The Official Pioneer 9G non-Elite KURO Owner's Discussion Thread - Page 501 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #15001 of 15032 Old 06-23-2014, 10:50 PM
makaveddie81's Avatar
Quoted: 336 Post(s)
Liked: 240
I have now created a program that allows the user to run commands on any of the below Kuro models:
101fd
141fd
500m
600m
111fd
151fd
5020
6020
Non-US model equivalents to the above
What does this mean? For starters, service menu access (by executing the proper commands) on any of the above models in one simple program.
Kuro Command Program
makaveddie81 is offline
post #15002 of 15032 Old 06-28-2014, 08:37 PM
yrly's Avatar
I bought a 5020, maybe 2 and a half years ago as old stock, it always had a slight buzz, but running it off a regulated power supply diminishes the noise to nearly nothing. A lot probably has to do with voltage and altitude. I feel lucky as ever to have gotten this set for $799 "new" though it was no longer current at the time. I hope those set aside for warranty one day get released for sale.
yrly is offline
post #15003 of 15032 Old 07-01-2014, 07:53 AM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
Clean power goes far with plasma PSU's and components in general - definitely.
Stu03 is offline
post #15004 of 15032 Old 07-01-2014, 11:00 PM
PBT
PBT's Avatar
Liked: 2
Originally Posted by gardear1 View Post
PLEASE HELP. after 11 months my 6020's digital tuner won't work and when i hit "tools" the menu won't come up. also when i hit "menu" all but the setup is greyed out reading "current status does not allow for selection or adjustment". if i unplug it for a while it all comes back for about a minute, then same thing. if i have it on the digital tuner any channel comes in, then the pic freezes with just audio, and then goes out reading "starting up". i did do the firmware upgrade when i bought the tv 11 months back. and i've searched this forum finding a just couple of the same problems but not saying what happened as a final solution. should i do the firmware update again? any help would be appreciated guys!
My 111FD has the exact same problem, except unplugging doesn't help. I probably did one firmware update a long time ago before the problem started, but since the TV still works, and I can access most settings I care about, I don't want to risk further trouble...unless someone has had this problem and a firmware update fixed it.
Any help or advice is greatly appreciated!
gardear1 likes this.
PBT is offline
post #15005 of 15032 Old 07-01-2014, 11:18 PM
gardear1's Avatar
Sorry to hear that man. If you're issue is like mine was, it's not a simple firmware fix. It was the main board. I had to send it away with some techs for it to be replaced. Since it was right at the end of Pioneer's Kuro run, it took about a month and a half to get the part, and have it installed. Fortunately I was in the final days of my warranty. So it was covered.
PBT likes this.
gardear1 is offline
post #15006 of 15032 Old 07-07-2014, 12:14 AM
PBT
PBT's Avatar
Liked: 2
Thanks for the quick reply gardear1! Good to know what you ended up having to do (though the fix required is bad news for an out of warranty person like me). I'm guessing a new main board or repair would be major $. I just hope that the set doesn't loose any more functionality.
If anyone else had and fixed this problem for not too much $$, I'd be interested to hear your story.
PBT is offline
post #15007 of 15032 Old 07-11-2014, 05:00 PM
Actionable Mango's Avatar
Quoted: 24 Post(s)
Liked: 30
Originally Posted by turbe View Post
It had been updated for April Tours.. when D-Nice provides his location and dates, it gets updated..
Not all tours have appointment slots open so those dates don't get posted...
http://www.calibrationforums.com/for...ead.php?t=1026
Hi Turbe, might you know what's going on? It's been almost two months now. I've sent an email requesting a spot on the Seattle trip, whenever that might be, but haven't received any response.
I know he's a busy guy, and plans change, but I will hate myself if he does a Seattle trip after all these years and I miss it.
Actionable Mango is offline
post #15008 of 15032 Old 07-12-2014, 10:05 AM
turbe's Avatar
Quoted: 13 Post(s)
Liked: 94
I have not received any updates.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #15009 of 15032 Old 01-02-2015, 03:22 PM
Quoted: 18 Post(s)
Liked: 2
Hi everyone, what are your thoughts on a 5k hour, ISF Calibrated 6020FD for $900 to replace a TH50PHD8UK in non light controlled (though no direct light) family room using DirecTV / Chromecast as primary sources?
