The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 1018 - AVS Forum | Home Theater Discussions And Reviews
 204Likes
post #30511 of 31813 Old 07-26-2014, 08:20 AM
gunhed's Avatar
Quoted: 22 Post(s)
Hi guys,
I know this has probably been covered before here but does anyone know exactly why a Kuro can increase it's light output in the ISF modes as opposed to the default modes you get with the set ?
Does unlocking the ISF modes somehow increase the ABL threshold in those modes or something like that ?
Also does simply unlocking the ISF modes allow increased light output in those modes or do you actually have to calibrate the ISF modes after unlocking ? Like can calibrate my lumagen and send the signal thru the Kuro ISF day mode to get a bright calibrated picture ?
gunhed is offline
post #30512 of 31813 Old 07-26-2014, 11:38 PM
Liked: 0
Hoping maybe I can find some advice in this thread before I chuck my recently acquired pro-111. This was sold to me buy my parents as I've always wanted the gold standard. Problem is it's got the dreaded buzz, and it's bothersome to the point where I can't really focus on watching the set unless the volume is turned up ridiculously high. I have placed power save on mode 2 with a marginal improvement. From all the research I have done, replacing the power supply may fix it, at 400$ it's not cheap. What do you all feel is my best option? Should I just get rid of it?
Pqbrown is offline
post #30513 of 31813 Old 07-27-2014, 01:23 AM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
Were you aware of how "bad" the buzz was when the set was at your parent's home?
A power supply can malfunction and make noise. Plasma technology can cause a buzz that varies from set to set. To get advise you need to know which situation you're dealing with.
If you are hearing a plasma buzz, the the difference in room characteristics between your parents viewing room and yours may be contributing to your perception of the problem.
I think your display is worth repairing if you're sure that it's the power supply.
htwaits is offline
post #30514 of 31813 Old 07-27-2014, 04:38 AM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
Originally Posted by Powers16 View Post
30ms is definitely good for me! But the gaming mode doesn't look a whole lot worse than the other picture modes right? That's the case on my ST50 right now. Sorry for all the questions by the way, I'm just very thorough in researching tv's that I'm considering buying
30ms is just one measured number.
People with appropriate measuring equipment have measured Kuro's with far lower response times than that.
It is also very system and set up dependent.
:thumbup:
Stu03 is offline
post #30515 of 31813 Old 07-27-2014, 07:18 AM
Liked: 0
I did not notice the buzz, but the positioning is quite different (it's mounted on the wall now, it was off the wall a ways and on a stand there). I have an 8g 6010 and an 8g panny and while they do buzz, it's not nearly as pronounced as it is on this set. Is there a way to test the power supply to tell if this is the issue? I absolutely love the set, and the pq is outstanding, so I'd really hate to give up on it.
Pqbrown is offline
post #30516 of 31813 Old 07-27-2014, 02:04 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
I'm not a service tech, but as I understand it, a power supply going bad will make noise that can be traced to the power supply card and it's best heard from the back of the set.
I have a 6010 and I could hear it buzz the day it was mounted over six and a half years ago. The buzz was coming from the entire surface of the screen, and my head was within inches of the screen. I've never put my head that close to the screen since day one.
From your description, it sounds like your room is causing a different experience that you were used to at your parents home. Your focus is probably different too. If it's plasma technology buzzing that your are hearing, those two areas are your best chance to solve your problem.
For instance, our viewing room is very soft so we don't have audio bouncing off of a lot of hard surfaces. Your parents may have an acoustically soft room, and your may have a room with a lot of reflecting surfaces.
Good luck.
htwaits is offline
post #30517 of 31813 Old 07-27-2014, 04:57 PM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
Well I bought the Kuro 5020FD and like mentioned on here, it came with the 111FD board installed so I get all of the picture setting adjustments of the Elite . I've already tried to search this thread for picture settings but there are more like like 40 pages that mention calibration settings so i figured I would just ask. What are some really good picture settings for Pure Mode (I have CNET's settings as of now) and some really good settings for Game Mode?
