The Official Pioneer 9G Kuro Settings/Issues Thread - Page 366 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #10951 of 10970 Old 08-16-2015, 08:57 PM
enf1945's Avatar
Originally Posted by RYANtheTIGER View Post
I'm removing the I/O and Mainboard of my 111FD so that they can be fixed. However, I am having trouble removing the two hexagon head screws (ABA1382) - Step 3 of "T Panel U Assy" in the Service Manual. Someone please help. I cannot figure out out to remove these!
8 blinking lights , Ryan ???
enf1945 is offline
post #10952 of 10970 Old 08-17-2015, 06:02 PM
EricQ's Avatar
***8 Blinking Lights Fixed***
My problem with the Kuro is fixed. I can now swap inputs and turn the tv off and on without any problems. If anyone has this problem there is a guy you can send in your main board and I/O board for repair. Here is a link to his ebay ad Clicky
I'm all set until oled tech matures.
"Guns at dawn, swords at dusk."
EricQ is offline
post #10953 of 10970 Old 08-22-2015, 01:33 PM
OShag's Avatar
Quoted: 28 Post(s)
Liked: 32
Saprano,
Pure can look a bit murky and dull with OTA sometimes (No doubt a lot is dependent on the broadcast) . The settings you suggested bring the picture out a bit more I think. What are you using for ISF DAY and ISF NIGHT as I want to try those too. Are you using ISF AUTO? Also, What are your settings for Vol YKNOFS1 D, YKNOFS3 D, YKNOFS4 D, AND YKNOFSA D? Also what is your RST P at? My settings are YKNOFS1 D 86, YKNOFS3 D 96, YKNFS4 D 143 and ny RST P is 031.
Thanks much
OShag is offline
post #10954 of 10970 Old 08-22-2015, 01:58 PM
OShag's Avatar
Quoted: 28 Post(s)
Liked: 32
General question for you guys. I wasn't happy at all to find a few small scratch/ abrasion marks (very slight and only noticable in the light) on the bezel . Don't know if someone carelessly cleaned the TV with a dirty rag but I am very picky and clean about my TV and have kept it immaculate for years. I am assuming the bezel is an acrylic material, so the best way to approach any type of scratch/ blemish removal would be to buff it out with a purpose designed polish compound and clothes? Any input would be welcome.
OShag is offline
post #10955 of 10970 Old 08-22-2015, 02:46 PM
OShag's Avatar
Quoted: 28 Post(s)
Liked: 32
Kuro in bedroom, also picture of BDP-09FD and DV-79AVi
ID:	902114   Click image for larger version
OShag is offline
post #10956 of 10970 Old 08-24-2015, 09:53 AM
VidPro's Avatar
Quoted: 14 Post(s)
Liked: 32
I posted this a while back and worked well. There are some threads to search out that might have more info. HTH.
I would first try a the Meguiar's NXT Generation® Tech Wax® 2.0 and it give it a few coats. With a good amount of pressure on the first application and then a couple more applications with less pressure you'll get rid of the surface scratches. If that does not work you can try hitting it with the Novus and then finish up with the wax. I think most light swirl marks will come out with the wax. By the way the wax is awesome for your car too.
The television screen is the retina of the mind's eye.
VidPro is offline
post #10957 of 10970 Old 08-24-2015, 09:55 AM
OShag's Avatar
Quoted: 28 Post(s)
Liked: 32
Thanks Vidpro. Will try this.
OShag is offline
post #10958 of 10970 Old 08-24-2015, 10:29 AM
Cloggerdude's Avatar
I made a thread about it already, but I've got an opportunity to buy a PRO-141FD (60") for $850. I had a Kuro 500M a few years ago, but ended up selling it (mistake).
Should I go for the 141FD? From what I gather, the picture quality isn't quite as good as the 500M, but it's still quite good. Second place, perhaps?
I'm also considering the LG EC9300 OLED, but price and other problems are holding me back currently.
Cloggerdude is offline
post #10959 of 10970 Old 08-24-2015, 11:33 AM
dsskid's Avatar
Quoted: 233 Post(s)
Liked: 244
I'd jump on it.
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is offline
post #10960 of 10970 Old 08-24-2015, 06:47 PM
RYANtheTIGER's Avatar
Quoted: 84 Post(s)
I'd like to echo Eric. I had the same problem, went to the same guy on eBay and a week or so later - my 111FD is back in business! Well worth the money.
