just got a new plasma, is this great buy?and new to this forum, Have questions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-09-2008, 03:12 AM - Thread Starter
nito3's Avatar
well just got a panasonic th-42pz77u. It was'nt the tv i was looking for but i taught it was a great price. I had an LCD in mind in sizes 32 to 37 720p but saw this at best buy and it's 1080p and 42 so i gave it a try.
So what should i do first(break in) is it necessary?can i play ps3 right away?does this tv have a system like pixel shifter to prevnt burn in? and how do you do this,thanks
nito3 is offline
post #2 of 9 Old 04-09-2008, 05:48 AM
optivity's Avatar
optivity is offline
post #3 of 9 Old 04-09-2008, 11:41 AM
airhostess's Avatar
Despite what anyone here *suggests, read your tv manual and follow its instructions first.
You will encounter image retention (IR), and some will wipe clean faster than others, but most if not all IR will fade. The tv will typically get better with some age (months rather than hours I say).
Your manual will tell you how to activate the pixel shift function
I play 360 on my Samsung plasma and I started right out of the box, break in is a clique rather than a fact, do some reading here and make your own mind up. I do get IR but it does wipe away in less than 30min (7 legendary Halo hours trying to kill two F%*(&^ Scarab tanks). Permanent burn is nearly a myth, in fact the only perm burn I have seen is on early plasma models used as leaderboards and baggage claim wards, and I bet that would wash away nearly clean after some good tv viewing.
airhostess is offline
post #4 of 9 Old 04-09-2008, 11:56 AM
slbosse's Avatar
Congrats on your purchase! The PZ77U's are great TV's, no doubt. If you haven't already, you may want to skim through this thread, which is dedicated to that model:
http://www.avsforum.com/avs-vb/showthread.php?t=938089
slbosse is offline
post #5 of 9 Old 04-09-2008, 11:59 AM
mswlogo's Avatar
Quoted: 27 Post(s)
Liked: 46
I agree I think Burn in just wastes energy and life of your set.
Just be a little extra careful (conservative) with settings for the first few months and try to keep it on full screen and you'll be fine.
If you see IR, don't panic, ignore it use it on full screen and a couple days later it will probably be gone.
LG - OLED65C6P
All Meridian Audio System with DSP-6000 Mains
TIVO Series 3 HD - OTA
Philips UHD BluRay BDP-7501
Harmony Elite Remote
mswlogo is offline
post #6 of 9 Old 04-10-2008, 05:33 AM
optivity's Avatar
optivity is offline
post #7 of 9 Old 04-11-2008, 01:10 AM - Thread Starter
nito3's Avatar
where in the manual does it say how to activate the pixels hifter? cant find at all
nito3 is offline
post #8 of 9 Old 04-11-2008, 01:40 AM
HDPeeT's Avatar
The pixel shifter is always on in the Panasonics.
Patience has its rewards.
HDPeeT is offline
post #9 of 9 Old 04-11-2008, 06:51 AM
jdsmoothie's Avatar
Quoted: 12090 Post(s)
Liked: 5503
As HDPeet said, the pixel shifter is always ON in the Panasonics so there is no adjustment required. Addtionally, based on postings in the PZ700 thread, very few owners actually see IR of any kind. I've played PS3 (on VIVID) from the beginning and have never seen any IR. In fact a number of us never did any kind of "break-in" procedures at all (except reducing PICTURE setting to 0), rather just watched TV as we usually would and STILL never had any IR. However, if you want to get through the 100 hour "break-in" faster and are concerned about IR on your set, just leave your set on HD Discovery for 10 hrs/day and you'll be done in 10 days (especially if you're anxious to get that PICTURE setting back up to 20+ as most are). With a 1/2 life of 60,000 hours, you're hardly shortening it's life span by speeding through the first 100.
Edit: I just found your other thread indicating you are already "freaking out" about some IR. It would seem you should speed through the first 100 hours as suggested. Any IR you experience should be gone quicker after that and generally in just a few minutes. One guy said in order to test his new set, he left it on a static image for 5 hours and it STILL only took about 5 minutes of watching some HD programming to wipe the IR away. Another benefit of speeding through the first 100 hours is it still gives you time to evaluate the set and still be inside the vendor's 30 day (or whatever it is) return policy.
jdsmoothie is online now
