The Official 9G Pioneer General Discussion Thread - Page 238 - AVS Forum | Home Theater Discussions And Reviews
post #7111 of 7985 Old 07-11-2008, 08:28 AM
QQQ99999's Avatar
Originally Posted by mwatcher View Post
Since I don't have the Denon player, does anyone know if it's possible for the PS3 to send a raw 480i signal via HDMI to the Kuro?
Nope, it can send 480p but not 480i over HDMI.
QQQ99999 is offline
post #7112 of 7985 Old 07-11-2008, 08:29 AM
ercc's Avatar
Originally Posted by Woodrow View Post
I responded to irwinroad two posts back..hope it solves the issue enough to be acceptable.
chris
oops didn't see that. Just read it, sounds good to me.
ercc is offline
post #7113 of 7985 Old 07-11-2008, 12:59 PM
aks434's Avatar
Originally Posted by AlexInvision View Post
100% agree, I love widescreen even with the bars on the top and bottom and I hate when the bars are on the sides, it just bugs me. But, I know more people who prefer the bars on the sides, it is just one of those things.
I think you all have taken my original query on aspect ratio in wrong spirit. I do not recall suggesting cropping/distorting image to fill screen is better than widescreen. I merely observed that widescreen results in wasting pixels - but that's how it is intended by the film producer and that's fine.
I remember D-Nice's comments that Pioneer's own upscaling is much better than most of the upconverting dvd players. I think I agree with him. To use Pioneer's upscaling, one has to send 480i or p signal. When doing so, I found that I can use "Cinema" mode which almost fills up the screen. I looked hard and compared it with WS but cannot find or determine if the image is cropped or distorted. Just want to know if my finding is correct or am I missing something?
Again, please understand I am not pushing to fill up the screen at the expense of image quality so don't bombard me with those remarks.
BTW, the cheapest way to send 480i raw to pioneer xx20s is using toshiba hd-a30. This is an HD-DVD player and can be had in barely used condition for less than $100 on ebay. They also send 1080p24. SD DVDs look great. Audio is very good too. Am waiting on Emotiva UMC-1 to try out TrueHD.
aks434 is offline
post #7114 of 7985 Old 07-11-2008, 03:38 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
Just to add a little more detail:
Deinterlacing is a big Kuro advantage so D-Nice suggests sending 480i using a HDMI connection. Letting the DVD player deinterlace 480i to 480p would be a disadvantage. Using a component connection would also be a disadvantage.
htwaits is offline
post #7115 of 7985 Old 07-11-2008, 03:44 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
The replies that you've gotten may stem from your first questions on that topic.
Is there a way to get rid of black bars at top and bottom when watching WS format DVDs? I watched LOTR sourced from Philips 5982 @ 480p and Cinema mode on 5020 which gave smaller bars. Full mode gives bigger bars. If upconverted to 1080p then Cinema mode is not available and big bars don't go away. I am using D-Nice's settings of Movie. Am I missing something?
htwaits is offline
post #7116 of 7985 Old 07-11-2008, 04:36 PM
jtack's Avatar
The video geek in me is curious: does it use motion compensation or is it just motion adaptive? (Well, I assume it is at least motion adaptive and not just a simple bobber.)
jtack is offline
post #7117 of 7985 Old 07-11-2008, 04:47 PM
Coyote Waits
htwaits's Avatar
Quoted: 953 Post(s)
Liked: 2105
It's not a bobber, but beyond that, I don't know.
htwaits is offline
post #7118 of 7985 Old 07-11-2008, 04:47 PM
Aetherhole's Avatar
Quoted: 327 Post(s)
Liked: 459
It's not motion adaptors or enhancers. It's simple deinterlacing, or rather not-so-simple deinterlacing since so many components get it wrong.
LG OLED65C6P ISF Calibrated by David Abrams @ Avical
Marantz AV8801 / D-Sonic M2500 / Oppo UDP-203
GR Research LS-9 / GR Research X-Voce / GR Research AV-1RS / Oppo PM-1
Aetherhole is offline
post #7119 of 7985 Old 07-11-2008, 04:50 PM
jtack's Avatar
I believe that given the tests I've read that the Kuro does pass, it must be at the very least motion adaptive. Otherwise the motion resolution would be much lower than seems to be reported.