Kevin Barcellos is offline
post #15010 of 15032 Old 01-03-2015, 02:28 PM
Dreassic's Avatar
For some strange reason my LX5090H in combination with an Intel NUC seems to exhibit some strange issue.
Using Video HDMI mode and dot by dot set, the Intel GPU or TV seems to constantly adjust "overscan".
Switch between a program or a browser you can see sides gettign cut off at varying intervals. Sometimes bottom side drops out of view,
other times it's the top or the left side. Can't tell what is causing this.
Dreassic is offline
post #15011 of 15032 Old 01-04-2015, 05:18 PM
pier0188's Avatar
Does anybody have external speakers hooked up to their Kuro? I have a 6020FD and a couple spare Infinity Overture 1s and was thinking of hooking them up for sound a little better than the bar. Thinking about getting sonos (wife factor) but I am not decided yet and this would be a decent upgrade in the interim? Would this damage the TV in any way? Speakers? From what I could see the speakers are rated 10-100, looks like the Kuro puts out 18. Overtures seem to be 8 but Pioneer is 6 ohms, is that ok? Any help would be appreciated.
Shawn
pier0188 is offline
post #15012 of 15032 Old 01-05-2015, 12:03 AM
six172's Avatar
Quoted: 14 Post(s)
Shawn
I don't have external speakers, I'm using a Vizio soundbar right now and it works great. It also is a pretty close match to my 5020 soundbar, looks wise. As far as using external speakers using the 6020 internal amplifier, you should be okay. It's not ideal to have unmatched impedance but it's better to have the amp lower and the speakers higher,which you do.
Sent from my Xperia Z3v
six172 is offline
post #15013 of 15032 Old 01-20-2015, 08:18 AM
gorman42's Avatar
Anybody with a link for LX-6090's service manual? It should be ARP3482 order part...
Seriously. AVS is a place where you go to learn to be unhappy. - Bear5k
gorman42 is offline
post #15014 of 15032 Old 01-27-2015, 01:33 PM
Quoted: 18 Post(s)
Liked: 2
On my new to me 6020 playing 2.35:1 1080p content (MP4 format) via the Media Gallery player results in vertically stretched content that eliminates the letter bars as if I was in Wide mode - cycling through the different aspect ratios via the remote doesn't affect change the aspect ratio on the screen at all. Am I missing a setting someplace?
post #15015 of 15032 Old 01-27-2015, 03:46 PM
saprano's Avatar
Quoted: 434 Post(s)
Liked: 419
Check the setup options that the burn in protection function is not on.
home theater addict
saprano is offline
post #15016 of 15032 Old 02-04-2015, 02:08 PM
davethestalker's Avatar
Quoted: 48 Post(s)
My 2008 5020 is starting to show its age with by not handling bright & dark contrast very well and lip sync with BluRay or DVD has always had to be slightly adjusted, now it needs about 100ms. Many games have a brightness adjustment which is adjusted until you see an image in a dark box, such as GTA5 on PS4. However, DriveClub on PS4 is unplayable with dusk, dawn, very cloudy, and scenes where the sky is super bright with a low sun. The track is dark and practically not visible. When I share my clips to Facebook and watch them on my iPhone, it looks like I'm driving drunk and the track is clearly visible. When playing GT6, text within a bright background is difficult to see with the contrast issue.
The movie Godzilla was practically unwatchable, as it has a lot of dark scenes. The long final battle scene, we couldn't see a thing. My son has a Samsung LCD and he doesn't suffer with the same contrast problems, even though his is a lowly 46" 60hz basic TV.
I used to use Movie mode with the settings from this thread, it just looked too muddy. Especially watching night baseball games compared to real life, backgrounds were just too dark and colors did not look natural. So I switched to Optimized mode. I've been happy with that for the last few years.
I've tried using Game mode and that doesn't really change how the TV handles contrasts, it just burns my eyes. DYNAMIC mode has never been used on my TVs.
