Panasonic PZ80/PZ85 Owners Thread [No Price Talk] - Page 423 - AVS Forum | Home Theater Discussions And Reviews
post #12661 of 12693 Old 12-19-2012, 06:53 PM
Noodles3's Avatar
Originally Posted by tomwil View Post
Just be aware that the unplug-plugin routine will eventually cause more damage, as mentioned in this post.
Yeah that's why I'm trying to get the TV tested and get the part needed from a reputable source as quickly as possible. I just wish Panasonic would be able to help with the parts.
Noodles3 is offline
post #12662 of 12693 Old 12-27-2012, 08:49 PM
Noodles3's Avatar
Well got the new P-Board installed and everything is working fine. Now let's hope this P-Board lasts at least 4 years like the original one did. The hardest part of the install was removing 40 some screws to get the back off. smile.gif
Noodles3 is offline
post #12663 of 12693 Old 12-28-2012, 04:51 AM
StuJac's Avatar
Noodles-where did you score the P board? How much? I'll take one.
Pan 46PZ85U, Marantz SR5003, TiVo Premier, TiVoHd + 1tb, A2 (fs), PS3, Pan DMR E-95 (fs), JVC DVD-A, Polk & Infinity, Harmony One
StuJac is offline
post #12664 of 12693 Old 12-28-2012, 06:32 AM
Noodles3's Avatar
I got it directly from Panasonic. It was roughly $160 after shipping. I called directly to the Viera concierge support line and they put me in touch with the parts department. They have A-Boards too that they priced at $380
Noodles3 is offline
post #12665 of 12693 Old 08-15-2013, 08:10 PM
irateb's Avatar
Hello All,
I have a TH-50PZ85U that i bought 12/08, and it had been working perfectly until about a month ago. I recently got a job that involved travel, and it happened to malfunction a day after my first trip. I've finally gotten around to trying to diagnose it, and it appears all three HDMI ports are not working. All other inputs work fine, the picture looks as good as it can sans an HDMI feed, and sound is fine. Any idea on what my issue could be? My quick research is saying A-board, but I figured I'd ask and see if that was correct...
irateb is offline
post #12666 of 12693 Old 09-20-2013, 06:47 AM
FlynP5's Avatar
I have a vertical yellow bar on my plasma tv. The images can be seen through it but I checked all of the settings and I can not get it to go away. I was just saying last week that I love the picture on this plasma, hopefully it is not anything to expensive to get fixed.
Panasonic TC-PS60 plasma • Anthem MRX 510 • OPPO DV-980H • Rogers Nextbox 2.0 8642 HD • Playstation 3 • HTPC (GA-EP45-UD3P, AMD Radeon HD 6870) • SVS Ultra Series Speakers • HSU STF-3 Subwoofer
FlynP5 is offline
post #12667 of 12693 Old 10-18-2013, 08:33 AM
wasp23's Avatar
I have a 42-pz80 which has developed an annoying fault just out of warranty.
A vertical black bar has appeared down the left hand edge of the screen about one inch wide. It doesn't flicker or flash it is just solid black.
Does anyone have any clue as to what this could be or how I could fix it ?
wasp23 is offline
post #12668 of 12693 Old 10-18-2013, 11:01 AM
FlynP5's Avatar
I'm sorry to hear about your problem, I have a 5" yellow bar on the right hand side, appears after an hour being on. At this point I don't think its worth getting fixed, I'm waiting for the Panasonic Viera TC-50PS64 to go on sale at Costco.
FlynP5 is offline
post #12669 of 12693 Old 12-18-2013, 07:20 AM
FlynP5's Avatar
I was playing around with the Catalyst Control Center settings last night and trying to figure out the "Dynamic Range", some people say use 0-255 full, others 16-235 limited if your TV can accept it. I had the Lagom LCD monitor test page up in my browser while changing the settings and could not see any difference between the different formats.
I looked through the Panasonic manual but could not find an answer, can the TV do 0-255 Full RGB, or is it limited to 16-235.
I ended up leaving it on RGB 4:4:4 Pixel Format PC Standard (Full RGB) which some say is best for an HTPC.
