The Official Pioneer 9G Kuro Settings/Issues Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #721 of 11084 Old 08-30-2008, 10:47 AM
maskdes's Avatar
Originally Posted by NormalGuyMike View Post
I think you're right. The living room of my condo is a corner room with huge windows (from the floor to the ceiling) on two of its walls.
I have a lot of light in my tv room,too. One patio door and a 8'x5' window.
I am looking for a good black out roller shade. Could someone please tell/
point me to the thread of this topic, or if you know a good brand. Preferably with automation. Thanks.
maskdes is offline
post #722 of 11084 Old 08-30-2008, 12:10 PM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
mode 1 is light sensor only. mode 2 is light AND color sensor.
if you are using D-Nice's d65 settings in pure, dont use any sensor...OFF.
He may post the ISF settings later for ISF-AUTO, which may make better use of the sensor.
aliaskary77 is offline
post #723 of 11084 Old 08-30-2008, 12:21 PM
Newenglander's Avatar
I thought the color and light sensor only work with Optimum mode. Am I wrong??
I am using D-Nice's settings.
I also tried the settings for Performance mode from the link you had posted with your recommened changes. I have noticed that in Pure Mode, some movies do look a little washed out. An example of this is Zodic. Part of the problem at least for me is that I have been watching HD with a Panny for years and am used to a little different PQ.
I really liked your recommendations.
Newenglander is offline
post #724 of 11084 Old 08-30-2008, 12:28 PM
progprog's Avatar
Originally Posted by botcher View Post
Does anyone have a code for the RC64 remote that will work functions on the PDP-6020 other than the volume/mute and channel up/down buttons?
I tried all of the codes on the HR20 OSD and also the RC64 pdf manual, but none of them will worl anything other than the volume and channel control. I'd like to be able to get into the menus or other functions, just like the RC64 will do on my Sony sets.
Originally Posted by pauker01 View Post
I have the same issue. I didn't see any replies the original post.
Is it a learning remote? If so, try learning the commands. If not, I'd recommend trying codes for all the Kuro models made in the last couple years. All their code sets are pretty similar, and one of the older ones might be more complete.
progprog is offline
post #725 of 11084 Old 08-30-2008, 12:29 PM
progprog's Avatar
Originally Posted by Newenglander View Post
I thought the color and light sensor only works Optimum mode. I am wrong??
That's what I thought too. Hopefully, we can get some clarification.
progprog is offline
post #726 of 11084 Old 08-30-2008, 12:31 PM
coltsfreak18's Avatar
I know D-Nice uses the color/light sensor in ISF auto, so at night he gets a much dimmer image (for the eyes ), and the last time I remember is when he said he'd be trying it out with pure mode. I think it does work with other modes.
What is dead can never die. Long live my 151!
coltsfreak18 is offline
post #727 of 11084 Old 08-30-2008, 12:35 PM
progprog's Avatar
Originally Posted by hingis_fan View Post
Hi guys, just wondering if D or turbo have posted an SM guide yet and some settings? Any info or ETA for this kind of thing?
Originally Posted by htwaits View Post
Not yet.
If anyone has the serial command for accessing the SM, I'd really appreciate if you can PM it to me. I already have SM access via IR, but I use serial control of my 151 and would prefer to keep everything within one code set. D-Nice originally offered to send it to me, but then decided not to. As I said, I already have SM access, so I'm not asking for some big "insider secret," I just would prefer to use the alternate code.
progprog is offline
post #728 of 11084 Old 08-30-2008, 12:38 PM
progprog's Avatar
I should refine my comment: I thought it only worked in Optimum and ISF Auto, as that's what the "auto" was all about. Seems like if the sensors work in the other modes, and will modify settings on the fly due to ambient conditions, the settings in those other modes are kind of, well, not pointless, but less important.
progprog is offline
post #729 of 11084 Old 08-30-2008, 01:04 PM
mt14942's Avatar
Quoted: 475 Post(s)
Liked: 167
I have a question regarding the posted break-in settings. Does any body else worry that these break-in settings especially the contrast is rather high? It seems I have read a number of articles suggesting that during the first 200 hours you should keep the contrast level and other picture settings to 50% or less. The posted 50 setting for contrast and 20 for color far exceeds that. Can anybody out there comment on this as I have just started the break-in with the dvd with these settings and I don't want to fry this display.