RYANtheTIGER is offline
post #10961 of 10970 Old 08-25-2015, 03:26 PM
Quoted: 84 Post(s)
Anyone have the issue where the Home Menu and Tools buttons on the remote do not respond? I can change HDMi sources, volume, etc. but get nothing when I press the Home Menu or Tools buttons.
post #10962 of 10970 Old 08-25-2015, 03:52 PM
dsskid's Avatar
Quoted: 233 Post(s)
Liked: 244
Weak batteries?
ISF Calibrator
Samsung PN64F8500
dsskid is offline
post #10963 of 10970 Old 08-25-2015, 08:21 PM
saprano's Avatar
Quoted: 305 Post(s)
Liked: 370
Saprano,
Thanks much
What settings did i give you? I have verizon which is suppose to be the best broadcast signal. Pure can look really good on some content. Other times it's as you said, murky. But it's not the kuros fault, it's just showing the source.
I don't have the ISF modes. I was suppose to unlock them. Don't know why i still haven't.
My voltage settings are
Vol SUS 128
Vol offset 068
Vol RSTP 018
Vol XPOFS1 105
Vol XPOFS2 063
Vol YKNOFS1D 086
Vol YKNOFS3 096
Vol YKNOFS4 143
Vol YKNNOFSA 128
home theater addict
saprano is offline
post #10964 of 10970 Old 08-25-2015, 08:27 PM
saprano's Avatar
Quoted: 305 Post(s)
Liked: 370
I hate glossy products they get scratched so easily. My bezel is scratched too. Can't see it unless natural light is shined on it. Anyone who says their bezel isn't scratched is not looking hard enough.
home theater addict
saprano is offline
post #10965 of 10970 Old 08-25-2015, 09:08 PM
Liked: 1
Quick update...
Purchased a 50" Kuro a few years ago, and about two months ago I found an one-owner nearly unused 151FD. Purchased it, had it calibrated and at first I didn't get very thrilled about the results. But as recommended by the tech, I waited a couple of weeks to 'get used' to it and he was right. Now, no other mode looks better than the calibrated isf-Night. My take on this, if you own a Kuro, no matter what model, calibration is a must. My 60" 151FD Kuro is from Jan/2010 and the picture is IMHO still unparalleled by any other set today.
Edllguy likes this.
KuroKrazy is offline
post #10966 of 10970 Old 08-26-2015, 02:30 PM
OShag's Avatar
Quoted: 28 Post(s)
Liked: 32
Vol SUS 128
Vol offset 068
Vol RSTP 018
Vol XPOFS1 105
Vol XPOFS2 063
Vol YKNOFS1D 086
Vol YKNOFS3 096
Vol YKNOFS4 143
Vol YKNNOFSA 128
Thank Saprano!
Your RSTP is lower than mine by 13 clicks, but all else is the same. Would recommend the ISF modes. ISF Day will give quite a bit more pop while looking 'right'. Given the inevitable drift that these sets go through over their life, I wonder if it might be wise to buy calibration gear and learn to do it myself?
OShag is offline
post #10967 of 10970 Old 08-27-2015, 05:28 PM
OShag's Avatar
Quoted: 28 Post(s)
Liked: 32
Saprano is that RSTP of 018 what the TV was set at or did you lower it to that?
OShag is offline
post #10968 of 10970 Old Yesterday, 04:03 PM
saprano's Avatar
Quoted: 305 Post(s)
Liked: 370
That's factory set.
home theater addict
saprano is offline
post #10969 of 10970 Old Yesterday, 05:03 PM
CrossRoad's Avatar
Gentlemen, I have had my Pro 151 for about 6 years. In recent days I have noticed an odd phenomenon. I am watching the Cowboys game on CBS channel 11 in DFW using an OTA antenna and the motion looks a lot like 120hz. THIS IS ANNOYING. It isn't doing this on other channels and it doesn't do it when watching BDs. I haven't changed any setting in years. Any ideas on what is going on? Is this a broadcast issue, or is my Kuro declining? I have been searching here and on Google and I can't find anything about this. I appreciate any help you guys can provide.
CrossRoad is offline
post #10970 of 10970 Unread Today, 11:18 AM
makaveddie81's Avatar
Quoted: 240 Post(s)
Liked: 211
Sounds like a source problem to me, though make sure your pure cinema mode is set to standard, as advanced forces all content to 75hz.
makaveddie81 is online now