• Connection HDMI Pass Through Onkyo
• Windows 7 HTPC with Radeon HD6870 to Onkyo_TX-SR607 to TH50PZ85U
1. YcbCr 4:4:4 Pixel Format
2. YCbCr 4:2:2 Pixel Format
3. RGB 4:4:4 Pixel Format Studio (Limited RGB)
4. RGB 4:4:4 Pixel Format PC Standard (Full RGB)
FlynP5 is offline
post #12670 of 12693 Old 04-18-2014, 03:13 PM
ctg115's Avatar
OTA Audio problems.
I'm having a problem with over the air broadcast tv audio. I get about 40 channels OTA , on only 2 of the channels the main audio track does not play through the receiver. Every other channel is fine. When I play the audio through the tv's speakers, the main audio track works fine for the two problem channels. To get audio to play through the receiver on those two channels I need to select the SAP on the tv, set it to audio track 2, and then the audio plays fine. I posted the problem in the OTA thread for my area and no one else has this issue. I swapped out the toslink cable and that made no difference. I played around with the audio settings in both the tv menu and the receiver menu but I cannot get it to work. Has this happened to anyone else? Any ideas?
Antenna: CM 3916
TV: Panasonic 42PZ80u
Receiver: Denon 1610
Cross-posting in the tv and receiver thread.
ctg115 is offline
post #12671 of 12693 Old 07-20-2014, 07:02 PM
04ctd's Avatar
are we supposed to log in here with time of death?
manufacture date nov 2008 on back sticker.
first "panasonic blinking red light of death" about a week ago
would unplug it, work for 12 hours, unplug it, 10 hours, till finally...nothing but the blink of death, the 10 blink one...
delivery to Best Buy recycling desk, 20 July 2014.
RIP (Really Inactive Plasma)
04ctd is offline
post #12672 of 12693 Old 07-20-2014, 07:04 PM
Noodles3's Avatar
Couldn't replace the A or P boards?
Sent from my SCH-I545 using Tapatalk
Noodles3 is offline
post #12673 of 12693 Old 07-27-2014, 08:10 AM
Reliantkcar's Avatar
Just got for free 2 pz80u's one 50" other a 42"
Both had 10 blinks
Just snap off 2 bad smd caps and boom both work mint.(what do you think those$100 ebay repair services do?)
50" has 5,000 hours
42" has about 10,000
They look great with Hdmi but component on the xbox 360 is decent with 720p but less sharp in 1080I. My old 360 doesn't have Hdmi. Is there a firmware update to give it better component performance or 1080p component support?
Reliantkcar is offline
post #12674 of 12693 Old 07-27-2014, 08:18 AM
Noodles3's Avatar
Both had 10 blinks
50" has 5,000 hours
Nice
Noodles3 is offline
post #12675 of 12693 Old 08-05-2014, 02:49 PM
nickyboy4's Avatar
How do you check the hours on a 50PZ85U ?
Almost 6 years still love the PQ on this set, hope it never dies.
nickyboy4 is offline
post #12676 of 12693 Old 09-19-2014, 07:58 AM
eyal8r's Avatar
Anyone know the best/cheapest place to buy a replacement P Board for a TH-50pz85u?
eyal8r is offline
post #12677 of 12693 Old 10-21-2014, 03:36 PM
stickboy2k's Avatar
Quoted: 31 Post(s)
Liked: 46
Originally Posted by stickboy2k View Post
Hey!<br>
Just hitting my 4Th year anniversay with the PZ85!<br>
Still going strong. Not a single issue whatsoever.<br>
I hope it lasts forever because it still looks great and I want to stay plazmatic!
ALAS! Finally my 50PZ85U has the 10 Blink issue. 6 Years old, guess that is not bad!
I hope to fix it myself or buy a replacement board. So sad. The picture was and hopefully will be better than anything short of OLED.
stickboy2k is offline
post #12678 of 12693 Old 12-28-2015, 07:08 AM
blynott's Avatar
Quoted: 30 Post(s)
My 46PZ85 is still going strong after over 7 years. However I can fit a 55 inch 4K set in my entertainment center with today's slim bezels. I would like the larger size but am not sure if I will be happy with an LED tv. I also am tired of reading about all the problems with today's "smart" tvs that need to receive updates all the time. Sometimes they fix problems and other times they cause more problems. Guess I'll wait until mine starts blinking at me.
Bob
blynott is online now
post #12679 of 12693 Old 12-30-2015, 07:57 AM
blynott's Avatar
Quoted: 30 Post(s)
Update: I guess part of the reason I was looking at a new LCD set is that my plasma seemed to have lost some of it's punch. Last night I went in and tweaked the settings a bit and it looks like new. Actually it looks more like the new tvs in the store, over-bright and over-sharp, but my wife likes it. So now I really can't justify a new set. Let's see what CES has to offer.