Try these settings for all modes-
The Official Pioneer 9G Kuro Settings/Issues Thread
Here's another for pure - The Official Pioneer 9G Kuro Settings/Issues Thread
Stu03 likes this.
home theater addict
saprano is online now
post #30518 of 31813 Old 07-27-2014, 07:53 PM
Liked: 0
Good luck.
I think you are right about the environment. The rear of tv is where the noise is coming from, so it sounds like the power supply then. I'm not sure anyone could say the sound would be considered normal! I will see what my local shop thinks. Thanks for the input.
Pqbrown is offline
post #30519 of 31813 Old 07-28-2014, 07:24 AM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
Anybody find small blue dots and marks on their screen? If you go up close and let natural light shine on the screen you'll probably see them. I wonder if it's the heat from the glass affecting the CEL? I had cleaned a few of them off weeks ago and now they're starting to come back.
I'm going to try cleaning it again but this time I want to use distilled warter. Where can I get some?
home theater addict
post #30520 of 31813 Old 07-28-2014, 08:08 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
Any grocery store carries distilled water. I know Walmart does
rcapprotti is offline
post #30521 of 31813 Old 07-28-2014, 01:08 PM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
I'm going to try cleaning it again but this time I want to use distilled water. Where can I get some?
Grocery stores carry distilled water for steam irons. It's probably around $1.79 a gallon.
Be careful that you don't ruin or remove the filter applied to the screen. Use a micro fiber cloth and don't get the cloth any wetter than slightly damp.
Why are you worried about something that you probably can't see when you watch from a normal viewing distance?
htwaits is offline
post #30522 of 31813 Old 07-28-2014, 04:02 PM
dsskid's Avatar
Quoted: 268 Post(s)
Liked: 257
And if I might add.... Make sure the screen is cool prior to cleaning.
htwaits and rcapprotti like this.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #30523 of 31813 Old 07-28-2014, 06:49 PM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
Pardon my ignorance - and off topic i know - but when is the VE shootout this term ?
Stu03 is offline
post #30524 of 31813 Old 07-28-2014, 07:42 PM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
Yeah I still have the cloth that came with the TV. The filter will be fine I think, they're mostly small round marks in one area. I won't be cleaning the entire screen.
You don't notice anything unless you look for it in bright light yes, but since I know it's there it bothers me.
home theater addict
post #30525 of 31813 Old 07-28-2014, 07:49 PM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
August. Boring line up imo.
home theater addict
post #30526 of 31813 Old 07-29-2014, 09:39 PM
Powers16's Avatar
Quoted: 28 Post(s)
I have been trying desperately to update the firmware on my 5020FD with 111FD board. It currently has the 0901-0201 firmware and i'm trying to update it to the latest 0907-0401 firmware. I've followed the instructions on Pioneer's website and downloaded the firmware and extracted the file and placed the "Update" file onto a flash drive. I've been unhooked the power cord of the tv, placed the flash-drive into the USB slot, then plugged the power cord back into the tv. The TV just starts up and never begins the update. I've plugged the flash-drive in while the TV is on also and the TV recognizes that a flash-drive is plugged in and it pulls up the file on screen but I can't do anything with it, everything is grayed out. Am I doing something wrong?
Powers16 is offline
post #30527 of 31813 Old 07-30-2014, 12:50 AM
makaveddie81's Avatar
Quoted: 473 Post(s)
Liked: 273
Make sure its formatted using fat32 partition and do not have any contents on it except for the update file.
How big is the flash drive? Perhaps the Kuro doesnt recognize larger drives.
I used a usb dongle with an old 1gb sd card (not sdhc) inserted and the upgrade worked on the first try on my 151.
makaveddie81 is online now
post #30528 of 31813 Old 07-30-2014, 05:31 AM
Nickff's Avatar
Quoted: 281 Post(s)
Liked: 176
Do you use the internal tuner on the 5020FD?
