Master thread for Panasonic plasma not turning on - Page 69 - AVS Forum
post #2041 of 2043 Old 07-11-2014, 02:29 PM
Liked: 0
Is anyone able to help with my problem?
WesleyPrice396 is offline
post #2042 of 2043 Old 07-11-2014, 02:44 PM
Liked: 0
Thanks kdh05. I am a novice at soldering... What is flux?
Originally Posted by kdh05 View Post
Don't worry about the heatshrink on that orange cap, no problem.
You did great! And the tv will probably work as is indefinitely.
But, if you add a dab of flux on each lead of the two caps, then put the iron on each one for about two seconds, it would smooth out the joint and make it a better solder joint, too.
Enjoy your tv!
Ichthys is offline
post #2043 of 2043 Old 07-11-2014, 05:18 PM
Crash55's Avatar
So my 2007 Panasonic TH-42PZ700U developed 10 blink syndrome on Mon. I replaced it with a Sony KDL-50W800B but I would like to repair the Panny if possible.
I took the back off but I see no obviously burned components.
What should my next steps be?
Crash55 is offline
Panasonic
User Tag List