Mike
Sony XBR75X940C
Panasonic DMP-UB900
Classe SSP-800 pre/pro
Parasound Halo 5 channel Amp
Denon A1UDCI Universal BD player
mt14942 is offline
post #730 of 11084 Old 08-30-2008, 01:14 PM
Quoted: 46 Post(s)
Liked: 56
someone correct me if i am wrong.
light sensor is built into the panel. the sensor we attach is the color sensor.
with optimum, mode 1 and 2 is available, but you have no settings control at all.
with all other modes, you have mode 1 and 2 as an option also. If you want, try mode 1 with other settings. I think it will only effect peak light output and dim as the ambient light goes down, kind of like DNice explained about ISF Auto. I would avoid using mode 2 personally as you dont want to effect color. (although im sure using the color sensor in other modes will not allow it to change as much as it does in optimum)
post #731 of 11084 Old 08-30-2008, 01:17 PM
KooSoul's Avatar
D-Nice:
will you post D75 and D55 settings for tv starting with HEPM?
thanks
KooSoul is offline
post #732 of 11084 Old 08-30-2008, 01:33 PM
Quoted: 46 Post(s)
Liked: 56
glad it helped. credit goes to ikeb. i bookmarked his post as he said its a work in progress.
this is my first flat panel ever. i am on of these that when comparing the displays in the store, loved the LCD image and thought plasmas looked too dim, especially pioneers. but reading everything, i know these displays are the best.
like others have posted, it does take some getting used to. d65 from ikeb in performance, which i use for normal tv which is during the day seems perfect. at nights, if i am watching movies with very little light, d65 from dnice took 2 days to get used to. i was watching beijing opening ceremony in hd with little light. i was playing back and forth with d65pure and d75sport. even my wife who thinks the images are too dim said ouch with i went to d75sport.
i still play between d65pure and d65performance with movies to compare. they can both look good, but i usually fall back to d65pure. d65performance settings by ikeb are a great alternative to those that want a little more pop or have a little more light.
main thing to remember. these are all great base settings to start with, especially for people like me that are new to being given this many options and learning what images should look like. by all means, tweak these furthar and find something you like if the base settings dont do it for you.
post #733 of 11084 Old 08-30-2008, 02:04 PM
progprog's Avatar
Mike
This gets into the whole break-in vs. no break-in debate. Search the plasma threads and you'll find about two weeks worth of reading on it. My understanding of the break-in (as recommended here, not by Pioneer), is that you are trying to accelerate the the early "wear" on the set, to get it out of the way faster. You'll just have to read the variety of opinions on the topic and decide what you are comfortable with for your TV, and whether that includes the "fry mode" contrast settings.
progprog is offline
post #734 of 11084 Old 08-30-2008, 02:42 PM
mt14942's Avatar
Quoted: 475 Post(s)
Liked: 167
Thanks, for chiming in. Even the person who sent me the dvd break-in disc recommended this: (" I suggest turning the contrast and brightness way down (about 15% to 20% of contrast and brightness bar) just in case your DVD player flips out (although I have not heard any cases of this in 2 years). Suggested run time is for 100-200 hours. I would suggest giving your tv a little break from time to time and don't forget you can also still watch tv during the break in period, just cary your viewing, stay away from black bars and high contrast static logos. Enjoy
Evangelos)
I will probably continue using the break-in dvd but set the contrast to 30 instead of 50 which is 50% and also lower color to 10 from 20 and set color temperature to medium as opposed to high. I will just increase the hours to 200 to compensate. I would like to still be able to take advantage of D'nice's settings. I am not sure if they would be approriate if I do this. Of course I will also be doing a fair amount of full screen viewing while doing this, trying to avoid those static channel logo's when ever possible.
Mike
Sony XBR75X940C
Panasonic DMP-UB900
mt14942 is offline
post #735 of 11084 Old 08-30-2008, 03:24 PM
general23cmp's Avatar
Guys,
I am using the thumb drive files on my new 151 (havent watched anything on it yet) using D-Nice's settings. It's been going almost non-stop since last Wednesday. I am using 15 seconds between images(30 seconds seems like a lot). However, there is about a 5 second delay between images of nothing (black). Should I tweak the 150 hour time, so that it is 150 hours of images, or do the provided settings take that blank delay into account? In other words if I run the thumb drive images for 150 hours at 15 second intervals, there is only about 112 hours of images displayed. The other part of the 150 hours is blank screen. If I want 150 hours of thumb images, then I would need about 200 hours of playing the thumb drive (150 hours of images in 15 second intervals and 50 hours of blank screen at 5 second intervals). If D-Nice's settings take this into account, then it doesn't matter. I just want to be sure on the 150 hours.
