Quick Question/Help - AVS Forum
post #1 of 3 Old 12-12-2007, 09:55 PM - Thread Starter
CH-OutbreaK's Avatar
Hi, I'm new to the forums, and I'd like to ask for some help. On monday I will be receiving my new 32" Sharp Aquos LC-32D43U from Brault and Martineau. I would like to know the best settings for optimal picture quality. I will be using this tv for my ps3 connected via and HDMI cable. I'm relatively new to the HD scene, so keep the terms as simple as you can. ( get the jist of it, but don't start going on about the calibrate function articulater something or other ) Thanks
CH-OutbreaK is offline
post #2 of 3 Old 12-13-2007, 04:19 AM
gordon@1310's Avatar
Search the "D43u" owners thread.
Or better yet, pick up a copy of Avia or DVE and do it correctly.
Good luck.
BTW, you should make your thread titles more specific in order to get replies from people familiar with your request.
gordon@1310 is offline
post #3 of 3 Old 12-13-2007, 08:12 AM - Thread Starter
What exactly is Avia? And i will search the D43U Thread. Thanks. Depending on what i find, i may just experiment myself
Reply LCD Flat Panel Displays
User Tag List
