The Official Pioneer 9G non-Elite KURO Owner's Discussion Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #331 of 15046 Old 06-05-2008, 04:20 AM
grider's Avatar
Originally Posted by Coggs View Post
It sounds like there is a 1.5" recess on the back of the panel where the cable inputs are, so even a mount that sits another 1.5" out from the wall should be fine for fitting the cables. The problem is that Pio recommends that their displays have 4" of clearance on all sides. I think a mount like the Peerless ST670 that sticks our 3" from the wall might be a safer bet. It's also rated for 250lb, and is a 3-stud model (instead of 2 like most mounts) so it should definitely hold the weight for a very long time.
-Coggs
This is overkill the 6020 only weighs approx 120lb without the stand. Fastening into two studs will be plenty.
Sanus low profile mounts are good and about 1.5" deep which will be enough clearance. This will also give you an ample 3" of space for the turn radius of the hdmi cable when it's plugged into the awkwardly positioned hdmi ports.
grider is offline
post #332 of 15046 Old 06-05-2008, 04:22 AM
avssa's Avatar
Sorry if it has been answered for good elsewhere but, are the 9G Kuro brighter for daytime viewing in an uncontrolled environment?
avssa is offline
post #333 of 15046 Old 06-05-2008, 04:25 AM
Quoted: 1679 Post(s)
Liked: 719
ferro,
Any black/white crush? Loosing any details in the shadows that should be there? Things like dark hair look like a blob or finely detailed hair?
With my 7g Pioneer, the panel turned off isn't very black(medium gray). So during the day, the darkest the blacks would be could not be any darker than that shade of gray.
How is the 9g in this regard during mid day room lighting?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
post #334 of 15046 Old 06-05-2008, 04:30 AM
kyler13's Avatar
Absolutely agree. Technically, one stud could hold the weight of the 6020. The weak point of hanging a flat panel TV is the lag screws/bolts and what kind of shear stress they can handle. I'd be more weary of a mount that uses smaller diameter bolts than one that uses 2 vs. 3 stud mounting. You would ultimately get the same holding strength by just using 3 bolts each on a 2 stud mount (compared to 2 bolts each on a 3 stud mount).
kyler13 is offline
post #335 of 15046 Old 06-05-2008, 04:32 AM
HDCanHD's Avatar
From the Elite Cut sheet (Elite-only feature):
- Improved Elite Color Filter for enhanced contrast in bright environments
HDCanHD is offline
post #336 of 15046 Old 06-05-2008, 06:01 AM - Thread Starter
D-Nice's Avatar
Quoted: 649 Post(s)
Liked: 1442
Originally Posted by ikeb View Post
i specifically asked dnice about it a while back and he specifically said that the non-elites have color temp settings - he must have received incorrect info from his contacts at pio.
You are correct. That's exactly what I was told by my contact. I'll take full blame for the mis-information.
D-Nice is offline
post #337 of 15046 Old 06-05-2008, 06:12 AM
edpowers's Avatar
Quoted: 24 Post(s)
Liked: 32
Originally Posted by gregdpw View Post
i think that is why i am waiting for amazon to start carrying these. their delivery service is spot on. and they give you a 30 day price match garentee.
Right. Amazon uses a special shipping service that fills the delivery truck with marshmallows to protect your TV.
Amazon's TV shipping success rate is no better than any other company who uses a reputable shipping company. The difference is that when a random shipping accident happens, what kind of service do you get from the dealer? Sixtysixpony smartly purchased from a great dealer like Chris at Cleveland Plasma. He didn't have to go through Amazon's nightmarish customer support center to get another TV shipped. Go check out resellerratings and specifically look for TV purchase reviews. Compare Amazon's reviews to Cleveland Plasmas.
edpowers is offline
post #338 of 15046 Old 06-05-2008, 06:22 AM
cajieboy's Avatar
Quoted: 125 Post(s)
Liked: 69
i agree. i think pio made a mistake - this is not a 999.95 tv - this is a pretty expensive tv that could have had a standard menu and an advanced menu.
i understand pioneer trying to differentiate their lines - but people that want a no frills tv are not going to buy a pio.
i hope I'm wrong - maybe dnice will say that if you press the xyz button on the remote - you can change the temp or maybe he will have a work around.
or maybe pio knows best (big brother) and i should just shut up and follow them blindly.