But I'm hoping it's one of the few deinterlacers that use motion compensation. It's much more computationally expensive, and tough to get right, but the quality improvement over the comparatively simpler motion adaptive approaches is very apparent.
jtack is offline
post #7120 of 7985 Old 07-11-2008, 05:50 PM
progprog's Avatar
Quoted: 88 Post(s)
Liked: 71
The 151 has a setting for the de-interlacing function. As the manual doesn't really explain what the different options actually do, may one of you guys who know a lot about this could give some insight, and maybe even some advice on when to use which settings. The options are:
1 = optimizes video images
2 = standard setting
3 = optimizes still images
progprog is offline
post #7121 of 7985 Old 07-11-2008, 06:39 PM
jtack's Avatar
Originally Posted by progprog View Post
The options are:
Based on this I strongly suspect it is strictly motion adaptive, and these settings allow one to tune the motion threshold.
In other words, when set to 1, it will be more likely to consider a block in motion (and therefore bob it), whereas with option 3 it will be more likely to consider a block as static (and therefore weave it).
Without experimenting with the settings I have nothing to say about them, but I'd suspect leaving it set to 2 probably is the better default.
It's a bit disappointing, but I'm not terribly surprised. Motion compensating deinterlacers seem to exist in only very high end equipment. (Maybe some of the better outboard processors do it?)
jtack is offline
post #7122 of 7985 Old 07-11-2008, 07:50 PM
frvega2000's Avatar
Please forgive me if this has been answered, but I want to make sure I understand. Reading through the thread, I understand that the Kuro (mine is the 151) automatically upconverts 480i/p, 720i/p and 1080i to 1080p, which is it's native resolution. However, when I pass a 480p signal, I press "Display" and it shows 480p on the Plasma. I can also see that the picture is lower quality than 1080p. When I have the PS3 or DVD player upconvert to say 1080i/p, then I see the much better quality picture on the Plasma and the "Display" reads 1080i/p. So what am I doing wrong or is there a setting on the Kuro that I am overlooking, that makes the Kuro upconvert? Manual was of no use to me in this regard. As always, I appreciate the help provided by this forum's members.
Maximus - "Are you not entertained! Are you not entertained! Is this not why you are here!"
frvega2000 is offline
post #7123 of 7985 Old 07-11-2008, 08:19 PM
miata's Avatar
Quoted: 65 Post(s)
The Kuro automatically upconverts to the native resolution. It is hard to explain why 480p is lower quality than 1080p unless you are down-scaling a 1080p source to 480p in the player. If you feed the Kuro a 480p signal from a 480p source the signal will most like be as good or better than having the player upscale it to 1080p. The Kuros are excellent at scaling.
miata is offline
post #7124 of 7985 Old 07-11-2008, 08:28 PM
chadmak09's Avatar
When you press "display" on your remote, the resolution that it shows on the screen (480p/1080i/etc) is only to show you the resolution on the incoming signal.
When it says "480i", that means what you are seeing is 480i upconverted to 1080p.
When it says "480p", that means what you are seeing is 480p upconverted to 1080p.
When it says "720i", that means what you are seeing is 720i upconverted to 1080p.
When it says "720p", that means what you are seeing is 720p upconverted to 1080p.
When it says "1080i", that means what you are seeing is 1080i upconverted to 1080p.
When it says "1080p", that means what you are seeing is 1080p upconverted to 1080p.
you are always seeing 1080p. the quality and resolution of the source is why you see differences
chadmak09 is offline
post #7125 of 7985 Old 07-11-2008, 08:33 PM
Robert2413's Avatar
At least with the HQV test DVD, the PS3 (with current software) is actually better at deinterlacing 480i than my 150. I have also compared the PS3 to a Denon DVD 3930 (which has the Realta chip) and the two are comparably good at deinterlacing video material (using not only the HQV test DVD but also real-world program material). However, the Denon is slightly better at sharpening the image and doing noise reduction.
