The Official Pioneer 9G Kuro Settings/Issues Thread - Page 369 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #11041 of 11070 Old 04-18-2016, 12:08 PM
Quoted: 21 Post(s)
Liked: 0
Originally Posted by makaveddie81 View Post
Why do you want to change your panel rx, ry, gx, gy, bx, by??? Those are NOT affected by a pulse meter reset and, unless you have professional grade meter and software, you are better off not touching those.
Factory settings for the service menu RGB High from a non reset panel will not make a difference on your set since you already reset the pulse meter without writing down the actual RGB values. There are two sets of RGB values - configured and actual. The configured ones (which are the ones that we have access to) do NOT change after reset or as the panel ages. The ones that change over time are the actual values. After you reset the pulse meter, the configured values will remain the same, but the actual values will revert back to their initial value. What you should have done was write down the actual values before pulse meter reset and then adjust the configured values AFTER reset so that the actual values match their pre-reset values.
If anything, you just made your grayscale WORSE by plugging in the configured values from a non reset display. If you insist on tinkering with these without using a colorimeter, you need to lower red and raise blue since post reset displays will always be heavy on red.
Makaveddie81..thanks for your info, i was used krp500 settings for this values and i think that this is not correct..can you post if you can the correct values for lx5090 please? thanks in advance
booleano is offline
post #11042 of 11070 Old 04-18-2016, 02:04 PM
Quoted: 21 Post(s)
Liked: 0
Originally Posted by andy79 View Post
Question: if the "hard-wired" settings for Performance and Standard are identical, why are the reference settings different?
Quote:Originally Posted by Dahlsim
Repost from old thread:
This thread is definitely useful for these sets. There's actually quite a bit of "tweaking" possible for a set with reduced adjustments.
I'll take the liberty to add the other Non-Movie settings which D-Nice has posted for other 6020 A/V modes as his own reccomendations for starters. It should not deter others from adding their own customized settings however.
Underlying Settings for each of A/V Modes:
A/V Mode ---- DRE --- Black Level --- ACL --- Enhancer --- Gamma --- CTI
Dynamic------ High ------- On ------- On ------- 2 ---------- 2 ------ On
Performance-- Mid -------- On ------- On ------- 2 ---------- 2 ------ On
Movie-------- Off -------- On ------- Off ------- 2 ---------- 1 ------ On
Sports------- Mid -------- On ------- On ------- 2 ---------- 2 ------ On
Game-------- Off -------- Off ------- Off ------- 2 ---------- 2 ------ On
Standard----- Mid ------- On ------- On ------- 2 ---------- 2 ------ On
The NR features are on for every A/V mode. Optimum mode changes these settings depending on what the light/color sensor detects.
Also, there is no way in the SM to adjust these features.
Power Save Mode: Off
Standard mode settings
http://www.avsforum.com/avs-vb/showp...postcount=6311
Picture:
AV Selection: Standard
Contrast: 31
Brightness: +3
Color: -3 to -7 (you pick)
Tint: R4
Sharpness: -15
Pure Cinema
Film Mode: Advance
Text Optimization: Off
http://www.avsforum.com/avs-vb/showp...postcount=5496
Game mode has an 8K+ grayscale. Here are some "ok" settings with that mode:
Picture:
AV Selection: Game
Contrast: 30
Brightness: 0
Color: -4
Tint: R4
Sharpness: -15
Pure Cinema
Film Mode: Advance
http://www.avsforum.com/avs-vb/showt...a#post14144788
Picture:
AV Selection: Performance
Contrast: 30
Brightness: +4
Color: -4
Tint: R3
Sharpness: -15
Pure Cinema
Film Mode: Advance
This settings works amazing on my lx5090...thanks d-nice for your work
booleano is offline
post #11043 of 11070 Old 04-18-2016, 03:34 PM
makaveddie81's Avatar
Quoted: 413 Post(s)
Liked: 265
There are no "correct" values. Not only were the values specific to each panel, but the pulse meter reset that you performed on your set means that you would have to find settings from a display that was reset with around the same amount of usage hours as yours that has had those settings calibrated with professional equipment.
Not sure how much more clear I can put this but you need calibration equipment and software to be able to find the right values for your set.
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is offline
post #11044 of 11070 Old 04-18-2016, 05:56 PM
Coyote Waits
htwaits's Avatar
Quoted: 847 Post(s)
Liked: 1935
How about D-Nice or UMR?
makaveddie81 likes this.
htwaits is offline
post #11045 of 11070 Old 04-19-2016, 07:26 AM
Quoted: 21 Post(s)
Liked: 0
Ok..which are the values for of panel rgb for lx5090?? is possible to post it please? thanks for all
booleano is offline
post #11046 of 11070 Old 04-19-2016, 03:40 PM
Coyote Waits
htwaits's Avatar
Quoted: 847 Post(s)
Liked: 1935
Sorry. I don't understand.
I'm suggesting the two most qualified calibrators that I know of with extensive Kuro experience. If you're interested in their work check post two of the link on owner's reports at the bottom of my post. Links to those comments are in order of manufacture, model, and the calibrator's AVS user name.
