The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 1021 - AVS Forum | Home Theater Discussions And Reviews
 221Likes
post #30601 of 31943 Old 08-15-2014, 02:48 PM
porschetech's Avatar
Quoted: 43 Post(s)
Originally Posted by Audio Karma View Post
Yes, that's right, it should be working for you. After you push down on the Display Info button for 10 seconds, your not still holding down that button when you push on the Home Menu button, are you ?
I tried a couple of ways and nothing has appeared to have worked
porschetech is offline
post #30602 of 31943 Old 08-15-2014, 02:52 PM
Audio Karma's Avatar
Location: Living On A MAGIC Roller Coaster Ride In My Room With My Tweaked out Stereo System !....
Quoted: 85 Post(s)
Originally Posted by porschetech View Post
Yeah 3rd row down. Display button which is beside av selection button. Then home menu button, which all i see are my regular settings on the menu screen
Maybe with the Elite models, they use a different way of entering the Integrator Menu. If you have your Pioneer Manual you can see how you open the Integrator Menu there or just call pioneer...
Audio Karma is offline
post #30603 of 31943 Old 08-15-2014, 03:05 PM
Quoted: 85 Post(s)
Every time I try it, it works for me...after you hold down the Display Info button for 10 seconds then try pushing down hard on the Home Menu and see if it works then.... Keep pushing on the Home Menu button until the Integrator Menu comes on...
post #30604 of 31943 Old 08-15-2014, 03:22 PM
makaveddie81's Avatar
Quoted: 498 Post(s)
Liked: 277
Originally Posted by -Hitman- View Post
List all your current settings and i'll take a look for you, Con 27 is low for a day setting, I go for the max peak on mine for daytime
Sorry, I meant 37.
AV Selection: ISF-Day
Contrast: 37
Brightness: 1
Color: +4
Tint: 0
Sharpness: -15
Pure Cinema: 2 (Advance)
Black Level: 0 (Off)
CTI: 0 (Off)
Color Space: 2
Color Temp: 6 (Manual)
ACL: 0 (Off)
3DYC: 2 (Mid)
I-P Mode: 2
Text Optimization: 0 (Off)
Intelligent Mode: 0 (Off)
DRE Picture: 0 (Off)
Enhancer Mode: 1
Block NR: 0 (Off)
3DNR: 0 (Off)
Field NR: 0 (Off)
Mosquito NR: 0 (Off)
Power Save Mode: Off
Orbiter: Mode 2
RGB Controls
R High: -9
G High: 0
B High: +2
R Low: 0
G Low: 0
B Low: +1
Color Management
R: 0
Y: 0
G: 0
C: 0
B: 0
M: 0
Gamma
10%R 0
10%G 0
10%B 0
20%R 0
20%G 0
20%B 0
30%R 0
30%G 0
30%B 0
40%R 0
40%G 0
40%B 0
50%R 0
50%G 0
50%B 0
60%R 0
60%G 0
60%B 0
70%R 0
70%G 0
70%B 0
80%R 0
80%G 0
80%B 0
90%R 0
90%G 0
90%B 0
In order to get points 50 through 90 remotely close to 2.23, I had to set them to the -3 to -5 range.
makaveddie81 is online now
post #30605 of 31943 Old 08-15-2014, 03:23 PM
Quoted: 498 Post(s)
Liked: 277
You need to hit the menu button twice after holding info button for 5 seconds.
hold info button for 5 seconds
release info button
tap and release home button 2 times
post #30606 of 31943 Old 08-15-2014, 07:24 PM
Tacklebary's Avatar
Gentlemen
Does anyone have any idea of the last month and year that Pioneer produced there units? Curious as I have a model manufactured in April of 2009.
Thanks for your assistance.
Tacklebary is offline
post #30607 of 31943 Old 08-16-2014, 05:07 AM
-Hitman-'s Avatar
Quoted: 152 Post(s)
Liked: 113
Originally Posted by makaveddie81 View Post
Sorry, I meant 37.
Ok,
First thing is I assume you are using a Display 3/pro with Calman5?
What's your video source make model, is this direct or through an AVR and what patterns are being used?
Are you using one of the included spectral sample offsets included with the D3 for "Plasma", the offset is created using a Minolta cs1000 and you need to use this offset with your plasma, d3 on it's own will be off.
You also maybe doing too much to try for 2.23, your kuro tracks better with 2.2 and may need external help otherwise, keep 10pt gamma at 0 as you have done so but if you must change gamma don't go past max +-3 and have all the RGB's and gamma points exactly the same, I have only ever gone - 1 to level gamma a bit for a low peak night mode, day mode is set all @0 and I prefer day mode all the time.
Con 37 may be well on the limit of your display, so my recommendation is to run full greyscale measures and check gamma line with cont @35/36/37 and check for color run out at 90/100%!
You should get a relatively flat gamma line @2.2 without any gamma adjustment.
See how you get on with that.
ConnecTEDDD likes this.
