu-rays? My HTPC is not recognizing the tv as an HDCP compatible device.
hamburglar2 is offline
post #1293 of 1309 Old 12-02-2012, 09:21 PM
NRG-Diesel's Avatar
Hi I have a 247fhd-t11 I was given it by a friend because it has a problem with the main digital board? It has horizontal lines across the screen that dance up and down. and the screen gets bright flashes as well. If you smack the tv it will most times fix the problem for a while. I was thinking since a smack causes a change with the issue it could be a solder joint problem and any luck re-flowing the solder?
Thanks, Nathan
NRG-Diesel is offline
post #1294 of 1309 Old 12-25-2012, 09:57 PM
Wolves0208's Avatar
Hey there, I was wondering if anyone had the most current firmware version. I have been looking for one for ages!!! If anyone could help, I would be very grateful!!
Wolves0208 is offline
post #1295 of 1309 Old 01-05-2013, 10:58 AM
redskinjonesy's Avatar
FYI, mine died 3 days after Christmas... For about a month prior, the unit would only power on by way of the power switch, not the remote... Yet it would turn off with the remote.... then one day last week, I pressed the power button, the blue light went off, but the tv never came on.... left it off for a while unplugged, nothin..
Took it apart and found 2 blown caps on the power supply. I have ordered a repair kit through
http://lcdalternatives.com/Repair-Kit-Olevia-242FHD-T11-LCD-TV-Capacitors-Only-Not-the-Entire-Board-P2446617.aspx
I will let you know what happens..
redskinjonesy is offline
post #1296 of 1309 Old 01-15-2013, 03:46 PM
Got my kit from lcd alternatives. Replaced the 2 blown caps and everything is as good as new...
Tv IS working again....
post #1297 of 1309 Old 01-15-2013, 04:42 PM
dad1153's Avatar
Quoted: 1925 Post(s)
Liked: 1218
Send a message via Yahoo to dad1153
dad1153 is offline
post #1298 of 1309 Old 02-18-2013, 05:09 PM
utmba95's Avatar
I'd love to get the latest firmware if somebody can PM me. DirecTV's remote seems to think this TV supports discrete On (OBC 64)/Off (OBC 65) codes, but my TV doesn't respond to them. Or if anybody can confirm that it does or does not have discrete codes, that would also be helpful.
utmba95 is offline
post #1299 of 1309 Old 09-06-2013, 08:22 PM
JaeRSr's Avatar
Hello all,
I'm having a real problem with my Olevia 747 FHD. When I turn it on I see white vertical lines flickering across the entire screen. The used to disappear after about 30 minutes, Now the monitor just continues to flicker permanently. On some occasions, the screen will just turn completely white and I cannot view any image whatsoever, only sound.
The link below is an example of what happens when I turn the TV on:
http://www.youtube.com/watch?v=JiYnR9vxL0M
After researching the issue i've pretty much ruled out that its a power capacitor issue because the TV does turn on. Does anyone have an idea of where I should begin looking to solve this problem.
JaeRSr is offline
post #1300 of 1309 Old 10-23-2013, 09:59 AM
darcilicious's Avatar
Hey, have had this TV for quite a while and still perfectly happy with it. Was wondering though, does it have a USB port (I don't think so but I'd like to be wrong!) and if so, where smile.gif
darcilicious is offline
post #1301 of 1309 Old 02-03-2014, 02:39 PM
Luyseyal's Avatar
I recently replaced the main board in my Olevia 242TFHD with a main board from a 247TFHD. The picture decoding looks "off" on every source. Everything else is fine. Any ideas? The firmware is still listed as for the 247.
Thanks for any help!
Luyseyal is offline
post #1302 of 1309 Old 04-30-2014, 07:00 AM
anjenaire's Avatar
I saw an old (circa 2008!) thread about issues with freezing on Comcast cable box while left overnight. I just switched to Comcast and I am having the same issue when routing my signal through a Yamaha Rx-V467 receiver. I am forced to reboot the cable box. I was also having issues with audio when the receiver is ON but not with pass-through. I have re-connected the cable box to go directly from the cable box to the second HDMI input and then ran an optical cord from the TV to the AV4 input. This seems to have solved the freezing overnight issue and reboot but of course the audio signal is now only stereo and I have to either shut the TV speakers OFF or use the TV remote to lower the volume to zero. Both of which are not wife/family friendly.
I have tried changing out the HDMI cord numerous times, changing the power on sequence but I am still not having any luck with Comcast Xfinity --> Yamaha Reciever __> Olevia 247TFHD with respect to audio with the receiver on. I know that the TV is now approaching 7 years old (and the original manufacturer went out of business) but this TV is very finicky with the HDCP handshaking. I have a Pioneer receiver with more HDMI inputs that won't display anything on this set that is now in the living room doing music duty only.
Is there some setting I'm not thinking about? Is there a way to rename the source inputs? Any suggestions?
anjenaire
"Conservation, it's worth the energy"
anjenaire is offline
post #1303 of 1309 Old 09-21-2016, 07:28 AM
Liked: 0
i have had olevia 247 for about 8 years, changed the main board twice but it still has a half blue tint, can anybody help with issue?
anavaho is offline
post #1304 of 1309 Old 09-21-2016, 05:32 PM - Thread Starter
spydermonkey311's Avatar
Is that your main TV? If so, replace it. You will be amazed how much better the newer TVs are. Even a $350-400 TV. I kept my 247TFHD for 7 years before replacing it. Wish I did it sooner!
spydermonkey311 is offline
post #1305 of 1309 Old 09-21-2016, 05:51 PM
Liked: 0
got another one a 39 inch, just like this one better
anavaho is offline
post #1306 of 1309 Old 09-21-2016, 08:52 PM
Liked: 0
could it possibile the inverter for the left side as you look at from the back? does it have two inverters, one for right and one for left, left is working great
anavaho is offline
post #1307 of 1309 Old 10-24-2016, 12:29 AM
udunnome's Avatar
Liked: 0
Only posting because I'm hoping for negative karma. I've had this TV since the original Circuit City deal, and it's still working like a champ. No issues/problems, ever. I'm dying to get a new TV, but can't justify it to my wife unless this damn Olevia breaks. I'm just amazed how long it's lasted. Best investment ever, actually. Please TV gods make it break. Thank you in advance.
udunnome is offline
post #1308 of 1309 Old Yesterday, 01:08 PM
vidiot1985's Avatar
Just wondering if your hopes for negative karma have been fullfilled.
My 247TFHD is still running perfectly after 10+ years of very heavy use, while my LG 42LD550 recently died after 6+ years of very light use.
I too continue to be amazed by how good this Olevia has been to us.
vidiot1985 is online now
post #1309 of 1309 Old Today, 07:41 AM
gamo62's Avatar
Same here. Our 247TFHD is running fine. Going on 11 years. Picture still rocks. Warms up the room rather nicely in the winter, unlike those new LED TV's. Waiting for it to break so we can upgrade to a 4k. It may be a while. I have a TiVo Bolt 4k, and will probably get Project Scorpio in the fall.
To put this in perspective, this TV is on its 3rd US President. And 4th game console. Original Xbox, PS3, and XBONE. (Skipped the 360 and PS4.)
gamo62 is online now
Reply LCD Flat Panel Displays
Olevia , Olevia 24 Class Led Hdtv
