Upscaling... - AVS Forum
post #1 of 4 Old 01-27-2008, 02:32 PM - Thread Starter
xiuxiu's Avatar
If I put my Onkyo 405 dvd player to 480i will my Philips 32" 9731D then upscale it to 720p if I use HDMI or will it still be 480i?
Thomas
xiuxiu is offline
post #2 of 4 Old 01-27-2008, 04:21 PM
james.92's Avatar
Your display will scale the signal to whatever its native resolution is (768p ?) and deinterlace the 480i to 480p as well. It has to. You might want to output a 480p signal to see which component deinterlaces the best.
james.92 is offline
post #3 of 4 Old 01-28-2008, 12:46 PM - Thread Starter
xiuxiu's Avatar
Thx for the answer
ok...so no matter what my tv will always scale it to 1366x768 (HD ready). But why then put the dvd player to 1080i if the tv only will put it to 768? Are there any advantages to 1080i?
Thomas
xiuxiu is offline
post #4 of 4 Old 01-28-2008, 02:38 PM
nm88's Avatar
If you have a 1366x768 TV and an upconverting player, let your TV do the scaling (i.e., 480i or 480p output from your DVD player) unless the player's scaler is much better. Scaling the DVD to 1080i then rescaling back down to 1366x768 will cause significant detail loss.
nm88 is offline
Reply LCD Flat Panel Displays
User Tag List