-Hitman- is offline
post #30608 of 31943 Old 08-16-2014, 12:17 PM
Quoted: 498 Post(s)
Liked: 277
Ok,
Yes Im using a D3 / Calman combination, though the gamma drop is also captured by HCFR.
I do select Plasma in Calman, but not sure how to select the offset that you mention. Can you walk me through that?
Also, can you provide the meter settings (exposure time, low light handler, sync mode, etc) that you use? Have a feeling I have set one of these incorrectly.
Is it normal to get significantly different greyscale readings between Calman and HCFR? I dont know which one is giving me more accurate readings. For some odd reason, Calman is givign me false black level reading. For instance, it consistently measures my brothers VT60 at .0006, when we all know that the lowest that panel (and my d3) can go is .001. HCFR gives me an accurate .001 reading when measuring the VT60. For this reason, Ive been doing greyscale with HCFR and color with Calman.
post #30609 of 31943 Old 08-16-2014, 05:10 PM
Quoted: 43 Post(s)
Ok I've tried both examples here and to no avail
post #30610 of 31943 Old 08-17-2014, 12:15 AM
lnarbi's Avatar
Quoted: 222 Post(s)
Liked: 68
Originally Posted by lnarbi View Post
It works only on the monitors (maybe the 101 too), but not on the other ones.
On European models at least, and I have no control other the FANs in integrator menu, only RS232 settings (accessed after pressing home when TV is in standby for some seconds and then turning it on).
Tried this one ?
lnarbi is offline
post #30611 of 31943 Old 08-17-2014, 11:04 AM
Quoted: 85 Post(s)
I can't find anything on the net about this, on your Elite model, so your have to call Pioneer on Monday 800-421-1404
post #30612 of 31943 Old 08-17-2014, 11:16 AM
turbe's Avatar
Liked: 97
I'm trying to calibrate the ISF day mode (using D-Nice's ISF Day settings as a starting point) on my 101fd and am experiencing a steep drop in gamma from 50 IRE and up. Gamma on ISF-Night mode is straight 2.23 on all points. Is there a specific setting that I am missing on the ISF Day mode?
Contrast is set to 27, brightness to +1 and all other settings match D-Nice's settings.
Though I can't find the post(s) right now, I seem to remember you are using GetGray for your patterns, is that still correct?
Please list your current pattern source and player model (if applicable).
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #30613 of 31943 Old 08-17-2014, 11:26 AM
Quoted: 498 Post(s)
Liked: 277
I use getgray for brightness and contrast only. For grayscale and colors, I use avshd709. My current source device is a playstation 3.
Gamma on isf night mode is a straight line around 2.22, while gamma on isf day takes a dip at 50 ire, with the lowest point of the dip (1.8) being at the 90 ire point.
post #30614 of 31943 Old 08-17-2014, 11:41 AM
turbe's Avatar
Liked: 97
it shouldn't be that far off for contrast up to 39/40 but I've seen a reports similar from units with various sm adjustments.. day/brighter than reference is always a compromise but on these models should still be better.
I would also use AVS HD 709 for Contrast and Brightness..
I'd recheck the power / energy saving setting (it's labeled Standard for off).
Lastly, I would Input RGB (16-235 of course) on your 9G Kuro (that would need to be changed in the PS3 and best to force that in the Kuro Monitor).
ControlCAL™
turbe is offline
post #30615 of 31943 Old 08-17-2014, 04:13 PM
rcapprotti's Avatar
Quoted: 187 Post(s)
Liked: 135
You have to use a service remote on your 111fd
rcapprotti is offline
post #30616 of 31943 Old 08-17-2014, 05:25 PM
Liked: 0
Any ideas on where I might be able to find a stand for a PRO-940HD model? I've scoured eBay with no luck. Didn't know if anyone had any recommendations on other sites or places to look.
CaptainColdCrush is offline
post #30617 of 31943 Old 08-18-2014, 12:17 AM
Powers16's Avatar
Quoted: 28 Post(s)
Anyone know why I cant make more bars to show up when adjusting the contrast in either ISF mode? I currently have the contrast in Night mode set to 23 and the contrast in Day mode set to 35 but i've noticed that it really doesnt matter contrast setting, the whites clip around 236. I can turn down the contrast on my BD player and mostly fix it but i really would like to avoid having to do that. My blacks were also getting crushed with my brightness setting at 0 (all gamma values were set to 1). So i ended up having to raise the brightness to 1. Raising it to 1 almost raises it too much though, making the "reference black" a little too light on the AVSHD calibration disc
Powers16 is offline
post #30618 of 31943 Old 08-18-2014, 01:22 AM
-Hitman-'s Avatar
Quoted: 152 Post(s)
Liked: 113
Not sure about adding the EDR offset matrix as I profile with an i1pro, so never done it, you will have to research how to do it, calman does have it's own plasma setting as you have used and I have seen that HCFR will do it with Argyll.
I would stick with 1 disk (AVSHD709) and same software and not switch between them, I also have found Calman to be cumbersome sometimes.
