The Official Pioneer 9G Elite KURO Owner's Discussion Thread - Page 1066 - AVS Forum | Home Theater Discussions And Reviews
 227Likes
post #31951 of 31964 Old 09-28-2017, 07:50 PM
Quoted: 264 Post(s)
Liked: 112
Originally Posted by giderac View Post
Hey guys someone in my area is selling two kurso the 151fd and the 6020fd for 800, and 550 respectively, do you guys think this is a good price for a 10 year old tv?
Let me give you an answer that is not filled with how plasma markets have dried up and you should just buy an OLED. Both will have the same blacks levels. The 151FD can be calibrated properly by using a program called ControlCal to access the ISF modes(there are other programs that work too). You'll be able to adjust white point high and low, primary and secondary colors etc. The 6020 you can't unless you put a 151 board in it. This process is complicated and if you are not able to calibrate yourself then the 6020 would be fine. If your a home calibrator then the 151 is a must. The next factor is knowing how many hours are on it. These Pioneers can literally go for ever. The TV being 9 years old, under 20k would be good. Next issue would be red tint. Turn the lights off and put up a black screen. Do the blacks have a red tint to them? If everything looks good I would put a price on the 151 at $550 and the 6020 at $450. The seller may not want to part with it for that and if you want a Kuro you may have to pay more. They don't come up that often.
Now for personal experience:
I bought a KRP-600M for $550. It had 19400 hrs on it and the blacks while not really red where glowing a bit. I've lowered voltages, calibrated with Controlcal and unlocked ISF modes. My KRP-600m is probably my favorite TV and I have a 65VT60 and LG65B6 OLED. Of cource the OLED is my best display and I enjoy it a lot but for just kicking on same basic HD satellite or a blu-ray I am so glad I have a classic Kuro.
Edllguy and makaveddie81 like this.
Test Ickles is offline
post #31952 of 31964 Old 10-18-2017, 09:31 AM
fritzjurg's Avatar
Liked: 0
I'm trying to have my Kuro Elite repaired. The technician has been told by Pioneer he needs a GGF1589 Service Remote Control. They're impossible to find. Does anyone have one they can share? Will return it when he's done
Sony XBR-65A1E OLED | Pioneer Kuro Elite 141FD 60" | Peachtree Nova Amp | Pro-Ject Turntable | OPPO UDP-203 | B&W CM1 | APC H15 Power Conditioning | AudioQuest Carbon 3M HDMI cables | Universal Remote 980-MX | Amazon Echo | Sanus BLF228-B1 Wall Mount
fritzjurg is offline
post #31953 of 31964 Old 10-18-2017, 06:50 PM
makaveddie81's Avatar
Quoted: 514 Post(s)
Liked: 278
What exactly is wrong with the TV?
He probably needs it to access the service menu. Keep in mind, there are software alternatives to the service remote to access the service menu. Hit me up on PM if interested.
JVC DLA-RS4810
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-151FD
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #31954 of 31964 Old 10-18-2017, 07:47 PM
progprog's Avatar
Quoted: 95 Post(s)
Liked: 73
Bingo. No need for the service remote. The disconcerting part is that the repairman doesn't seem to know that....
makaveddie81 likes this.
progprog is online now
post #31955 of 31964 Old Yesterday, 07:00 AM
BruZZi's Avatar
Quoted: 61 Post(s)
Liked: 122
There's also the GGF1633 Service Remote
Ditto !!!
Someone from Greece is selling a GGF1589
https://www.ebay.com/itm/GGF1589-Ser...AAAOSwuLFZwnT9
$147.37...
fritzjurg likes this.
BruZZi is offline
post #31956 of 31964 Old Yesterday, 11:37 AM
Quoted: 514 Post(s)
Liked: 278
$147.37...
Not to pat myself on the back, but $20 for my software, which works on ALL 8th and 9/9.5th generation Kuros is a better bang for your buck lol
JVC DLA-RS4810
post #31957 of 31964 Old Yesterday, 01:52 PM
fritzjurg's Avatar
Liked: 0
Ditto !!!
$147.37...
Saw that and notified my TV technician. Not sure what he is waiting for...he should have bought it already
post #31958 of 31964 Old Yesterday, 02:04 PM
bodosom's Avatar
Quoted: 277 Post(s)
Liked: 121
As noted you can enter the Elite service menu with a command via IP or serial. I also posted the Proto (doh! Pronto) string for the SM command in the KRP thread (a long time ago).
bodosom is offline
post #31959 of 31964 Old Yesterday, 03:24 PM
progprog's Avatar
Quoted: 95 Post(s)
Liked: 73
Originally Posted by bodosom View Post
As noted you can enter the Elite service menu with a command via IP or serial. I also posted the Proto string for the SM command in the KRP thread (a long time ago).
Accessible via IP, Serial and IR. I have the option programmed into the "testing" page in my universal remote. I don't remember where I got the IR code(s) for the service menu, but most likely, from remotecentral. I'd definitely hunt around there before spending any money on a service remote.
post #31960 of 31964 Old Yesterday, 05:05 PM
bodosom's Avatar
Quoted: 277 Post(s)
Liked: 121
As far as I know any instance of the SM command came from me. As noted I posted the *Pronto* string (and the Pioneer string) in the KRP thread years ago because I couldn't find it. I suppose because years ago anyone installing Elite/KRP panels would have the remote as a matter of course (or have a service manual) and wouldn't be looking for the string.
bodosom is offline
post #31961 of 31964 Old Yesterday, 05:38 PM
mpatnode's Avatar
Quoted: 45 Post(s)
Overheated?
Looks like my brother overheated the 141FD I gave him. Think running the break-in thumbdrive will fix it?
mpatnode is offline
post #31962 of 31964 Old Yesterday, 06:11 PM
BruZZi's Avatar
Quoted: 61 Post(s)
Liked: 122
This one???
At some point in time Logitech would load these. Perhaps they still do. In any case Pronto Codes are "universal".
In the Pioneer style:
Code:
Category Maintenance Function FACTORYCommand AA5FHEX CODE (one long line)0000 0068 0000 0022 0168 00b4 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0016 0016 0043 0016 0043 0016 0043 0016 0043 0016 0043 0016 0016 0016 0043 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0043 0016 0016 0016 0043 0016 03dd
If you kill your panel don't blame me.
BruZZi is offline
post #31963 of 31964 Old Yesterday, 06:17 PM
bodosom's Avatar
Quoted: 277 Post(s)
Liked: 121
DOH! I posted it here in 2012 and put a link (now broken) in the FAQ.
SM CCF hex.
bodosom is offline
post #31964 of 31964 Old Yesterday, 06:19 PM
bodosom's Avatar
Quoted: 277 Post(s)
Liked: 121
This one???
Yes but formatted differently.
bodosom is offline
Pioneer Elite , Plasma Hdtv , Pioneer Elite 50 Inch Elite Plasma Hdtv Pro111fd
