The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 1024 - AVS Forum
post #30691 of 30691 Old Yesterday, 12:51 PM
[Irishman]'s Avatar
Quoted: 54 Post(s)
Liked: 63
Originally Posted by 34HFX83 View Post
This may sound dumb, but what should I use to detect persistent IR and dead pixels?
What do you use for IR and dead/stuck pixels?
There's no fast tool that I know of other than the ole Oculon Mark One!! Your eyeball should suffice for that.
Someone might be able to recommend some break-in slides that you could load up on an USB stick. The slides usually have monochromatic slides that rotate in playback on the display. Usually people use them for doing a fast and dirty break-in of a TV, but in this case, I don't see why it couldn't work for you. Instead of watching content on the screen and searching for the needle in a haystack, you would use these monochrome slides to ease the process of finding any dead pixels.
I'm not sure where the best places are to find break-in slide files.
Maybe the AVS brain trust might know.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
Pioneer Elite , Plasma Hdtv , Pioneer Elite 50 Inch Elite Plasma Hdtv Pro111fd
