The Official Pioneer 9G Kuro Settings/Issues Thread - Page 370 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #11071 of 11084 Old 09-05-2016, 02:31 PM
toran0x's Avatar
Through a bit of randomness and luck, I now have a pre-owned 151FD (Aug 2008). I plan on trying DNice's settings, but I don't know if it's one of those with the "green" issue. Is there any way to tell? I'll use it mostly for movies via Netflix and gaming on my PS4 and xbone. Thanks.
toran0x is offline
post #11072 of 11084 Old 10-10-2016, 11:56 AM
LowBattery's Avatar
My 6 year old 101FD recently started making a crackling/static-like noise from the back panel.
The picture quality is unaffected and adjusting the settings do nothing to change the abnormal sound.
I did a search and found some similar experiences, but no conclusive solution.
Anyone have an idea of what the problem might be?
LowBattery is offline
post #11073 of 11084 Old 10-10-2016, 12:19 PM
saprano's Avatar
Quoted: 540 Post(s)
Liked: 527
I read around about that too since i was having the same crackling sound. Arcing is the reason why it's doing that. It had me worried a little but reading a post from somebody with the same issue made me relieved because he said it went away eventually. That's exactly what happened.
home theater addict
saprano is offline
post #11074 of 11084 Old 10-10-2016, 12:52 PM
spongebob's Avatar
Quoted: 38 Post(s)
Red Blacks
Again I ask how to get rid of the reddish black in some scenes?
bob
spongebob is offline
post #11075 of 11084 Old 10-12-2016, 02:38 PM
Dave_6's Avatar
Quoted: 26 Post(s)
Is D-Nice (or anyone) still calibrating these? I was going to get him to do my 6020 a few years ago and never got around to it
PSN: DaveS78
Dave_6 is online now
post #11076 of 11084 Old 10-13-2016, 10:34 AM
Quoted: 31 Post(s)
Liked: 0
Rgb High and low
At the momment , my defaut values for RGB high and low for my krp-500a are:
R high 511
g high 502
b high 500
all low values are set to 500
Is there any optimized values for rgb? im using a krp500a
Thanks for all of your help , a greeting
booleano is online now
post #11077 of 11084 Old 10-13-2016, 04:08 PM
makaveddie81's Avatar
Quoted: 473 Post(s)
Liked: 273
R high 511
g high 502
b high 500
You can obtain optimized values for these settings by performing a calibration using a meter and software.
booleano likes this.
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is offline
post #11078 of 11084 Old 10-14-2016, 12:06 AM
Quoted: 31 Post(s)
Liked: 0
Thanks makaveddie for your help but I havent got a meter...could anyone with a krp 500a post it's values please? Thank you so much. A greeting
Enviado desde mi iPhone utilizando Tapatalk
post #11079 of 11084 Old 10-15-2016, 03:47 PM
Quoted: 31 Post(s)
Liked: 0
Setting very near of my krp 500a I see the image foggy... I don't know why...is it normal? Is there any voltage to clean the image?? Settings not near the krp this is not appreciate... Is it norma in plasma TV? Sorry for this silly question but I would like to have a clean image if it's possible, thanks in advance
post #11080 of 11084 Old 10-17-2016, 05:30 PM
Quoted: 473 Post(s)
Liked: 273
Like ISF calibration settings, plugging in values from another TV is not a good idea. You need a meter and calibration software to determine the optimal values.
post #11081 of 11084 Old 10-18-2016, 01:47 AM
Coyote Waits
htwaits's Avatar
Quoted: 924 Post(s)
Liked: 2042
Yes. You can use the two links at the bottom of my post for information. All owner reports about their calibrations are organized by manufacturer, model, and the AVS user name of the calibrator. UMR and D-Nice have both worked on my 6010. D-Nice did a new calibration after I had to replace the main board.
htwaits is offline
post #11082 of 11084 Old 02-21-2017, 03:12 AM
Liked: 0
I recently aquired a Kuro 5090h.
Everything was working fine (only some buzzing that I got used too) until I bumped the screen against a wall while I was doing cable management.
Now my Kuro has half of a vertical subpixel (red) line dead
I have heard of vertical lines but those go usually from the top to the bottom, but in my case it stops at the center...
It would be great if someone would be so kind as to shed a light on what the problem might be.
I have searched the web to no avail, I mostly seem to find answers to problems like this on Samsung plasmas (but always full vertical lines) that can be solved by cleaning the ribbon cables, but I have no idea if the built techniques are the same with the Kuros.
Do Pioneers even have ribbon cables that might get loose and that I could try to adjust to solve this problem?
I atached a picture of the problem to this message.
The quality of this set is so amazing. I really wish this issue was fixable
SarilhosGrandes is offline
post #11083 of 11084 Old Today, 02:52 AM
FreMo's Avatar
Quoted: 62 Post(s)
I have a Kuro 5090 and I can't have smooth travelling. That is the main reason for which I want to change my TV for OLED. For instance, when playing the opening scene of X-Men Apocalypse on blu-ray (the vertical travelling on the sand dunes) with both Oppo 103D and 203 players, the motion is not smooth and full of judder effects. Have I a wrong setting? (I'm on advance cinema mode).
FreMo is offline
post #11084 of 11084 Old Today, 08:50 AM
galthor's Avatar
Hi
Same static/electric sound ; my repair shop change few electronicals pieces on 2016 (October). Sound disappeared.
But come back last week ... I wait for his new diagnostic ...
galthor is online now