Mathematics is the reason for the season.
Nickff is offline
post #30529 of 31813 Old 07-30-2014, 10:19 AM
Powers16's Avatar
Quoted: 28 Post(s)
I formatted the flash drive making it FAT32 and retried everything and it still didn't work.
Powers16 is offline
post #30530 of 31813 Old 07-30-2014, 03:18 PM
Quoted: 473 Post(s)
Liked: 273
What is the capacity of the flash drive?
I wonder if the fact that your display is a 5020 is a factor in the upgrade not working.
post #30531 of 31813 Old 07-30-2014, 09:48 PM
Edllguy's Avatar
Quoted: 122 Post(s)
Liked: 57
Follow this thread, especially post 320. All the best.
Official FW UPDATE for NA PDP-5020FD/6020FD, PRO-111FD/151FD (NO SIGNATURES!)
Edllguy is online now
post #30532 of 31813 Old 07-30-2014, 11:43 PM
Quoted: 473 Post(s)
Liked: 273
Yep. You need to use an old flash drive.
I used a usb dongle with an old 256mb sd (not sdhc) card.
post #30533 of 31813 Old 07-31-2014, 10:31 PM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
makaveddie, when you dropped RSTP to1 on your 600M did you change anything else? Or did you even need to for lower blacks? I'm not going to do it, i'm just wondering for future use in case my mll changes. The value is at 18 on my 151. If all i have to do is change that it would be great.
home theater addict
post #30534 of 31813 Old 08-01-2014, 01:31 AM
Quoted: 473 Post(s)
Liked: 273
I dropped it to 1 on my 101fd, 141fd and 151fd with no issues and a reduction in mll.
For a further reduction in mll, I also reduced s1, s3 and s4 (by the same amount) on all three panels. The 101fd was able to go down all the way to minimum values with no artifacts on content. The 141fd and 151fd were a bit more resistant, so i could only go down about 15 ticks without issues. Anything more than that and artifacts would manifest themselves on content.
post #30535 of 31813 Old 08-01-2014, 07:58 AM
qwknuf6's Avatar
Quoted: 132 Post(s)
Liked: 166
I found the same results with my 151 and both of my 101s
qwknuf6 is offline
post #30536 of 31813 Old 08-01-2014, 09:12 AM
Quoted: 473 Post(s)
Liked: 273
2 101s? Drool.
If Im not mistaken, your 151 is a 2009 build right? If so, double drool.
P.s. how is the pdk-1015 stand working out for you?
post #30537 of 31813 Old 08-01-2014, 10:29 AM
qwknuf6's Avatar
Quoted: 132 Post(s)
Liked: 166
2 101s? Drool.
2 101s
My 151 is a 2008 build ,
I have not used the 1015 stand yet , still in the box , got it just in case I need to take the work on the guts of the 151 .
qwknuf6 is offline
post #30538 of 31813 Old 08-01-2014, 10:38 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
If you don't mind me asking what is the difference between the 2008 build and 2009? Mine was built in February 2009 good or bad?
post #30539 of 31813 Old 08-01-2014, 10:40 AM
jmmesch's Avatar
My 151 is a 2009 build. It was sitting around Pioneer until early 2010 when I got it, to replace a dead warranty 150.
My favorite toy
jmmesch is offline
post #30540 of 31813 Old 08-01-2014, 10:53 AM
rcapprotti's Avatar
Quoted: 159 Post(s)
Liked: 126
Mine is a warranty replacement two.I actually had a 6020 the first 6020 they sent the panel was crushed on it the second one they sent me after about two months developed several problems. And then had a build date of April 2009. When they replaced the second 6020 I had to pay them a little extra was less than $400 to upgrade to a 151 and so far no problems with this one knock on wood. Like I said this one has a build date of February 2009
Pioneer Elite , Plasma Hdtv , Pioneer Elite 50 Inch Elite Plasma Hdtv Pro111fd