The 150's deinterlacer came in well behind the PS3 and Denon. It took a long time to lock onto the 3:2 cadence in the "Speedway" test (both the Denon and the PS3 were extremely quick) and also showed substantially more "feathering" or "combing" artifacts with real-world video-originated material. The 150's deinterlacing is good, but I would not call it "excellent." It's clearly not up to the current state of the art.
Robert2413 is offline
post #7126 of 7985 Old 07-11-2008, 08:34 PM - Thread Starter
D-Nice's Avatar
Quoted: 706 Post(s)
Liked: 1505
Everyone,
I'm happy to report that the 9G non-Elites can officially be calibrated
Colorspace selection may also be capable. I will report back later.
D-Nice is offline
post #7127 of 7985 Old 07-11-2008, 08:40 PM
ChuckZ's Avatar
Cool, D-Nice.
Let us know what tools we'll need and to the extent that regular Kuros can match their Elite counterparts.
ChuckZ is offline
post #7128 of 7985 Old 07-11-2008, 08:46 PM
miata's Avatar
Quoted: 65 Post(s)
De-interlacing is one thing, but scaling is another. When we are talking about the difference between 480p and 1080p we talking about scaling -- and that the Kuros do very well.
I also compared my 8G Kuro's de-interlacing to the PS3 and found the Kuro to be better. The image had more detail and was more realistic with well authored titles like Star Wars. I wasn't so much looking at torture tests as real world viewing. I remember the Kuro having troubles with certain cadences compared to the HD-XA2 or the OPPO 983, but I don't put much value on that compared to the overall image that you get with the vast majority of released DVDs. I guess it depends on what is important to you. I personally tend to spend more time watching movies than calibration discs
miata is offline
post #7129 of 7985 Old 07-11-2008, 08:48 PM
antennahead's Avatar
Quoted: 256 Post(s)
Liked: 178
I agree. Another one that beats it as well is the OPPO 983 with ABT de-interlacing. I think sometimes people confuse the excellent scaling capabilities of the Pio's with the de-interlacing capability....... two different things altogether. Not that the Pio de-interlacing is bad, just not the king of the hill some think it is.
John
antennahead is offline
post #7130 of 7985 Old 07-11-2008, 09:10 PM
chadmak09's Avatar
Originally Posted by D-Nice View Post
Everyone,
Can you possibly change the layout of the NR,DRE,BLK LVL,ACL,ENHAN, GAMMA,CTI for each video mode(movie, Game, standard,etc)?
post #7131 of 7985 Old 07-11-2008, 09:10 PM
The_Hun's Avatar
This is for D-Nice or anyone that knows the real answer to this question.
I have the ps3 and the 5020. I have been using D-Nice's movie settings and they are great. I only tweaked teh colour up to my liking. However, last night i was playing with teh ps3 settings during a movie so i could get direct comparisons. I went into video settings and was switching between RGB colour and Yp/Cb/Rc/Bp or whatever the letters are. and the setting i usually had the ps3 on was the Yp/Cb... so when i switched to RGB i noticed the colours in the movie had alot more pop to them. then went i swtiched back the colours were more soft. So i was thinking if I did not tweak D-Nice's colours up a couple notches on the RGB setting would the be the correct ps3 setting. So in other words, my question is should i be using the RGB colour or the Yp/Pb/Rc.. thing? Let me know, thanks
The_Hun is offline
post #7132 of 7985 Old 07-11-2008, 09:14 PM - Thread Starter
D-Nice's Avatar
Quoted: 706 Post(s)
Liked: 1505
No. Just like last year's non-Elite, you can only calibrate one set of RGB controls. That means the changes will be global. I will be calibrating Movie mode as it is still the most accurate mode.
BTW, it may be possible to modify the gamma.
D-Nice is offline
post #7133 of 7985 Old 07-11-2008, 09:51 PM
LKDog's Avatar
Everyone,
Thanks for your persistence on researching the SM.
Will be interested to hear what you think the improvement can be from calibrating on the non-Elites.