I agree. Pioneer should be adding more features, not taking them away. Personally speaking, that's a deal breaker for me, and now can only consider the Elite model, which may be what Pioneer is trying to accomplish in the first place. I think Pioneer will take a hit on this mistep, and hopefully will reconsider. Well, I guess you can't have everything come up roses in the land of Kuro.
cajieboy is offline
post #339 of 15046 Old 06-05-2008, 06:41 AM
gregdpw's Avatar
oh i know they have great prices! i am just nervous about order a 4000 dollar plus tv.
gregdpw is offline
post #340 of 15046 Old 06-05-2008, 06:46 AM
kkgsxr's Avatar
Originally Posted by BFJ 96 View Post
Are you sure? That HDMI Port doesn't look like the flash is distorting it's look. Have you tried plugging an HDMI Cable into it?
I checked the port and it works fine. Just a bad picture.
kkgsxr is offline
post #341 of 15046 Old 06-05-2008, 06:51 AM
kkgsxr's Avatar
Originally Posted by VidPro View Post
Blacks are the deciding factor for me this go around. After viewing a 5010 in an environment where lighting could be controlled I was mightily impressed and it made my 700U that much less appealing to me. Have you an opinion on the difference between the lest years gen of Kuros and the new gen when it comes to improved blacks?
I didn't have an 8g Kuro so I can't compare. I have seen them at my local electronics store, but they weren't configured correctly.
-kkgsxr
kkgsxr is offline
post #342 of 15046 Old 06-05-2008, 06:54 AM
kkgsxr's Avatar
Originally Posted by D-Dub View Post
Hey kkgsxr:
What is the distance (in inches) between the 4 wall-mount bolt holes (horizontal & vertical) on the back of your 6020? And the distance from the bolt holes to the edges?
This info would be useful to me in mounting my Peerless One-TP wall mount prior to delivery of my 6020. Thanks in advance.
(If Pioneer had a PDF of the manual available, I'd try to find this info myself.)
Sure, the mounting holes are:
Horizontal 33 1/2"
Vertical 19 3/4"
12" in from the edge of the display.
-kkgsxr
kkgsxr is offline
post #343 of 15046 Old 06-05-2008, 07:36 AM
BigDog84's Avatar
Horizontal 33 1/2"
Vertical 19 3/4"
-kkgsxr
Thanks for the info. How far are the bottom holes from the bottom of the display? (not including the speaker). Thanks.
BigDog84 is offline
post #344 of 15046 Old 06-05-2008, 07:38 AM
jgreeson's Avatar
There was talk of a redesigned remote. Can someone share a picture of what it looks like? Backlit?
jgreeson is offline
post #345 of 15046 Old 06-05-2008, 08:03 AM
mgd6912's Avatar
Ok... Call me a noob... but can someone explain to me the whole color temp thing and why it would be such a big deal that you couldn't choose it on the 6020's? Thanks!
mgd
PSN: MGD6912
mgd6912 is offline
post #346 of 15046 Old 06-05-2008, 08:26 AM
kkgsxr's Avatar
The bottom holes are about 7 3/4" up.
kkgsxr is offline
post #347 of 15046 Old 06-05-2008, 08:32 AM
Trackman's Avatar
Quoted: 114 Post(s)
Liked: 98
Color temp refers to the image being warm (< 6500'K) or cool (> 6500'K) relative to neutral (6500). Neutral is the standard for accurate reproduction of color film and video.
Some people prefer a slightly cool temp because it makes the image appear more blue (warm = red, cool = blue), which is aesthetically more pleasing to most than too red and tends to make the color white appear whiter (blue white), though this is really an illusion. If you can't adjust the temp, you are stuck with whatever the set came from the factory at.
Go Duke !
Trackman is offline
post #348 of 15046 Old 06-05-2008, 08:36 AM
kkgsxr's Avatar
No, it is not backlit.
kkgsxr is offline
post #349 of 15046 Old 06-05-2008, 08:40 AM
Nambit's Avatar
Remember, though, D-Nice suggested there might not be such a thing as an
elite vs. non-elite after this gen. Next year, we might only see elite-type TVs
with all the bells and whistles and the signature series for those who want a
monitor type (sorta reminiscent of what the elite was in the first place).
BTW, that 're-designed' remote posted by kkgsxr doesn't look like much of a
re-design at all. All they did was move the numberpad up, the directional pad
down and exposed the media/dvd buttons, for the most part. Sigh...
