sony 40xbr5 or samsung 4069 - AVS Forum
post #1 of 2 Old 01-31-2008, 02:56 PM - Thread Starter
jiqqaman's Avatar
I'm deciding on which of these two sets I'm better off getting. Can anyone recommend which one to get? I'm usually gonna be using it more for gaming and for movies.
jiqqaman is offline
post #2 of 2 Old 01-31-2008, 05:18 PM
Dubz4lif3's Avatar
They are Both Amazing Sets and you will be Fine with either one so it comes down to price and if you want to pay more for the XBR
If glare ain't a issue then i say go with the 71F (yes it has a few issues but minor)
Because it has better blacks (atleast to me) and equal PQ to the XBR and the best part it can be up to $400 cheaper than the XBR4.
So let your eyes Choose
Dubz4lif3 is offline
Reply LCD Flat Panel Displays
User Tag List
