Blu-Ray Player on 720p Plasma ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-08-2008, 08:32 PM - Thread Starter
PhilipsPhanatic's Avatar
Quoted: 397 Post(s)
Liked: 52
Is there much/any benefit to running a Blu-Ray on a 720p plasma ? How much better would a 1080p plasma show a Blu-Ray ?
And what about a 1080i (I think those are LCD's, not plasma) ?
PhilipsPhanatic is offline
post #2 of 13 Old 07-08-2008, 08:39 PM
daniel'son's Avatar
Quoted: 33 Post(s)
.. from reading here, i'm not sure you'll notice a diff., depends on size of set & seating distance. if ~6ft, probably so. If Spidey-man
member Randy, i think its a city block.
Hitachi have the non True-HD plasma's that are 1080i.
daniel'son is offline
post #3 of 13 Old 07-08-2008, 08:47 PM
gatornavy25's Avatar
There's a huge difference between bluray and DVD, even on a 720P set. Wider color gaumet and sharper picture are two of the major differences. A 1080P plasma will of course, be a little sharper with bluray. Do a search for "720P vs 1080P" and look through all the debates and great info. I've got a sony bluray player and a 720P Pioneer Elite plasma, and I'm still floored everytime I pop a bluray in. I can barely stand to watch a standard dvd anymore. I've been spoiled.
gatornavy25 is offline
post #4 of 13 Old 07-08-2008, 09:06 PM
cjm7c's Avatar
+1
The quality of the source material is the most important factor in achieving excellent picture quality. Right now, BD is the most pristine source you can send to your plasma. A well mastered blu-ray disc will look significantly better than its DVD counterpart even on a 720p TV.
If you decide to upgrade to a 1080p television, the amount of visible benefit will depend on your viewing distance and the quality of the TV to which you upgraded. If you go with a bargain basement 1080p set, the overall picture quality might look worse.
EDIT: The only 1080i native sets are CRTs and some Hitachi plasmas. Don't worry about 1080i sets unless you're planning on buying an HD CRT.
cjm7c is offline
post #5 of 13 Old 07-08-2008, 09:19 PM
MidnightWatcher's Avatar
Quoted: 37 Post(s)
Liked: 25
Check out what Home Theater Magazine says about the Pioneer 5080HD 720p plasma here.
MidnightWatcher is offline
post #6 of 13 Old 07-08-2008, 09:21 PM
MelloFellow13's Avatar
Quoted: 129 Post(s)
Liked: 174
I've been using a Vizio 42" LCD TV (read: total crap) for almost a year, and when I got my PS3 in March with some Blu-rays it was still a huge difference. I highly recommend it, up-converted DVD is nice if it's all you have but it still doesn't compare.
Don't forget that Blu-ray movies also feature high definition SOUND! If you have a receiver and speakers which can take advantage of it it makes a great difference, and if you don't... get some!
LG 65E6P
Pioneer 5020FD
MelloFellow13 is offline
post #7 of 13 Old 07-09-2008, 05:22 AM
scotth42's Avatar
Will a Blu Ray DVD look better than a standard DVD when viewed on a 1080p upconvert player and 1080p plasma ?
scotth42 is offline
post #8 of 13 Old 07-09-2008, 05:31 AM
optivity's Avatar
Blu-ray disc is encoded w/HD formats: 1080i/1080p and played back on Blu-ray devices only, SD upconverting DVD players cannot play Blu-ray disc.
optivity is offline
post #9 of 13 Old 07-09-2008, 05:43 AM
frorule's Avatar
I should hope so. DVD = garbage in...
My Basement Theater/Rec Room
"I don't have some way to put it...that's the way it is."
frorule is offline
post #10 of 13 Old 07-09-2008, 05:54 AM
Majestyk's Avatar
What? Where did you read this?
Majestyk is offline
post #11 of 13 Old 07-09-2008, 07:08 AM
daniel'son's Avatar
Quoted: 33 Post(s)
.. waiter, where's my 'omelet' !!
i see you've been w/ the AVS family for some time & your posts count appears to show you know (assumption) about different features provided w/ being a member. The 'search' tool is one such feature.
but, my past few months being a member I've scoured the diff. threads/posts & with the collective thoughts of others, my post was taken from what i'd taken in. So, after using the search tool, i was able to pull up a thread that seems tuned to the topic:
http://www.avsforum.com/avs-vb/showt...+1080p+blu-ray
post #12 of 13 Old 07-09-2008, 08:17 AM
Quoted: 129 Post(s)
Liked: 174
I'm pretty sure they meant it's tough to discern a difference between 720p and 1080p.
It's much easier to tell the difference between DVD and Blu-ray, imo.
LG 65E6P
Pioneer 5020FD
post #13 of 13 Old 07-09-2008, 10:56 AM
optivity's Avatar
Makes sense to me. There is a BIG difference between SD & HD, but with HD content, 720p versus 1080p, those differences w/image resolution/detail are rather small to begin with and virtually impossible to distinguish between for sub-60" displays if/when sitting ~10' or more away from the screen.
optivity is offline
