Power Conditioner/UPS for my Plasma/AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-04-2008, 06:46 AM - Thread Starter
claymanhb's Avatar
I found a Power Sentry Home Theater Surge Protector, Line Conditioner and UPS from woot for $89.99. Is this a good deal? Do these actually work? Will it provide clean power to my HT? I froogled it and found it for $350.
Samsung 58B650 plasma|Pioneer Elite SC-71|Polk CS2|2-Polk Monitor 70s|2-Polk Monitor 40s|Energy ESW‑C10+BIC PL-200
claymanhb is offline
post #2 of 13 Old 04-04-2008, 06:55 AM
iatacs19's Avatar
Quoted: 239 Post(s)
Liked: 149
If you are going to invest in a UPS, I suggest you look at APC's Smart-UPS line, those are the most affordable UPS's that can do true sine wave output.
XBR65X930C, AVR-X4200W, NVIDIA ShieldTV, SVS SB12-NSD, RF-42 II, RC-52 II, RB-41 II
iatacs19 is offline
post #3 of 13 Old 04-04-2008, 07:59 AM - Thread Starter
claymanhb's Avatar
Anyone else have an opinion on this thing?
post #4 of 13 Old 04-04-2008, 08:18 AM
topperdude's Avatar
Am interested in feedback/reviews for same as well. Dont really care much for the UPS functionality myself tho'. Hope someone can chime in, although there doesn't seem to be much info on these.
woot price seems to be good - walmart.com lists the same thing (I think) for a lot more here.
-Topper
Edit: Could not find any professional reviews, but there is some positive feedback on this in the woot community posts for this item. HTH.
topperdude is offline
post #5 of 13 Old 04-04-2008, 08:53 AM
videoaddikt's Avatar
Quoted: 40 Post(s)
Battery back-up with good protectiion >APC Smart UPS.....
Very good to excellent power protection and/or conditioning $-$$ Panamax...$$-$$$ Furman.
At least that's always worked for me.
Samsung PN51F8500, Emotiva MC-700, Emotiva A-500, Xbox One S, Dali Ikon 6, Vokal 2, OnWall, Outlalw LMF-EX, Furman Elite pf15i.
videoaddikt is offline
post #6 of 13 Old 04-04-2008, 08:58 AM
iatacs19's Avatar
Quoted: 239 Post(s)
Liked: 149
APC Smart-UPS has battery backup, power conditioning and surge protection.
Some details
Furman and Panamax seem way overpriced for what they are, have you ever opened one and looked at it? I was surprised to say the least.
iatacs19 is offline
post #7 of 13 Old 04-04-2008, 09:05 AM
209Mason's Avatar
I thought this was a good deal too at first, but then I saw that it's rated at 500W... is that enough to cover a 50" Plasma? I was thinking they were rated at 700+ wats Peak?
I'm not sure, I'm just asking because I was interested too.
209Mason is offline
post #8 of 13 Old 04-04-2008, 09:22 AM
Quoted: 40 Post(s)
Some details
Yes, I have, as matter of fact. And I did not see a problem. First negative thing I've heard about either product.
Like I said, I would easily pick APC for battery back up, I don't think anyone does it better. But I don't think they have the best conditioning or power reserve of a Furman.
No battery back up, the quick disconnect of power of either the Panamax or Furman in the event of over or under-voltage is unparalleled IMO.
After the all the best protection is NO connection, unless we are talking about writing devices (hard drives, etc.) and some lamp projection systems, then I think an UPS is a much better solution.
That's MO based on work and home experience of all three.
You are certainly entitled to yours, and let's be thankful there are enough choices to go around. Don't get me wrong, you could certainly do worse than having APC for everything.... a lot worse!
post #9 of 13 Old 04-04-2008, 09:24 AM
Quoted: 40 Post(s)
You should allow at least 25% more reserve than the total wattage ratings of all the components you want to protect.
post #10 of 13 Old 04-04-2008, 09:27 AM
209Mason's Avatar
Thanks for the info!
So is it safe to say that for a Plasma, you'd want atleast 1500VA/900W for your UPC... or is that overkill?
209Mason is offline
post #11 of 13 Old 04-04-2008, 09:35 AM
Quoted: 40 Post(s)
No such thing as overkill except spending more money than you need to.
You have to know the exact wattage of the plasma, assuming it's 700 watts you are fine. More reserve buys you more 'battery time' if there is an outage.
You might consider putting a DVR or DVD recorder on it too, if you have those.
You don't want to remove power while writing data to a disk. You have plenty of reserve to do that with the 1.5VA.
post #12 of 13 Old 04-04-2008, 04:08 PM
jdsmoothie's Avatar
Quoted: 15052 Post(s)
Liked: 7262
That's fine if all you're plugging in is the plasma TV; however, if you're adding a satellite/cable box, DVR, game console, and AVR, then you'll need something closer to 1500W.
jdsmoothie is offline
post #13 of 13 Old 04-04-2008, 07:39 PM
Quoted: 40 Post(s)
Definitely.. he needs to add up wattage for each device and add in the margin.
