The Official Pioneer 9G Kuro Settings/Issues Thread - Page 360 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #10771 of 11084 Old 04-23-2014, 10:40 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
Originally Posted by oppopioneer View Post
Where do I go to access and find out how many hours my tv has in use? Can any of you give me instructions? It's a Pio Elite Kuro Pro-151FD.
A member here created a kuro program. There's a thread for it.
home theater addict
saprano is offline
post #10772 of 11084 Old 04-24-2014, 06:57 PM
rcapprotti's Avatar
Quoted: 165 Post(s)
Liked: 130
saprano not yet it's a little better than it was a month ago. I just haven't put a lot of time on the TV I may have a little over 200 hours on it maybe 250 at the most. Like fine wine I'm sure it'll get better over time. Thanks for asking
rcapprotti is offline
post #10773 of 11084 Old 07-12-2014, 04:30 PM
makaveddie81's Avatar
Quoted: 477 Post(s)
Liked: 273
Just installed speakers (courtesy of rcapprotti, thanks bud!) And was wondering what the best options are for the four srs settings. I currently have everything set to off, but want to squeeze the last ounce of performance out of these speakers.
makaveddie81 is offline
post #10774 of 11084 Old 07-13-2014, 12:50 PM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
Turn the bass up to 3 and put everything on low then adjust to your taste from there. But just changing it to low is a big improvement.
home theater addict
saprano is offline
post #10775 of 11084 Old 07-13-2014, 01:02 PM
craigyboy's Avatar
Quoted: 37 Post(s)
Liked: 91
what about your treble and bass?
craigyboy is offline
post #10776 of 11084 Old 07-13-2014, 05:11 PM
lnarbi's Avatar
Quoted: 219 Post(s)
Liked: 66
The best setting is everything off
The soundbar is pretty good, it has the same tonal balance and overall sound (except the lack of bass which is normal with speakers of that size) as my linn speakers behind a professional power amp.
lnarbi is offline
post #10777 of 11084 Old 07-13-2014, 06:40 PM
Quoted: 477 Post(s)
Liked: 273
Im not remotely close to being audiophile, but they sound good with default settings. Setting everything to low does give it a little extra kick, but i dont know if doing so is the equivalent to setting motion processing to low in the video world. I want to hear what the director intended, so not sure what the best approach is.
post #10778 of 11084 Old 07-13-2014, 08:20 PM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
I don't touch the treble, only bass. I don't remember exactly what the other sounds settings are called, but I have them at a mixture of low and mid.
I have the sound set different for pure and movie.
home theater addict
saprano is offline
post #10779 of 11084 Old 07-14-2014, 11:51 AM
Quoted: 477 Post(s)
Liked: 273
Wait, I can have different sound settings for each picture mode? Wow, Pioneer really though of everything!
post #10780 of 11084 Old 07-14-2014, 12:43 PM
craigyboy's Avatar
Quoted: 37 Post(s)
Liked: 91
yes will need setting for each input
post #10781 of 11084 Old 07-14-2014, 04:02 PM
Stu03's Avatar
Quoted: 69 Post(s)
Liked: 169
Chuck em all up high
Stu03 is offline
post #10782 of 11084 Old 07-18-2014, 02:55 AM
Urga's Avatar
Quoted: 28 Post(s)
Liked: 367
In addition to the audio bar You can connect a subwoofer on the kuro optional ...
Pioneer LX 5090H + Démo G5  C+ Csat HD + DD et la TNT + Pioneer LX58 + Sony BD-S790 ... Pana 50 ST60 + PS3 BD + Pioneer BD320 ... CRT Philips 32 PW 9520 P+2 DNM + TNT Thomson DTI 652 + Pioneer DV 380 ... BR 137 .
Urga is offline
post #10783 of 11084 Old 07-18-2014, 10:37 AM
jmmesch's Avatar
I use a 7.1 AVR for my audio. Wow! It is grand on Master or TrueHD.
My favorite toy
jmmesch is offline
post #10784 of 11084 Old 07-27-2014, 08:38 AM
gunhed's Avatar
Quoted: 22 Post(s)
Hi guys,
I know this has probably been covered before here but does anyone know exactly why a Kuro can increase it's light output in the ISF modes as opposed to the default modes you get with the set ?