What's wrong with my precious KURO! Is there anything I can do to repair this? How much would it cost to typically fix this issue?
My other choice is to upgrade in size (60 or 65) and to a modern LED 4K TV and put this one in the living room for my wife to enjoy.
davethestalker is offline
post #15017 of 15032 Old 02-06-2015, 12:21 AM
jd17's Avatar
Hey guys...
unfortunately my KURO (European LX5090H) showed first signs of an issue a couple of days ago.
I was just watching some stuff when suddently weird vertical stripes appeared on the whole screen. They were kind oft green/yellow/reddish bright. I first switched from HDMI to SAT but the stripes didn't vanish.
Then I turned the TV off, unplugged it, plugged it back in and turned it on again. I have not seen the stripes since then.
Does anyone know this issue? I could not find much info on this in the web...
Is my TV gonna die soon? Is there a reasonably priced way to fix it?
jd17 is offline
post #15018 of 15032 Old 02-07-2015, 12:14 PM
AVS Club Gold
htwaits's Avatar
Quoted: 331 Post(s)
Liked: 888
How about a good quality professional calibration?
htwaits is online now
post #15019 of 15032 Old 12-12-2015, 05:52 AM
Invader3's Avatar
Quoted: 43 Post(s)
So after 6+ years of great service, my 50" Kuro (non-Elite) suddenly seems to have no power! It was working fine yesterday, great picture, etc...then this morning, it won't turn on, and the red standby light is not lit up. I tried unplugging and plugging back in, and that did nothing. Is there anything I can do, or has my Kuro met its demise?
Edit: Nevermind...we had a babysitter last night, and I think in process of turning off the TV, the main power switch on the bottom left of the TV was somehow bumped. Glad a Google search reminded me it was there! TV is still working, disaster averted!
Invader3 is offline
post #15020 of 15032 Old 01-08-2016, 07:43 PM
AVS Club Gold
htwaits's Avatar
Quoted: 331 Post(s)
Liked: 888
The dreaded manual power switch strikes again.
Enjoy.
EscapeVelocity likes this.
post #15021 of 15032 Old 01-10-2016, 01:46 PM
saprano's Avatar
Quoted: 434 Post(s)
Liked: 419
How can the power switch be accidentally turned off? It's on the bottom.
home theater addict
saprano is offline
post #15022 of 15032 Old 01-11-2016, 02:29 PM
AVS Club Gold
htwaits's Avatar
Quoted: 331 Post(s)
Liked: 888
It happens a lot more than it should. Dusting is how it's happened in our house.
post #15023 of 15032 Old 01-15-2016, 07:14 AM
needlesbox's Avatar
Crackling Sound
Kuro Owner since May 09 here-
Last weekend mine started to make a crackling sound across the entire back of the unit-
I have a tech look at it today and he said the sound was "discharge from the panel and the whole panel would need to be replaced"....
Has anyone else had this issue and is there a solution other than what this gentleman suggested?
needlesbox is offline
post #15024 of 15032 Old 02-14-2016, 02:35 PM
wozman's Avatar
Quoted: 16 Post(s)
Pioneer 5020FD owner here, since 2009. The picture quality still kicks anything out there on the market today. Hell its even better then my 2013 Panasonic ST60, which is the closest competitor. Hence why I am trying to save it. Its beginning to go thru the 8 blue flashes syndrome.
I have all my devices plugged into my Pioneer Receiver (VSX-1326-K) (Rogers HD Cable Box) (Panasonic Blu-Ray Player) (HTPC) (PS4) (PS3) then an HDMI out to the Pioneer panel, and it usually flickers off when I am changing inputs. Watching regular TV thru my Rogers box usually isn't an issue, however trying to fire up the other devices triggers the 8 blue flashes shut down. Where I have to unplug the TV physically and reconnect wait a few minutes and then turn on.