Good luck.
gus738, makaveddie81 and booleano like this.
htwaits is offline
post #11047 of 11070 Old 04-19-2016, 03:47 PM
gus738's Avatar
Quoted: 56 Post(s)
Liked: 32
I second d-nice values .
Pioneer Elite PRO-111
Samsung 60PnF5300 af
panasonic px75u(r.i.p)Samsung 51f4500
XBL x117x831
PS4 gusx831
gus738 is offline
post #11048 of 11070 Old 04-19-2016, 04:52 PM
Quoted: 413 Post(s)
Liked: 265
Plugging in the values wont work because he reset his pulse meter, therefore he reset the aging algorithms for the service menu RGB values.
He needs to either calibrate his set or hire someone to do it.
post #11049 of 11070 Old 04-19-2016, 09:42 PM
buttonsw's Avatar
Quoted: 34 Post(s)
For accurate RGB numbers you will need to calibrate it yourself with a meter as you already have Controlcal or hire a pro to perform the calibration.
If you want a ballpark figure for RGB Settings on a reset Kuro my 500A has Blue + 50ish and Red -40ish so try:
Red High - 460
Green High - 500
Blue High - 550
These might be totally off on a 5090 but maybe worth trying, also remember to adjust the RGB's on each frequency:
60v
50v
75v
72v
If you want your white balance accurate you need to get it calibrated.
booleano likes this.
Pioneer KRP-500A | Sony STR-DH810 Receiver | Tannoy HTS101 Speakers
buttonsw is offline
post #11050 of 11070 Old 04-20-2016, 09:27 AM
Quoted: 21 Post(s)
Liked: 0
Red High - 460
Green High - 500
Blue High - 550
60v
50v
75v
72v
How can i calibrate my white balance buttonsw?? i see in sat tv very white levels.
I set r high to 504, g high to 508 and b high to 500 and is quite good for my lx 5090.
Sorry if i ask sometimes silly questions, i would like to learn...thanks for the help
booleano is offline
post #11051 of 11070 Old 05-03-2016, 01:20 PM
Quoted: 21 Post(s)
Liked: 0
Good luck.
I'm looking for d-nice work for lx5090 to try those settings in the list below of bottom of your post but i cant find any post to try..can you help me please? sorry for these silly question, i just learning
booleano is offline
post #11052 of 11070 Old 05-03-2016, 02:47 PM
Coyote Waits
htwaits's Avatar
Quoted: 847 Post(s)
Liked: 1935
Only the comments of the owner after having a professional calibration are posted. D-Nice has posted settings for the Pioneer sets that he owns, but he never posted settings from any other Pioneer sets that I'm aware of.
htwaits is offline
post #11053 of 11070 Old 05-04-2016, 09:29 AM
Quoted: 21 Post(s)
Liked: 0
standard mode
I'm trying to use standard mode in my lx5090 to use it in sat tv. I was trying d-nice settings in isf day and night of 111fd but it's darker than standard mode...which are best settings for sat tv ? thanks in advance
booleano is offline
post #11054 of 11070 Old 05-04-2016, 11:24 AM
dsskid's Avatar
Quoted: 253 Post(s)
Liked: 254
Why not just pay for a professional calibration?
ISF Calibrator
Samsung PN64F8500
Pioneer Kuro Elite Pro-111FD
Pioneer Kuro BDP-320
Displays are like 100% cotton t-shirts. Always buy a size larger than you think you'll need, as they tend to shrink over time.
dsskid is online now
post #11055 of 11070 Old 05-04-2016, 11:53 AM
Quoted: 21 Post(s)
Liked: 0
Bacause i live in Spain
Enviado desde mi iPhone utilizando Tapatalk
booleano is offline
post #11056 of 11070 Old 05-04-2016, 01:00 PM
Coyote Waits
htwaits's Avatar
Quoted: 847 Post(s)
Liked: 1935
Sorry. I can't advise anyone on calibration methods. This is the 9G thread dedicated to owner calibrations where there may be some settings posted that might help. I can't think of anyplace else to look. Maybe one of the owner calibrators that have posted here can help.
htwaits is offline
post #11057 of 11070 Old 05-04-2016, 08:55 PM
ll Viper ll's Avatar
Quoted: 75 Post(s)
Liked: 56
Has anyone else gotten worsened buzzing after doing voltage adjustments? I wasn't too afraid of running my 5020 too hard bc I was getting a new oled but as soon as I did, my pioneer started buzzing like a hornet's nest.
It's coming from the back of the tv (obviously), the top center. Can anyone tell me if this is where the power supply is? Should I be worried about it failing soon? The buzzing isn't the normal kind which is mostly alleviated by using power save mode 2 but a whiny higher pitched one that's new, as far as I can tell.
