Horizontal storage of plasma display - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-19-2008, 09:03 PM - Thread Starter
Bongo's Avatar
Apologies in advance that this topic has been touched on before in numerous threads. However, I haven't seen what I would consider to be a straight answer.
For an office application, I am planning on storing a 50-52" panel (plasma or LCD) in a swing-down ceiling-mounted lift--i.e., the panel is stored flat most of the time).
  1. Does this pose any problem for plasma in terms of (a) total failure; (b) performance; (c) useful life?
  2. Are there any issues with powering on the plasma immediately after swinging it down, or swinging it up immediately after powering it off?
  3. If someone forgets to turn off the display prior to swinging it up, and it is powered while in a horizontal position, would that cause any problems?
(If you have any views for LCDs to the extent that the answers differ from those for plasmas, I would be grateful.)
Thanks in advance
Bongo
Bongo is offline
post #2 of 4 Old 08-19-2008, 09:42 PM
skeelo58's Avatar
I'm not quite sure I understand your question.... What do you mean by swinging it down? Is it going to be going from flat on the wall, to hanging upside down (like if it were on the ceiling?)
skeelo58 is offline
post #3 of 4 Old 08-19-2008, 09:56 PM - Thread Starter
Bongo's Avatar
It will be stored flat inside the ceiling (with the screen facing up) when not in use, and will swing down though a 90° arc to be vertical when in use (actually, 95° to be slightly down-facing).
Bongo is offline
post #4 of 4 Old 08-23-2008, 06:20 PM - Thread Starter
Bongo's Avatar
Anybody know about this?
Bongo is offline