If someone uses more or less on the display time (30 seconds, for example), then that is an entirely different amount of time if you run it for 150 hours with the 5 second delay still persisting. In 150 hours of run time, the tv would see 128.5 hours of images.
This makes me believe that it is 150 hours of images. the blank screen shouldn't be counted. What is the consensus on this? D-Nice?
I just want to do what is best for optimum picture quality and accuracy of the settings, without having a calibrator coming out, of course.
general23cmp is offline
post #736 of 11084 Old 08-30-2008, 03:51 PM
Kuro60Elite2008's Avatar
This Feb, 2008, acquired my 60" 150-FD (and also Elite Blu-ray player and P's receiver 94TSX)... and never knew there was any procedure(s) that should be done to the screen or otherwise. Purchase was from Ken Crane's TV stores.
Clearly, I'm way behind. Need to catch up, or at least recognize the common issues. Would love to know certain things:
1. Common, easy, newbie levels of stuff to do, or not do, re getting the equipment all working, working together well, and generally producing on the PR, performance optimization, and reviewers optimisms.
2. Best HDMI 1.3a hookups, things to do, optimize, etc.
3. How best to tie in the screen to my home computer network, wirelessly.
4. In what ways might the (new this summer) Pro-151FD be actually improved/better than my Pro-150FD of this last Feb.2008... other than the list price being $1000 less (wonder if there's a refund/rebate/etc.?)
Any inputs appreciated, when anyone has the time, etc. OR/and any good URL's to check out.
Meanwhile, will take same 'off-line' and just continue to observe the threads ongoing, w/o my interfering w same.
Kuro60Elite2008 is offline
post #737 of 11084 Old 08-30-2008, 04:41 PM
progprog's Avatar
You might want to move that post over to the 9G Elite thread. Your questions are more general than the settings focus of this thread and you'd probably get more feedback over there.
http://www.avsforum.com/avs-vb/showthread.php?t=1039269
progprog is offline
post #738 of 11084 Old 08-30-2008, 05:09 PM
billybob0405's Avatar
Originally Posted by general23cmp View Post
Guys,
There's nothing magical about the 150 hr time frame. It's just a suggested approx goal. Some say 150-200 hrs, the post above yours, quoted evangelos as saying 100-200 hrs with different settings, and it's his break in disk. I wouldn't set the alarm for 3am if that's when the 150hr time hit.
D-Nice used his settings to break in his set. He did not pull these settings out of the air, he has the expertise, knowledge and contacts to validify his settings as probably the most efficient IMHO. To get the best results from his "after breakin settings", it seems logical that you would want to follow the same method as he used. Whether you miss the exact 150 hrs by a few hrs one way or the other is not going to screw the process up, I don't believe. If D-Nice disagrees, I'm sure he will set me straight.
Bill
There are no answers, only choices.
billybob0405 is offline
post #739 of 11084 Old 08-30-2008, 06:07 PM
mr2828's Avatar
If you mean Zodiac, the Fincher movie - it was deliberately made to have somewhat muted colors. So it is supposed to look that way.
If you want "pop" and cartoony bright colors go watch a kiddie movie.
mr2828 is offline
post #740 of 11084 Old 08-30-2008, 07:14 PM
Quoted: 46 Post(s)
Liked: 56
1st part, helpful and informative...good for people to know this stuff.
2nd part could really be done without. (this goes for other posters too. ive seen a few that have posted "watch it the way its supposed to be and appreciate it since its the only correct way, or sell the kuro and buy a vizio, you unappreciating noob." ok, maybe i went a little too far. )
post #741 of 11084 Old 08-30-2008, 09:09 PM
I am not an idiot. I know the film was shot in a toned down mode to reflect the time period of the piece. Even in Optimum mode, the colors were still subdued, just not washed out.
I also find fillms where the director wanted a dark theme to be difficult to watch in Pure mode. Two examples are The Dark and AVP Requim. Again, in Optimum mode, the picture was a little brigher which made it easier for me to view.
