Samsung PN58A650 Owners Thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
post #2341 of 2353 Old 09-07-2011, 07:17 AM
dallasdiscus's Avatar
Anyone have vertical blue and red line in right lower side? I have changed the y buffer board with no success. My Plasma is out of warranty. Planning to change y sustain board. my 58a650 was made in 2007. see attach picture. thanks in advance..
dallasdiscus is offline
post #2342 of 2353 Old 09-13-2011, 05:35 PM
bizuca's Avatar
I had almost the same thing,but mine was green.
http://www.avsforum.com/avs-vb/showthread.php?t=1278856
bizuca is offline
post #2343 of 2353 Old 09-13-2011, 05:39 PM
bizuca's Avatar
Originally Posted by JOE.G View Post
I have 50 Inch version of this tv, is it able to play 3d Movies? if so what would I need?
http://www.avsforum.com/avs-vb/showt...1#post20944031
bizuca is offline
post #2344 of 2353 Old 09-14-2011, 05:39 PM
JOE.G's Avatar
So the TV isnt 3D Capable?
Samsung HL-T6176S 1080P DLP
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung PN50A650 1080P Plasma
Panasonic DMP BD 85 K
Samsung LN32C530F1F
Panasonic DMP BD10 A
JOE.G is offline
post #2345 of 2353 Old 09-15-2011, 07:48 AM
lankshire's Avatar
No, the PN58A650 plasma display is not 3-D capable. You will need a newer model if that is what you're looking for.
lankshire is offline
post #2346 of 2353 Old 10-13-2011, 01:58 PM
Sxar's Avatar
Originally Posted by Rickylane44 View Post
I am having the same problem...? The glass on our Pn50A650 has slipped down about an inch? Looks like the bezel maybe came loose at the bottom and "allowed" the glass to slip down. Is that all that holds the glass "up" is the bezel? Anybody else have this happen? Any ideas on a fix?
I had this happen about a year ago. I tried taking the bezel off, but ended up breaking it in one section. Right about when I had it all the way off. The bezel holds the glass and double sided tape holds the bezel. The bezel has small ledges that the glass sits on. Bad design in my opinion as most of the bezel came apart easily except for the small section that broke where the tape was actually holding really well.
I ended up pushing the glass up back into place and using clamps at the bottom to keep the bezel tight and hold the glass. If I had it to do over again (and a helper), I would have laid it down flat (not sure if this is advised as I did not investigate it), repositioned the glass, and used some automobile body panel double sided tape to replace the tape that was there. I may do this as I am tired of the clamps being there.
Sxar is offline
post #2347 of 2353 Old 02-22-2012, 05:24 PM
pwygant's Avatar
Greetings,
I have now had my PN58A650 for several years. I'm starting to notice that when I turn it on it displays basically what I have to refer to as red/white/green snow across the entire screen until the unit has warmed up. It is barely visible but now I try to turn my TV on for about 20 minutes before I watch a movie. Browsing the web I am finding that I might need to adjust VSCAN on the power supply. Anyone know how to do this or seen this symptom?
//Cheers
Note: Sorry for bumping an old thread
pwygant is offline
post #2348 of 2353 Old 09-14-2013, 03:13 PM
bizuca's Avatar
How can I find out how many hours have used this TV ? I have it since 2008.is there a hidden menu or something ?
Thank you
bizuca is offline
post #2349 of 2353 Old 09-15-2013, 06:11 PM
JOE.G's Avatar
Id like to know also.
Panasonic DMP BD55
Onkyo HT-SR800 7.1
Samsung LN32C530F1F
JOE.G is offline
post #2350 of 2353 Old 10-23-2013, 12:15 PM
Gsaraco's Avatar
I came here to post about the exact same issue! One night I was watching TV just fine; the next night I noticed that the glass had slid down about an inch (more on the left side) and the front-left corner of the bezel had popped open.
I really don't know what to do about it. Samsung is quoting $700 for an out-of-warranty fix, which is preposterous. Their inflated repair cost includes replacing the glass and bezel, which I don't even need!! I just want them to put their TV back together. mad.gif I am going to speak to Executive Customer Relations and bring what is clearly a manufacturing defect to their attention; hopefully I can raise a little hell and get somewhere.
Patent Penguin likes this.
Gsaraco is online now
post #2351 of 2353 Old 12-13-2013, 10:03 AM
Thomas Edison's Avatar
LOL....Hahaha
Thomas Edison is offline
post #2352 of 2353 Old 12-13-2013, 10:06 AM
Originally Posted by jttar View Post
Hello Matt,
Now that is scarry. How could anyone be in the position of working on televisions and not know what Pro Calibrations are??? And you had two of them in the same room! Now this dynamic duo are going to "work" on your plasma, like I said, scarry. I hope it all works out for you.
Joe
 Pro calibrated hahaha lmao..... some people just don't know squat about electronics... you got skinned plain and simple and the two technicians had it right where you were wrong. No such thing as pro calibration on a plasma screen. You can only adjust the voltage on the power supply potentiometers to match the sticker voltage on the screen panel and that is all... lol
post #2353 of 2353 Old 08-27-2015, 05:50 AM
Rockstead's Avatar
Quoted: 14 Post(s)
Can anyone tell me if the PN58A650 has a designated audio out-put HDMI slot? I don't see an HDMI port on the back labeled as such.
I ask because I want to attach the Vizio SB4051 soundbar too it and I have multiple devices, and I was reading one review that said to plug this in your TV's dedicated Audio Output HDMI port and then devices on other HDMI ports will recognize that the TV is hooked up to a Soundbar and will not use your TV speakers.
Any help would be appreciated.
Sent from my Z30 using Tapatalk
Rockstead is offline
