Panasonic PZ80/PZ85 Owners Thread [No Price Talk] - Page 418 - AVS Forum | Home Theater Discussions And Reviews
post #12511 of 12695 Old 04-02-2010, 09:54 PM
cj19791979's Avatar
hey everyone i was thinking about buying a g20 or maybe getting my 85u isf calibrated any advice out there your help or input would be appreciated
cj19791979 is offline
post #12512 of 12695 Old 04-17-2010, 10:45 AM
Scallica's Avatar
Is there a way to disable overscan in the TH-42PZ85U?
HTPC Enthusiast
Scallica is offline
post #12513 of 12695 Old 04-17-2010, 07:08 PM
PlasmaPZ80U's Avatar
Quoted: 2233 Post(s)
Liked: 683
HD Size 2 in advanced picture settings
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is offline
post #12514 of 12695 Old 04-17-2010, 07:27 PM
Raymond42262's Avatar
Why would you want to disable overscan ?
Is there a benefit to it?
And how do you get to advanced settings ?
Raymond42262 is offline
post #12515 of 12695 Old 04-17-2010, 08:26 PM
JCBoomer's Avatar
I would personally wait for the next gen Panny's (if you are wanting a Panny) to see if the black level issue (erm..feature) is fixed.
JCBoomer is offline
post #12516 of 12695 Old 04-17-2010, 08:29 PM
If you are going to do that , you may as well get a 3D television.
post #12517 of 12695 Old 04-18-2010, 02:40 PM
Dreassic's Avatar
Tis may be a weird question, but apparently my pz85 should have a pixel orbiter function, but i cannot find any such option in any of the menus.
Dreassic is offline
post #12518 of 12695 Old 04-18-2010, 02:58 PM
Liked: 683
(1) to see the whole picture and (2) to get 1:1 pixel mapping
To get to advanced scroll to the bottom of picture settings and select advanced settings.
post #12519 of 12695 Old 04-18-2010, 03:00 PM
Liked: 683
under setup, anti-image retention, pixel orbiter
post #12520 of 12695 Old 04-18-2010, 03:07 PM
Dreassic's Avatar
Thats the weird thing, no such option exists there.
Dreassic is offline
post #12521 of 12695 Old 04-19-2010, 05:32 PM
Scallica's Avatar
Thank you, it worked perfectly!
HTPC Enthusiast
Scallica is offline
post #12522 of 12695 Old 04-22-2010, 08:34 PM
Marvsworld's Avatar
does anyone know what size the holes are in the back of the flat panel and what size screws fit those holes? I was told 8mm but that is not correct.
Marvsworld is offline
post #12523 of 12695 Old 04-30-2010, 11:45 AM
mitchy's Avatar
I recently added a 2nd HD TV in my office (Sony Bravia 22EX308). I added a 1x2 HDMI splitter from Monoprice between my 50PZ80U and Tivo HD so that I could watch my Tivo in both places. For the most part things work well, but it seems like after about 2 days I lose audio for any HD content on the Panasonic TV (Sony has been fine so far). To get it to work again I have to power down the Panasonic and the splitter. I've ordered another brand of splitter that is labeled as HDCP 1.2 compliant hoping that it solves the problem. Wondering if any others have experience with HDMI splitters going to your Pannasonic and if you see any handshake type problems like this?
mitchy is offline
post #12524 of 12695 Old 05-03-2010, 01:15 PM
JamesP1701's Avatar
Quoted: 44 Post(s)
Hi all,
I really hope someoNe can offer some advice.
I have had the 46pz85B for some time now and generally very happy. However, i cannot shake the feeling that cinema mode is somewhat off. I have had the set calibrated and everything set so that in cinema mode the default settings are accurate. However, when using it, the picture lacks punch. It's almost as if it's a bit too airy/'washed out.' this goes away if I turn down the brightness but of course then I lose detail.
Swithing to normal mode makes th picture alot punchier, but loses detail. Is cinema meant to be like this, am I going mad etc? Should cinema only be used in low light conditions?
Apprecite your help.
James
JamesP1701 is offline
post #12525 of 12695 Old 05-03-2010, 01:36 PM
Dreassic's Avatar
So no one has any ideo why my 42PZ85E has no pixel orbiter options??
Dreassic is offline
post #12526 of 12695 Old 05-03-2010, 06:20 PM
Plasma Guy's Avatar
Dreassic, my answer is the same as PlasmaPZ80U. I also own the PZ80U. We own the model for the U.S.A. market. What market do you reside in?