Any help would be greatly appreciated
ll Viper ll is offline
post #11058 of 11070 Old 05-05-2016, 08:08 AM
Quoted: 21 Post(s)
Liked: 0
Try to decrease abl
booleano is offline
post #11059 of 11070 Old 05-05-2016, 08:48 AM
dsskid's Avatar
Quoted: 253 Post(s)
Liked: 254
SPAIN
Antonio Nuñez at HomeFUTURA - Spain
David Valencia at DIGITAL LUXE - Spain
also:
https://imagingscience.com/dealers.php?search=Spain
ISF Calibrator
Samsung PN64F8500
post #11060 of 11070 Old 05-05-2016, 09:55 AM
Quoted: 75 Post(s)
Liked: 56
So decreasing the abl control in the service menu will make the abl more aggressive, possibly reducing buzzing?
It was set at 98 by default. How much lower should I go?
post #11061 of 11070 Old 05-05-2016, 10:56 AM
Quoted: 21 Post(s)
Liked: 0
Try drive mode 2 and set abl to 00 to see default value and off tv and on after
booleano is offline
post #11062 of 11070 Old 05-05-2016, 12:30 PM
Quoted: 75 Post(s)
Liked: 56
I don't know how to change drive mode in the 5020's service menu (unless it's rtsp or whatever that one right next to vol sus is which you're supposed to keep at 1-3), and setting abl to 0 didn't work.
It wouldn't count it as a relevant value and reverted to whatever I had it at. Instead I just set it really low (like 8) but it didn't seem to make any difference. Maybe a slight difference in higher light output modes (as long as I kept energy save off) but the buzzing/whining I'm getting is even in movie/game mode which have low light output (so low as to not be affected, on my tv, at all by power save in terms of brightness, even on full white)
post #11063 of 11070 Old 05-06-2016, 10:24 PM
Quoted: 21 Post(s)
Liked: 0
Try xsus_b and ysus_b set to 125 or 124 to decrease buzzing. Look for 5020 default voltages and set it
booleano is offline
post #11064 of 11070 Old 05-15-2016, 11:58 AM
Quoted: 21 Post(s)
Liked: 0
Im sorry for ask this question again but im a littie worried because not im not using fans on my lx5090 and before reset it fan 1 i remember in 173 D/a mode...can i enable it in integrator mode?? thanks to all people and sorry if its not the thread to ask it...
booleano is offline
post #11065 of 11070 Old 05-21-2016, 12:22 AM
Quoted: 21 Post(s)
Liked: 0
Good morning... is normal 58º degrees on Kuro lx5090?? is normal temp?? thank for the help
booleano is offline
post #11066 of 11070 Old 05-31-2016, 01:28 PM
webdove's Avatar
Liked: 0
New 151FD calibrator
Greetings,
I own a 151FD panel (build month Dec 2008) with 10K hours on it ( I bought it new in 2009).
I had recently decided to ISF calibrate it.
I got controlcal and planned to use my i1pro rev d spectrophotometer.
I was able to get pure mode pretty close with HCFR (attached) before I started trying ISF modes.
I realized that I was going to have problems with low levels due to the noise and drift of the i1 pro.
So I ordered an i1display pro from Amazon. People seemed to say nice things about its sensitivity, speed, accuracy, repeatability.
Is that the best choice for a few hundred dollars?
I had a couple of other questions:
1. if the i1display has color filters that are matched to the human eye (CIE 1931 version) then why is it necessary to have a display specific CCSS color adjustment matrix to get the most accurate readings from the 151fd?
2. Why doesn't HCFR have an RGB levels display window that normalizes (divides) by the target RGB level rather than normalizing by the measured luminance. Such a display would be much more helpful for hitting RGB targets. (perhaps it does, and I have not yet found it )
webdove is offline
post #11067 of 11070 Old 07-15-2016, 09:26 AM
saprano's Avatar
Quoted: 502 Post(s)
Liked: 483
To that person that wanted more vibrant whites. Change the color temperature to mid. There's your LCD whites. You'll get more light output too.
(sorry, i forget your name. You helped me with the color sensor thingy)
home theater addict
saprano is offline
post #11068 of 11070 Old 07-15-2016, 10:41 AM
Quoted: 292 Post(s)
Liked: 154
The whites on my set are just fine as long as the source is good. I only see the infamous "dirty Plasma Whites" on lower quality sources and I don't think that's the Kuro's fault really. I was watching that movie Everest the other day, not great but enjoyable I guess and there is a lot of white in that one and everything looks totally clean and white just like an LCD would.
Vader1 is online now
post #11069 of 11070 Old 07-21-2016, 08:10 AM
Khran's Avatar
I have been running my Pro-141FD for a number of years as a monitor.
After some troubleshooting I have come to the conclusion that my source PC has stopped passing through the display. When I try to install my videocard driver and it tries to change the resolution to 1080p my monitor goes black. The strange part is it passes through the image to a standard monitor and also pass through the image if I change source from PC to Video on the Pro-141FD...
I have been running through the PC source for years which is strange.
Now that I am running through Video I was wondering if there are recommended settings for PC Gaming in Video mode on the Pro-141FD?
Khran is offline
post #11070 of 11070 Old 07-21-2016, 05:35 PM
Quoted: 1434 Post(s)
Liked: 1123
Hey, me too, but in 3D. OT, but it's the kind of showcasing of the format (coupled with the right display) that shows the format is more than a gimmick.
video_analysis is offline