Now I have already been down the google search path, youtube, and the blue flash thread in this forum. Had a local repair guy come on site, and replace the transistor on the board?. This has all been done, however I am still experiencing the same symptoms. So maddening cause I love my Pioneer and don't want to kick it to the curb. Any idea out there what else it can be? someone at a audio visual store yesterday told me that it needs a full new board. He called it a "tange" board. Or maybe I was misinterpreted the pronunciation. He says that he did the following for his Kuro. Now the gentleman that tried to repair it first with the replacement kit off of ebay, is supposed to come over again this week to diagnose it some more. But I am just about at a loss of words.
Can anyone save me here, any ideas out there.....don't want to put my Pioneer Plasma 5020 to the curb, just yet. I am willing to spend $300-$500 for repair, but after that its pushing it.
Display#1: Pioneer Kuro Plasma PDP-5020FD (Living RM)
Display#2: Panasonic Plasma TC-P55ST60 (Rec-RM)
Receiver: Pioneer VSX-1326-k (Living RM) & Pioneer Elite SC-95 (Rec-RM)
Speakers: Bose 6 Series III (LivingRM) & Pioneer SP-FS52 (L&R) SP-C22 (Center) SP-BS22A (L&R Rear Atmos Ready)
Sources: Panasonic BDT360 -- Sony BDP-S350 -- PS3 & PS4 -- HTPC
wozman is offline
post #15025 of 15032 Old 02-15-2016, 12:10 PM
saprano's Avatar
Quoted: 434 Post(s)
Liked: 419
I don't think you need a full board. It's probably the power supply.
home theater addict
saprano is offline
post #15026 of 15032 Old 02-15-2016, 02:12 PM
Quoted: 336 Post(s)
Liked: 240
It's either the audio board or the main board. Save yourself some serious money and time and just send your audio and main boards to ebay member kcrownie. Not only will he fix the 8 blink issue, but he can also convert the audio board to an Elite audio board, unlocking Elite only calibration controls and the Pure picture mode on your non Elite model.
http://www.ebay.com/itm/Repair-Servi...kAAOSwewJTmuWG
wozman likes this.
post #15027 of 15032 Old 02-16-2016, 12:39 AM
Clint S.'s Avatar
Quoted: 41 Post(s)
Liked: 0
What exactly is involved in doing this repair and mods, is there a webpage somewhere that details them? I don't have the issue......yet, but I'd like to look into the mods. Thanks.
God Bless,
-Clint
Clint S. is offline
post #15028 of 15032 Old 02-16-2016, 11:32 AM
Quoted: 336 Post(s)
Liked: 240
For the audio board repair, he replaces a resistor. Not sure what he does with the main board and audio board Elite conversion.
post #15029 of 15032 Old 02-16-2016, 01:37 PM
wozman's Avatar
Quoted: 16 Post(s)
Thanks for the link,
$70 US seems like nothing for me, if this fixes my issues, since the guy I got locally (repair guy) ordered me a transistor replacement piece (similar to the popular youtube clip you see about the 8 flashes) and was going to charge me $300. I didn't end up paying him as it never fixed the problem. We are still diagnosing the issue. I don't use the audio speakers on the Pioneer Kuro (have a receiver surround sound) would you still recommend sending in the audio board too? Being from Canada is there any issues in shipping the boards to him. Guess I would have to pay duty etc.
I assume you have tried the following? how was the turnaround time......and the service?
wozman is offline
post #15030 of 15032 Old 02-16-2016, 02:05 PM
Quoted: 336 Post(s)
Liked: 240
Even if you don't use the speakers, the audio board is still a likely culprit. Plus, unlocking the Elite features via the audio board mod will breathe new life into your set. The non Elite sets were crippled with regards to calibration and although the grey scale can be calibrated via the service menu, gamma and other features (including color space) are locked down.
Gamma on the non Elites is locked between 2.0 and 2.1, while the colors are way off since it's locked on color space 1. I can definitely tell the difference between my 5020's and Elite sets and its mainly because of gamma and colors.
I haven't used the guy's service yet but know of people who did and recommended others to do the same. Turn around time was around a week total.
Pioneer , Pioneer Pdp 5020fd 50 Inch 1080p Kuro Plasma Hdtv , Pioneer Pdp 6020fd 60 Inch Class Kuro Plasma Hdtv
taboola here