Plasma Guy is offline
post #12527 of 12695 Old 05-04-2010, 12:29 AM
Dreassic's Avatar
As you can see in the post, the E model, thus Europe. But that should not make a difference, this is about a vital feature, a pixel orbiter.
I know of other, less important features, differing in models from different countries/regions, but one would think a pixel orbiter would be in ANY model.
Dreassic is offline
post #12528 of 12695 Old 05-04-2010, 01:34 AM
sonic_blue's Avatar
Originally Posted by JamesP1701 View Post
Hi all,
James
The problem with Cinema mode on 2008 models is the gamma (midrange brightness) is set wrong. The picture probably looks as if someone has jacked the brightness up too high causing the image to look flat and 2 dimensional. This is essentially what you are correcting by lowing the brightness, but as you've said it's not a solution because doing so will crush blacks.
Some of the 2009 models can now achieve the correct gamma curve via an advanced picture menu and this makes all the difference in the world. I've just upgraded from a PX80 to an S10 with the gamma control unlocked and I can tell you the difference it makes is truly astounding. With the gamma corrected, images now look 3 dimensional and realistic. The picture now seems as though you are looking out a window.
I'm struggling to understand why Panasonic would not set their TV's to the correct 2.2 gamma setting by default from the factory. It clearly looks superior to any other gamma setting. Everyone I've shown the S10 to agrees at how nice 2.2 gamma looks.
sonic_blue is offline
post #12529 of 12695 Old 05-04-2010, 01:37 AM
JamesP1701's Avatar
Quoted: 44 Post(s)
Yes that's it exactly. Quite why my calibrator didn't pick that up I don't know. Is there a way of going into the service menu to adjust gamma?
post #12530 of 12695 Old 05-04-2010, 01:46 AM
sonic_blue's Avatar
Not on 2008 models I'm afraid. I've spent many hours trying to correct gamma on my PX80A, but to no avail. If you want realistic images you'll have to get a 2009/2010 model.
post #12531 of 12695 Old 05-04-2010, 01:47 AM
sonic_blue's Avatar
By the way, the reason Normal mode looks punchier is because the gamma in that mode is set to S-curve. But that isn't correct either and gives an artificial look.
post #12532 of 12695 Old 05-04-2010, 01:50 AM
JamesP1701's Avatar
Quoted: 44 Post(s)
I feel very ripped off and annoyed now!
post #12533 of 12695 Old 05-04-2010, 01:52 AM
sonic_blue's Avatar
By Panasonic or the calibrator?
post #12534 of 12695 Old 05-04-2010, 01:54 AM
JamesP1701's Avatar
Quoted: 44 Post(s)
Bit by both to be honest!
post #12535 of 12695 Old 05-04-2010, 01:56 AM
JamesP1701's Avatar
Quoted: 44 Post(s)
What I can't understand is why so many people are raving about this mode. It is really bad to me.
post #12536 of 12695 Old 05-04-2010, 02:10 AM
sonic_blue's Avatar
Yes I know the feeling, I tried to force myself to use Cinema mode on the PX80 for nearly a year, but it's just no good. I actually found it fatiguing to watch because there is not enough variation of light and dark in the midrange, so your eyes have nothing to "latch onto". I then switched to Normal and enjoyed that for a while but then became annoyed with the caked on makeup look and crushed whites that the S-curve gamma was producing. Actually the Normal mode is a lot nastier on the PX than the PZ , so you may find Normal mode better on your PZ.
But still, none of it compares to the correct gamma.
post #12537 of 12695 Old 05-04-2010, 02:33 AM
JamesP1701's Avatar
Quoted: 44 Post(s)
Is the s10 sognifcantly inferior to the g10?
post #12538 of 12695 Old 05-04-2010, 02:43 AM
sonic_blue's Avatar
I wouldn't say so. The only real difference between the two is the G10 has the newer "neo-pdp" panel which enables it to go brighter for less electricity. Apart from that the basic picture qualities such as black level , colour accuracy and motion resolution are the same. Be aware though that you have to do a hack to unlock the gamma control.
post #12539 of 12695 Old 05-04-2010, 02:54 AM
JamesP1701's Avatar
Quoted: 44 Post(s)
Of course the problem now is selling my pz85 and affording a new one!
post #12540 of 12695 Old 05-05-2010, 10:47 AM
LI-SVT's Avatar
Hi all,
James
Try your CINEMA setting in the CUSTOM mode. CUSTOM looks "clearer" than CINEMA on my PZ85U.
LI-SVT is offline