Nambit is offline
post #350 of 15046 Old 06-05-2008, 08:44 AM
RobertR1's Avatar
Quoted: 93 Post(s)
Liked: 154
Seems like Pioneer is going well out of their way to cripple the xx20 sets and push their already small potential customer base towards the Elites. Yet, Europe gets to retain the adustable settings. Wtf.....???
RobertR1 is online now
post #351 of 15046 Old 06-05-2008, 08:45 AM
gm1
gm1's Avatar
Basically, the color temperature is how the greyscale looks. If you had a test pattern with boxes that went from black to white in steps with shades of grey in between they will look correct if the color temp is correct. If the color temp is too cool (Blue) then the pattern will look like it has a blue tint to it. If the color is too warm(Red) then the whole pattern will look like it is tinted Red. If the color temp is correct then white will look white and not bluish or redish. When the color temp is not right then it throws off the look of all of the colors and white and black also.
Many tv's allow you to chose which color temp setting you want to use (including last years Pioneer's). Usually the warm setting is closest to being correct but some people choose one of the other settings because it can make the whites look brighter (but less accurate).
Once D-Nice evaluates the new Kuro he will be able to tell us what settings the tv uses and how accurate they are.
gm1 is offline
post #352 of 15046 Old 06-05-2008, 09:13 AM
RobbazZ's Avatar
In sweden we only get the elite modells but they dont call it elite or non elite. We get two modells an call them X090/X090H and the differents will be hd tuners and DLNA streaming only in the more expensive tv ( H modell ). ( maby a "pure" mode in settings but that is not sure yet) i have a pre order at the little more expensive modell and i hope i get it in 19-20 june or something.
but its more expensive in Sweden i think. if i translate it to dollars i will pay 5500 dollar for a 50 inch ( 5090H )
RobbazZ is offline
post #353 of 15046 Old 06-05-2008, 09:14 AM
E-A-G-L-E-S's Avatar
Wow, just when I thought the biggest drawback couldn't get worse.
That is one fugly remote and WAY too long.
E-A-G-L-E-S is offline
post #354 of 15046 Old 06-05-2008, 09:23 AM
kkgsxr's Avatar
This sounds similar to what car companies due in the US.
Toyota -- Lexus
Honda -- Acura
non-Elite -- Elite
I have an Acura and it has a honda engine, .1 liter larger than the honda accord. It is almost the same car just with a few more bells and whistles. I can be driving the poor mans honda, I need to have car one level higher (status thing). I am joking but that is how seems to be in the US. In other countries they don't have the same manufacturer using different names for cars, maybe that is why Pioneer only sells one version.
-kkgsxr
kkgsxr is offline
post #355 of 15046 Old 06-05-2008, 09:23 AM
kkgsxr's Avatar
Yes it is, I use my harmony 890.
kkgsxr is offline
post #356 of 15046 Old 06-05-2008, 09:25 AM
edpowers's Avatar
Quoted: 24 Post(s)
Liked: 32
£2400 for a 5090 in UK is considered a good deal. That's $4600 US. There is no equivalent 5020 model in Europe and they are paying US Elite prices for the 5090.
edpowers is offline
post #357 of 15046 Old 06-05-2008, 09:36 AM
RobbazZ's Avatar
Yes in sweden we pay more than they in UK
Sweden : 5090 = 5000 dollar and 5090H = 5500 Dollar
RobbazZ is offline
post #358 of 15046 Old 06-05-2008, 09:39 AM
tn2005's Avatar
D-nice, do you or your contact know how to get into the 6020's service menu?
tn2005 is offline
post #359 of 15046 Old 06-05-2008, 10:06 AM
xb1032's Avatar
Liked: 26
I fully agree. Most TVs in the $200 range have this option!
i understand pioneer trying to differentiate their lines - but people that want a no frills tv are not going to buy a pio...
My guess is that Pioneer is trying to sucker, I mean persuade Pioneer fans to buy the Elite line if you want to tweak. Especially considering that the Pioneer's profit margin is likely much higher on the Elites.
xb1032 is offline
post #360 of 15046 Old 06-05-2008, 10:08 AM
Sucker isn't the right word because there is a performance difference. If there wasn't that would be applicable.
Pioneer , Pioneer Pdp 5020fd 50 Inch 1080p Kuro Plasma Hdtv , Pioneer Pdp 6020fd 60 Inch Class Kuro Plasma Hdtv