LKDog is offline
post #7134 of 7985 Old 07-11-2008, 10:12 PM
Kurisu2's Avatar
Is anyone using their 9G with an HTPC? What settings are you using on the Pioneer, and what settings on the PC?
I've got a 6020 and an ATI HD4850, but I can't figure out what to set on each. Regular 1920x1080 @ 60hz looks fine when playing Batman Begins Blu-ray, with the 6020 in simple movie mode. Anything else that would improve this? Thanks a bunch!
Kurisu2 is offline
post #7135 of 7985 Old 07-11-2008, 10:22 PM
Tyns78's Avatar
D-Nice - is calibrating the non-elites via the service menu something the average avsforum user will be able to do with a proper guide, and is it something that a professional calibrator would do, or would they not want to mess with the service menu...?
Thanks for all your work. I just watched Apocolypto on Blu-Ray w/ your reference settings and it looked absolutely fantastic.
Tyns78 is offline
post #7136 of 7985 Old 07-11-2008, 10:31 PM - Thread Starter
D-Nice's Avatar
Quoted: 706 Post(s)
Liked: 1505
It's best just to leave it on Auto.
D-Nice is offline
post #7137 of 7985 Old 07-11-2008, 10:33 PM - Thread Starter
D-Nice's Avatar
Quoted: 706 Post(s)
Liked: 1505
Originally Posted by Tyns78 View Post
D-Nice - is calibrating the non-elites via the service menu something the average avsforum user will be able to do with a proper guide.....
Not sure. However, it's really quite easy.
A REAL calibrator would want to use the SM as it is the only place you can adjust the grayscale on the non-Elites.
Thanks for the kind words.
D-Nice is offline
post #7138 of 7985 Old 07-11-2008, 11:25 PM
Quoted: 256 Post(s)
Liked: 178
Hey D-man ( I say that with the greatest respect and smile on my face)
As a 5010 owner, would I be correct to assume the instructions on how to get to the SM on my model and the values for the grey scale calibration are somewhere in the 8G calibration/settings thread? (wonders if I could bribe you enough to come to Charleston to oversee the process
Oh, btw, had a good friend that owns a sign business cut down my stand and drill new holes in the stand for the bolts..................... got it back today, my 5010 now sits nice and flush like an Elite with no gap at the bottom
John
post #7139 of 7985 Old 07-11-2008, 11:38 PM
Dovetails's Avatar
D,
I trust your valuable input on this forum and I guess i'm looking for a little 'extra' reassurance .... I posted my auditioning experience today with the 5020 while at BB on the non-elite 9g thread. Tell me i'm off base and that this set will, in fact, really excel on 'movie' mode in a darkened HT environment i've re-read your review and noted you suggest avoiding 'dynamic' mode explicitly, (which I can usually understand under dark room conditions) however, at our local BB this mode simply looked stunning! Creating a 3D depth and richness to the pic that no other display in the store could match (even the 5010 sitting next to it). And, yes, I understand it should look impressive with the brighter environment.And,of course, 'Movie' mode (understandably) looked less than impressive considering the lighting. Bottom line is .... I guess i'm affraid of getting this set home and the recommended 'Movie' mode still looking a little too suttle for my taste and not having a viable alternative setting to use (considering your opinion on the remaining picture modes and the limited user adj.) Am I needlessly worrying about this
Dovetails is offline
post #7140 of 7985 Old 07-11-2008, 11:53 PM
PioBeer's Avatar
Quoted: 17 Post(s)
I was in BB the other day as well, and I compared the 5010 to the 5020 and the 5020 IMO was the better TV by quite a good margin. (8G still better than everyother plasma besides 9Gs). It impressed me so much that I bought it and took it home right then and there (well, after about an hour of drooling.) Believe me, Movie mode with D-Nice settings can't be beat. The colors are so natural not over-saturated at all, and the gray-scale/shadow detail can't be beat. With those settings, it is simply the best TV/PQ I have ever experienced in my life. With movie mode you can just set it and forget it.
"Reckon I get me some fried po'taters mmm hmmm"
PioBeer is offline