For most viewing, Pure mode is definitely the way to go. Tonight I watched Unbreakable (BD version). This movie has so much natural high levels of contast that viewing it in Optimum mode would cause retinal damage.
But, it is nice to have different options to choose from to enhance viewing experience.
post #742 of 11084 Old 08-30-2008, 11:18 PM
ddgtr's Avatar
Mike
Is this something we should worry about?
ddgtr is offline
post #743 of 11084 Old 08-31-2008, 06:10 AM
JazzGuyy's Avatar
Quoted: 292 Post(s)
Liked: 286
As I understand it, the color and contrast are turned up when using the break-in disk to "overdrive" the panel and thus push the settling in process for the phosphors. It is only to be done where there are single uniform colors across the whole panel which are changing frequently because standard programs at these settings would have all kinds of colors and intensities scattered across the screen because this is essentially what normal content is. Normal programming shown with the break-in settings could probably lead to IR issues.
I used the break-in disk with the "overdrive" settings and saw no negative results. As long as you remember that these settings are only to be used with the break-in disk (or the thumbdrive equivalent) and never with normal programming, I don't think there would be any problems.
JazzGuyy is offline
post #744 of 11084 Old 09-01-2008, 05:51 AM
Sam S's Avatar
Quoted: 213 Post(s)
Liked: 106
Originally Posted by Sam S View Post
So would GetGray be the best option? If so, the software would not run automatically, correct?
Originally Posted by D-Nice View Post
GetGray for SD content. AVS-HD 709 for HD content. The latter is free.
Bump for D-Nice.
I purchased the Chroma5 + CalMAN package. I have not purchased GetGray yet. Based on the software/colorimeter I will be using, is AVIA enough for SD content? I have used AVIA extensively in the past, just didn't know if there was something else on GetGray that I would be missing over my current AVIA disc.
Sam S is offline
post #745 of 11084 Old 09-01-2008, 09:44 AM - Thread Starter
D-Nice's Avatar
Quoted: 124 Post(s)
Liked: 457
Mike
The break-in settings are un-officially approved by Pioneer. It is not mandatory for you to break-in your TV. If you choose to break-in your TV, this is the most effective way to do it. Reducing the contrast and brightness prolongs the process.
D-Nice is offline
post #746 of 11084 Old 09-01-2008, 09:47 AM - Thread Starter
D-Nice's Avatar
Quoted: 124 Post(s)
Liked: 457
Bump for D-Nice.
Congrats on your purchase. I have not used Avia in ages as at this point, it's a relic. Get-Gray, IMO, is hands down the best calibration DVD for SD sources. The AVS-709 disc is the best for HD sources (unless you have a pattern generator).
Have fun calibrating your display and make sure you get ControlCAL to activate and calibrate ISF-Auto/Day/Night modes
D-Nice is offline
post #747 of 11084 Old 09-01-2008, 09:48 AM - Thread Starter
D-Nice's Avatar
Quoted: 124 Post(s)
Liked: 457
Originally Posted by KooSoul View Post
D-Nice:
thanks
I doubt it.
D-Nice is offline
post #748 of 11084 Old 09-01-2008, 09:50 AM - Thread Starter
D-Nice's Avatar
Quoted: 124 Post(s)
Liked: 457
111FD/151FD Pure and Movie mode settings for non-HEPM serial number owners have been updated. These settings may look very radical compared to their predecessors, however they will perform better overall.
As always, enjoy
D-Nice is offline
post #749 of 11084 Old 09-01-2008, 09:58 AM
mt14942's Avatar
Quoted: 475 Post(s)
Liked: 167
Thank's D'Nice, this is my first plasma and I have much to learn. I, and I am sure many others, appreciate all the time and knowledge that you donate to this thread.
Sony XBR75X940C
Panasonic DMP-UB900
mt14942 is offline
post #750 of 11084 Old 09-01-2008, 11:04 AM
Sam S's Avatar
Quoted: 213 Post(s)
Liked: 106
Thanks. I am going to take this slow. I don't have a Windows-based laptop today, so that will be another purchase, or I'll drag my desktop into the living room
I was planning on getting access to ControlCAL, I'd like to knock down the brightness a bit (over your recommended settings) for watching in a completely dark room.
See ya over at the ControlCAL forums
Sam S is offline
