Break in DVD not working in any DVD player - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-01-2008, 10:41 AM - Thread Starter
kam1996's Avatar
Hey guys,
I downloaded the Break in DVD from http://www.eaprogramming.com/
and have burnt 5 different copies using Nero and Power ISO, none of my DVD players, including the Toshiba HD-A2 or my Sony Prog Scan DVD player are playing the DVDs. I just see a light blue blank screen.
I tried to search the forum about this but didnt find any threads about problems with the DVD itself.
Thank you
kam1996 is offline
post #2 of 8 Old 03-01-2008, 11:28 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Originally Posted by kam1996 View Post
Hey guys,
Thank you
Didja try Fast-Forwarding it to see if the color of the screen changes? Light blue is the first color you see when you first hit the PLAY key so if you only watched it for a few seconds you didn't give it time for the colors to start changing.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #3 of 8 Old 03-01-2008, 11:37 AM - Thread Starter
kam1996's Avatar
I fast forwarded to 30 mins.
Also, the one that I burnt using Nero, plays fine for 1 min and 36 seconds and then goes blank.
kam1996 is offline
post #4 of 8 Old 03-01-2008, 05:12 PM
chadmak09's Avatar
I ordered the DVD already burned from ea programming.com. It should be here monday I think.
I was wondering, Should i use my Playstation 3 to upconvert the dvd or should I use my HD-A3 Toshiba HD-dvd to do the upconverting??
Should I even be upconverting the DVD??
What resolution should i set it to play at while doing break in?? 1080p??
thakns,
Chad
chadmak09 is offline
post #5 of 8 Old 03-01-2008, 09:51 PM
jollyrogr's Avatar
Try Imgburn? It's free btw.
jollyrogr is offline
post #6 of 8 Old 03-06-2008, 07:12 PM - Thread Starter
kam1996's Avatar
Hey guys,
I just got my break-in DVD and it is playing right now.
I have a question regarding the speed of the changing colors. The colors seems to be changing very slow may be once every 1-2 minutes, is that how the DVD shoudl be?
kam1996 is offline
post #7 of 8 Old 03-06-2008, 09:10 PM
swlee's Avatar
I downloaded and burned the ISO file a couple of months ago. My version has 90 chapters, with each lasting 30 sec. It automatically repeats after 45 minutes. Some of the chapter-to-chapter changes are pretty subtle, but if you watch closely you can see a brightness and/or hue shift when it moves to the next chapter. Keep an eye on your DVD player's display, and you should see the chapter # change; then you can track how long chapters are and see if you can detect changes on your screen ...
swlee is offline
post #8 of 8 Old 03-07-2008, 05:52 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4050
please use sticky at top. OP is all set now. thanks
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
Closed Thread Plasma Flat Panel Displays