Bob
post #12680 of 12693 Old 02-22-2016, 01:14 PM
stickboy2k's Avatar
Quoted: 31 Post(s)
Liked: 46
Well, I have finally decided that I may want to use one of those eBay repair services to fix my 10 Blink problem.
I would undertake the chore myself but I simply don't have the experience soldering and I would have to spend more than $50 in tools and stuff just to do it. So I am going for the sure(er) thing.
I just miss the 50PZ85U so much I can't stand it.
It's like having Morgan Fairchild for an ex-girlfriend.
Anyway, the price on these services has dropped considerably, I will post back my experience for those who still care.
post #12681 of 12693 Old 02-22-2016, 03:41 PM
Noodles3's Avatar
See if you can get a new board from Panasonic. Then it's just a matter of about 30 screws to remove and plug and play with the board.
Sent from my XT1060 using Tapatalk
Noodles3 is offline
post #12682 of 12693 Old 02-22-2016, 08:00 PM
TheRatPatrol's Avatar
Quoted: 70 Post(s)
Liked: 60
I'm curious to see how many people are still using their Panasonics?
I use mine everyday and it's still going strong, bought in 2009.
TheRatPatrol is offline
post #12683 of 12693 Old 02-23-2016, 04:25 AM
Noodles3's Avatar
I had to replace the P board in mine about 2 years ago due to 7 or 10 blinks I don't remember now. But bought it in 2009 still running like a champ after that fix.
Noodles3 is offline
post #12684 of 12693 Old 05-06-2016, 06:43 AM
evident's Avatar
I picked up mine on craigslist for $80. It had non-functional hdmi ports. I used an ebay service for another $80, so for $160 I have an awesome 50 inch tv that beats many LCD's out there today still!
evident is offline
post #12685 of 12693 Old 04-20-2017, 06:14 AM
Liked: 0
PZ80 trouble
Hoping someone can identify my issue from this description. It seems like a loose connection as it comes and goes.
left side of screen goes black, right side seems to now contain the entire picture, not just the right half. the picture is distorted with numerous vertical colored lines and it tends to move vertically as well(bottom and top sometimes in middle.
I have had the back off and re-seated a few of the more obvious ribbon cables, with out luck. wondering if this is evidence of a board failing or if i should dig deeper on the cable re-seating.
Ruili is offline
post #12686 of 12693 Old 04-20-2017, 06:26 AM
Liked: 0
ive determined it is definately something lose, jarring the tv corrects it for a time. Just need some idea where that connection is. It seems like on half of the panel is just shut off since all of the picture shows up on the right. would that be a Power supply issue?
Ruili is offline
post #12687 of 12693 Old 05-08-2017, 09:57 AM
Mark_Likes_Games's Avatar
Quoted: 34 Post(s)
I have found a used TH-42PZ85U for a very low cost. One owner, but probably lots of hours. I like LCD but have always been curious about Plasmas. I like the Panasonic brand in general. It would be used for gaming consoles only.
Should I do it?
How DARE you question my ignorance!?!
Mark_Likes_Games is offline
post #12688 of 12693 Old 05-08-2017, 06:24 PM
Quoted: 148 Post(s)
Liked: 45
Should I do it?
How much? That's a 2008 model. I would shoot for something 2011 and up. ST, GT or VT.
Test Ickles is online now
post #12689 of 12693 Old 05-08-2017, 07:27 PM
Quoted: 34 Post(s)
Thanks for the response. Asking $150. I'm ok with the older specs except for the high power use - almost 600W!!
I suspect it will have pretty high hours - so my only other concern is that it will appear dim compared to the top of the line vintage Sony CRT this would be replacing. I don't pump my LCD to torch levels, but I'm hoping it will be at least as bright as the CRT.
I will only use it once in a while for LAN gaming on a 360 or maybe with some older 480 consoles (PS2 / original Xbox).
Seller upgraded so this one is supposed to be still working fine. No replaced boards - which might be a bad thing...
Should I do it just to satisfy my plasma curiosity? This was considered a good mid-model right?
post #12690 of 12693 Old 05-08-2017, 11:08 PM
Quoted: 148 Post(s)
Liked: 45
Yes it was good in it's day but Plasma's got a lot better.
