Thin vertical line on LCD tv - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 101 Old 08-15-2011, 03:01 AM
The Reflex's Avatar
My Westinghouse 42" TV which I got at BJ's for $650 a couple years ago is showing signs of vertical lines in several places not really related to any burn-in influences AFAIK. I hooked up M$ Paint to the VGA input of the TV. I found for each of the 3 primary colors, if the setting was 230 or higher, the lines were not quite visible; but as I go darker below 230, like 200, 150, 100, the lines become more apparent in each of 3 colors. Where the lines are, it's getting to black several bits ahead of the rest of the screen.
If it's too broke, it's beyond fixing.
The Reflex is offline
post #92 of 101 Old 01-04-2012, 12:06 AM
amoizbaig's Avatar
there is one line from edge to edge horizontal line. please help.
amoizbaig is offline
post #93 of 101 Old 06-23-2012, 01:25 PM
Freethinker21's Avatar
I have a line on the right hand 4:3 border on my Toshiba 32 inch LCD TV.
It appears regularly when I turn on the TV but by pressing on the screen near the top of the line it disappears.
Freethinker21 is offline
post #94 of 101 Old 01-15-2013, 09:56 PM
oneshot321's Avatar
I had a one pixel wide verticle yellow line running down my Sony 52" LCD. I was able to "fix" it by changing my power saving settings to low. I put "fix" in quotes because I have no idea why that worked but it did for me so it 's worth a shot for other people with the same problem.
MIKE K. likes this.
oneshot321 is offline
post #95 of 101 Old 09-03-2013, 07:11 PM
SomaXD's Avatar
took me a while to find this... but glad i did... i have the yellow/green/magenta/cyan vertical lines in my (5 year old) Samsung LN40A500t on the right side of the screen. they appear if i turn my TV off then back on... which is making me just leave my TV on all times. I CAN get rid of them by putting pressure on the top of the screen or wiggling the screen softly which is getting harder and harder if i turn my TV off ever. is it worth it to fix the LCD or just replace the TV.
SomaXD is offline
post #96 of 101 Old 09-03-2013, 08:50 PM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
Soma, if you're going to pay someone to fix your tv, IMHO, you would be better served buying a new TV. A new 40" can be found for < $500 and you will spend a minimum of $100 plus parts. You might want to try removing the back cover and checking the ribbon cables to make sure they are seated properly.
I would still buy a new model and move the old one to the deck or spare bedroom.
Good Luck,
RollTide2011 is offline
post #97 of 101 Old 09-18-2013, 03:11 PM
NetWiz30's Avatar
That is the exact issue I've now got with my TV set. My TV model is LG 50PV350T. (50")
I have solved the problem by doing the same as yourself; changing the Engery/power setting. Now I'm delighted.smile.gifsmile.gifsmile.gif
MIKE K. likes this.
NetWiz30 is offline
post #98 of 101 Old 03-10-2014, 05:29 AM
lollypop8381's Avatar
I had a 3 year warranty too. It expired on Feb 5, 2014. On March 9, 2014 my TV messed up now has the thins lines down the middle of the screen. Apparently I should have bought the 5 year warranty instead.
lollypop8381 is offline
post #99 of 101 Old 08-18-2014, 09:04 AM
Liked: 0
Fixxed
I had a problem with my tv. I was able to fix it by myself. Watch this video on YouTube. I hope it helps.
davedavid85 is offline
post #100 of 101 Old 11-30-2014, 01:51 PM
Liked: 0
I have the same problem with my Vizio and all I do is apply pressure on the line at the bottom of the screen and that works. Also you can slide a small piece of paper into between the screen and the frame where you see the line and that seems to work.
Ladymary00 is offline
post #101 of 101 Old 10-20-2015, 10:35 AM
Liked: 1
Originally Posted by safelz View Post
i have the same problem with my westinghouse. does anyone know how to fix the vertical lines? it's getting worse now; the lines are more defined now.
We get it! You ALL have the same problem. If you dont have a solution NO NEED in saying you have the same problem. WE ALREADY KNOW.
-If there were an answer nobody will find it bc of all of the posters that HAVE THE SAME PROBLEM. Thanks for ALL the help guys. LOL
By the way.. (guess what). I have the same problem.
Are you guys getting paid to post these redundant messages? I hope so. If not you are wasting your time and everyone elses.
Anderhan is offline
Reply LCD Flat Panel Displays
Sony Bravia S Series Kdl 32s3000 32 Inch 720p Lcd Hdtv , Westinghouse 42 Inch Ld 4255vx Led Hdtv