LLH low settings are not really necessary for the D3 but more for an i1pro but can enhance the low end a bit, play with the settings to see what benefit it brings if any.
Sync mode needs to be on, however I have found that sometimes Calman cannot obtain a reading, so then use auto if this occurs and exposure time increase can also help but will increase calibration time as it will take more measurements.
You should get similar readings from both HCFR and Calman when you get Calman and your display to stabilise when you can start getting your black level read properly using the above, I would use HCFR for all until you get things level then verify with Calman.
-Hitman- is offline
post #30619 of 31943 Old 08-18-2014, 01:26 AM
-Hitman-'s Avatar
Quoted: 152 Post(s)
Liked: 113
That's normal for the G9, you can however use DRE lowest setting which will give an increase, however I don't use nor is it recommended to use DRE for accuracy purposes and any information past 235 is not common anyway, some games may go slightly past 235.
Brightness is usually 0 or +1, yours looks like +1 is correct.
-Hitman- is offline
post #30620 of 31943 Old 08-20-2014, 10:23 AM
Quoted: 85 Post(s)
Did you get your fans turned onto MAX yet?
post #30621 of 31943 Old 08-20-2014, 08:16 PM
Quoted: 43 Post(s)
Nah not yet. I can't access anything more than the normal home menu
What did rcapp mean about a service remote? While I'm here if my tv does take a sh1t. Should I look for another 111fd or consider a 151, 141 or 600m?
post #30622 of 31943 Old 08-20-2014, 11:09 PM
Liked: 0
Looking for some info
I have a Pro111FD - it's having power issues that I do not see talked about elsewhere...
Built April 2009 (is that late? is that a bonus?)
Unit powers off at random times, usually after being on for an hour or two. No led lights at all. Unplugging for 10 minutes usually gets me up and running again. Heat could definitely be an issue, so my plan is to clean the fans tomorrow. Any thoughts?
A pioneer rep gave me a Datacolor ISFccc Toolkit. Is this a good method of calibrating this TV? Supposed to only be for Pioneer Elite TV's... I have 2 151's also, not sure of the dates at the moment... (all deals through Pioneer...)
All your help is appreciated
Coshesey is offline
post #30623 of 31943 Old 08-22-2014, 06:04 AM
Quoted: 85 Post(s)
I would look for a used 600M or 500M....
post #30624 of 31943 Old 08-24-2014, 03:46 AM
8mile13's Avatar
Quoted: 1703 Post(s)
Liked: 989
I bought a european 500M. Can someone tell me which menu settings i should use for blu-ray till it gets pro-calibrated?
8mile13 is online now
post #30625 of 31943 Old 08-24-2014, 03:50 AM
Nickff's Avatar
Quoted: 346 Post(s)
Liked: 221
Just use Pure until it is calibrated.
Nickff is offline
post #30626 of 31943 Old 08-27-2014, 06:37 PM
Liked: 0
A curiosity:
I programmed my 111FD kuro remote to address the Apple TV on the DVR mode setting but it also works when on the TV / Receiver setting! I couldn't duplicate it if I tried- in fact- the buttons controlling it are technically non programmable! (The circle, select, back). The only problem is that the back button is for some reason a double press, which I have no way of fixing since they shouldn't have had any way of reprogramming themselves anyway.
Any idea as to what this is about?
Two other questions:
How do you guys with a dish receiver /DVR program your kuro remotes when the remote splits the necessary programmable buttons across the Sat and DVR modes?
And...
In TV / RCV mode, how can I get the Source Power to power on the BluRay 23fd? It doesn't seem programmable and the red light doesn't even light, but the rest of the controls there all control the BluRay player through HDMI control! (Play pause stop etc).
Ilbisonte is offline
post #30627 of 31943 Old 08-28-2014, 03:38 AM
Nickff's Avatar
Quoted: 346 Post(s)
Liked: 221
Originally Posted by Ilbisonte View Post
A curiosity:
And...
Have you considered a Harmony remote?
Nickff is offline
post #30628 of 31943 Old 08-29-2014, 01:54 PM
Liked: 0
I used to have their touch screen 1000. I wasn't so convinced. The Kuro remote is great and on paper is supposed to do everything I need.
post #30629 of 31943 Old 08-30-2014, 05:18 AM
Nickff's Avatar
Quoted: 346 Post(s)
Liked: 221
Their touch screen and remotes that use rechargeable batteries are not worth it in my opinion. However, the 620 and 670 are amazing.
Nickff is offline
post #30630 of 31943 Old 08-30-2014, 06:07 AM
[Irishman]'s Avatar
Quoted: 176 Post(s)
Liked: 121
D-Nice posted some offsets for various tweaks to 9G and 9.5G kuro models in this thread I think, back in late '08, or early '09.
They may not be for your device, but you might find some benefit (I did).
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
Pioneer Elite , Plasma Hdtv , Pioneer Elite 50 Inch Elite Plasma Hdtv Pro111fd
