The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 1039 - AVS Forum | Home Theater Discussions And Reviews
post #31141 of 31146 Old 08-30-2015, 08:26 PM
Edllguy's Avatar
Quoted: 67 Post(s)
Liked: 33
Originally Posted by Qpon View Post
It's been ages since I posted here, but over the past couple of months, I've noticed a strange problem with my 101FD. When I first turn it on, regardless of what's on the screen, it makes a loud, high-pitched whine from the back of the unit that I can hear from other side of the room. It slowly quiets down after a good while, but one thing that remains constant is pretty nasty buzzing that I'm not sure was there or was as bad before. I've also noticed that the tv gets a bit hotter than it used to. I've had no other issues with the set other than this. I could just be a little paranoid, but any help would be much appreciated.
Could be the power supply board. I hope you find a solution. The 101FD is a great panel and IMO would be worth fixing.
Edllguy is online now
post #31142 of 31146 Old 08-30-2015, 08:31 PM
Qpon's Avatar
I'm worried that if it is something like the power supply, that it's going to cost a fortune in order to get it fixed.
Qpon is offline
post #31143 of 31146 Old Yesterday, 04:03 PM
Edllguy's Avatar
Quoted: 67 Post(s)
Liked: 33
I believe that it comes down to 2 options.
Option A. Verify that it is the power supply board that is failing and find a used power supply board and install it yourself or by a knowledgeable friend.
Option B. Find 1 or 2 reputable Pioneer plasma service centres and get them to diagnose and quote you a price (parts and labour) and go with the lowest quote.
Note: This is why I purchased a used power supply board for my Pro-111FD online a couple of years ago just in case mine goes bad. However, my Kuro was manufactured in January 2009 pre press release of Pioneers exit from the flat panel business (February 2009), and sometimes I speculate that is why my Kuro is still alive after much use.
All the best to you in finding a solution.
post #31144 of 31146 Old Yesterday, 05:19 PM
saprano's Avatar
Quoted: 305 Post(s)
Liked: 370
I should of bought a power supply when they were going for $50.
http://www.shopjimmy.com/catalogsear...?q=pioneer+151
My procrastination gets me again.
home theater addict
saprano is offline
post #31145 of 31146 Old Today, 09:06 PM
JohnnyRose's Avatar
So I'm heading out tomorrow to look at a used 151FD with less than 1,000 hours on it. I have no way to check the hours so I have to rely on the seller's word. It was purchased in 2010.
Assuming its in pristine condition, any suggestions on what I should offer for it? Just looking for guidance as this is very subjective.
______________________________
Seeking perfect solutions.
JohnnyRose is online now
post #31146 of 31146 Old Today, 09:06 PM
JohnnyRose's Avatar
Pioneer Elite , Plasma Hdtv , Pioneer Elite 50 Inch Elite Plasma Hdtv Pro111fd