Does unlocking the ISF modes somehow increase the ABL threshold in those modes or something like that ?
Also does simply unlocking the ISF modes allow increased light output in those modes or do you actually have to calibrate the ISF modes after unlocking ? Like can calibrate my lumagen and send the signal thru the Kuro ISF day mode to get a bright calibrated picture ?
gunhed is offline
post #10785 of 11084 Old 08-02-2014, 03:35 PM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
Can somebody tell me if this startech cable is the proper one to use for controlcal?
http://www.amazon.com/s/?ie=UTF8&key...l_8vzkjhgh32_b
home theater addict
saprano is offline
post #10786 of 11084 Old 08-02-2014, 06:14 PM
Quoted: 477 Post(s)
Liked: 273
That should be good since its straight through. Make sure you get the right gender. I use the one listed in post 1 of the below thread. Works with controlcal, kuro kapture, kuro command and kuro control.
http://www.avsforum.com/forum/167-plasma-flat-panel-displays/1577577-kuro-command-program.html#post25229882
post #10787 of 11084 Old 08-02-2014, 06:25 PM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
It's suppose to be female to female correct? Looks like they only have 6 feet. I need about 10 or 12.
home theater addict
saprano is offline
post #10788 of 11084 Old 08-02-2014, 10:44 PM
Quoted: 477 Post(s)
Liked: 273
Yes. Your kuro and the adapter should each have a male port.
post #10789 of 11084 Old 08-03-2014, 09:38 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
The controlcal site doesn't have any activity. So i'm going to ask here. When i run the install it gives me 3 options to choose from. Which do i choose? When i selected the first, whatever that does, it installed but the CC folder is empty???? Also when i tried downloading the profile it says page not found????
home theater addict
saprano is offline
post #10790 of 11084 Old 08-03-2014, 10:05 AM
Quoted: 477 Post(s)
Liked: 273
Yeah, they need to update their site as you have to contact turbe directly to purchase profiles (via paypal donation).
post #10791 of 11084 Old 08-03-2014, 10:23 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
This is why i never wanted to bother with this. Everything is too confusing. The site is nothing but links to more links to links, links, links. There is no one page of concise things to do and how to do it. I can't even download the main program properly.
home theater addict
saprano is offline
post #10792 of 11084 Old 08-03-2014, 03:24 PM
Quoted: 477 Post(s)
Liked: 273
I feel you. I had to email Turbe directly for instructions on how/where to download the program and profiles.
post #10793 of 11084 Old 08-20-2014, 10:23 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
Anybody think D-Nice's ISF settings on the first page are still valid? Does anybody have any new settings? And it says plus green 2008 151's only. Mine is 2009.
I'm going to access the ISF modes this week. Are the default settings in day and night good enough?
home theater addict
saprano is offline
post #10794 of 11084 Old 08-20-2014, 05:17 PM
rcapprotti's Avatar
Quoted: 165 Post(s)
Liked: 130
How do you access the ISF mode? I have the ISF mode unlocked
post #10795 of 11084 Old 08-21-2014, 12:42 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
Go to the picture modes. Did you just get them?
home theater addict
saprano is offline
post #10796 of 11084 Old 08-21-2014, 05:41 AM
rcapprotti's Avatar
Quoted: 165 Post(s)
Liked: 130
no I had the ISF modes unlocked a couple months ago
post #10797 of 11084 Old 08-21-2014, 09:03 AM
jmmesch's Avatar
D-Nice set my 151FD to have Day ISF when there is sunlight, and Night ISF during the night.
My favorite toy
jmmesch is offline
post #10798 of 11084 Old 08-21-2014, 11:12 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
Yeah they should be in the picture modes menu. You never used them?
home theater addict
saprano is offline
post #10799 of 11084 Old 08-21-2014, 01:36 PM
rcapprotti's Avatar
Quoted: 165 Post(s)
Liked: 130
Yes I have it in ISF day but all the adjustments are grayed out
post #10800 of 11084 Old 08-22-2014, 06:55 AM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 532
To change settings you have to use control cal. I don't like that about the ISF modes. I'm always playing with settings and to have to use CC everytime I want to make an adjustment is not good at all.
home theater addict
saprano is offline
