Signature Elite 141 Owners Thread - Page 157 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 02-23-2010, 10:38 PM
Tmankiller72's Avatar
I will have my 141fd calibrated by Doug Weil on Monday 3-1 Thanks for all your help.
Tmankiller72 is offline
Old 02-25-2010, 07:30 AM
kmak's Avatar
where's the runco guy?
kmak is offline
Old 02-25-2010, 07:34 AM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
You could search the thread for Runco or Sony324 or just look back a few posts. Unless you mean physical location.
bodosom is offline
Old 02-25-2010, 08:44 AM
Sony324's Avatar
I'm still here. I have to wait for my dealer to install it. It's still in its box strapped to a skid right now... I will be ordering the compatible mount and having the dealer install it and ISF it at the same time... probably in the next few weeks.. I'll keep you guys posted.
Sony324 is offline
Old 02-25-2010, 02:05 PM
kmak's Avatar
Hey Sony you're back! I'd be climbing the walls if I had to wait that long.
So you're in Ontario too..........
kmak is offline
Old 02-25-2010, 02:30 PM
orologio's Avatar
Quoted: 31 Post(s)
Is it normal that the pure mode settings reset by itself? Is there a way to lock them?
orologio is offline
Old 02-25-2010, 02:56 PM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
Originally Posted by orologio View Post
1) Is it normal that the pure mode settings reset by itself? 2) Is there a way to lock them?
1) Not normally.
2) No.
Originally Posted by the KRP FAQ View Post
Q. My settings are reverting to default/My settings reverted to default/One of my settings reverted to default -- why?
a. There are a few common causes for this.
  1. Reset will restore all settings to factory default.
  2. Per resolution effects often look like random resets. Settings are per signal type and some sources change according to content. E.g. a DVR that supports native channel resolution.
  3. Integrator mode resets all settings per page 12 of the Integrators manual.
  4. Memory overflow will cause the ninth set of settings to push out the first. Referenced here -- probably sourced from page 24 in the Integrators manual.
Q. Signal type?
a. Non-ISFccc settings are stored per input and per signal type where the signal type is characterized by colorspace (YUV/RGB), resolution (1080p/720p/etc.) and framerate(60/24). ISFccc settings are stored per input.
bodosom is offline
Old 02-25-2010, 04:18 PM
orologio's Avatar
Quoted: 31 Post(s)
Originally Posted by bodosom View Post
1) Not normally.
2) No.
You are a saint... Thanks
orologio is offline
Old 02-27-2010, 08:42 AM
pcarel's Avatar
Can anyone recommend a good starting point for my settings. I just want a good basic setup for now and then maybe have my set pro calibrated in the future. I read the Home Theatre Magazine review for the pro 141 and reviewer posted his settings. Should I use those ? Thanks; pcarel
pcarel is offline
Old 02-27-2010, 09:19 AM
spongebob's Avatar
Quoted: 38 Post(s)
I read that article and wonder what is meant by:
"ISFccc provides a 10-step color-temperature adjustment rather than just high and low. However, in practice, I found the Manual Color Temp adjustment menu more than adequate to get an outstanding setup."
What is "10 step"?
bob
spongebob is offline
Old 02-27-2010, 09:54 AM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
A good starting point is to get the Spears and Munsil HD Benchmark disc and make adjustments appropriate to your environment and panel.
I recommend against simply copying settings.
Of course it does depend on your end goal.
bodosom is offline
Old 03-02-2010, 09:48 PM
Lattimer1's Avatar
Just Got my PRO-141FD delivered today from FED-EX Freight. I want to say a big....huge.....gigantic.... thank you to a MIKE WEEKS at MAGNOLIA in Bucktown Illinois. If you are in need of anything and live in that area then hit him up, and if not call the bucktown store and ask for him and tell him Marcus sent you. He was an amazing genuine guy loving what he does, and it obviously showed as he went way above to help out my home theater craving lol. He really came through and after a few snags here and there, the dream came true and I actually have it in hand. By the way it was shipped yesterday around 5pm from Bucktown and arrived at my house in MN this afternoon around 2pm, not even twenty four hours later....amazing shipping. Yes this is a brand new never been used in the box PRO-141FD. This might have been the last one remaining in the US of A, but maybe not??? Weird thing to add is that Pioneer said they quit manufacturing in Feb. or March 2009?, but mine said it was manufactured in April of 2009?? Just thought that tidbit was interesting. Anyways what an exciting day it was !!!!!!! Take Care everyone and keep enjoying home theater as it just keeps getting better and better and better!!
Lattimer1 is offline
Old 03-02-2010, 10:03 PM
wvick's Avatar
Congrats and enjoy the best TV ever made! Mine is also an April 2009 build.
wvick is offline
Old 03-02-2010, 10:40 PM
Lattimer1's Avatar
Thanks and enjoy yours as well.....go April builds LOL !!!
Old 03-03-2010, 07:54 AM
HuskerHarley's Avatar
Quoted: 33 Post(s)
Liked: 26
After months of fighting TWC's terrible signal and always experiencing Jaggies and Pixelating (that's what I call it) on medium to fast motion, I'm thinking if I swap out HDMI and replace with Component it will eliminate some or maybe all of the motion problems.
Before I get behind my equipment and tear it apart/replace cables,,What do you think my chances are of improving/eliminating the problem & will there be much of a difference in overall picture quality due to downgrading to Component?
HH
HuskerHarley is offline
Old 03-03-2010, 07:56 AM
spongebob's Avatar
Quoted: 38 Post(s)
What is "10 step"?
bob
Bump? Anyone? What is 10 step colr temp??
thx
bob
Old 03-03-2010, 12:13 PM
wrinklefree's Avatar
thx
bob
Bob,
Normally when you adjust the RGB offsets you get to play with 2 sets of controls, the low and high.
The 10 step color temp control means you can adjust the RGB at 10 different points such as 10% IRE all the way up to 100% individually. This is great for sets that have poor grayscale tracking.
The Kuro's are not of those sets however as they tracking amazingly flat making this feature practically unnecessarily.
wrinklefree is offline
Old 03-03-2010, 02:59 PM
spongebob's Avatar
Quoted: 38 Post(s)
Originally Posted by wrinklefree View Post
Bob,
Thanks, James
Where is that in ControlCal?
thx
bob
Old 03-03-2010, 07:02 PM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
Thanks, James
thx
bob
I don't know where you are getting 10 point, however most ISF calibrators use 11 point Data to set the grayscale. What you would input in controlcal is H/L Green, Red, Blue.
There is a 9piont gamma but I wouldn't play with those settings, as well as green in your grayscale ( man temp settings)
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
Old 03-03-2010, 07:39 PM
spongebob's Avatar
Quoted: 38 Post(s)
ss
Wrinkle is a calibrator so I hope he can clear that up, then!
thx
bob
Old 03-03-2010, 07:43 PM
stevec325's Avatar
ss
Peter, have you touched up your 141's calibration recently? I put about 1000 hours on mine since I did it and was wondering if it would be worth the effort to break out the stuff and take a look now - or wait another 1000 hours?
It still looks great, but I could be just used to it and not notice the "little things".
-steve
My HT Setup - updated 12/25/2012
"...and all the science, I don't understand. It's just my job, five days a week."
stevec325 is offline
Old 03-03-2010, 09:15 PM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
The Norton review he quoted in HT Magazine has an error regarding ISFccc gamma adjustment.
bodosom is offline
Old 03-03-2010, 09:28 PM
jvvjvv's Avatar
Hi...........Replaced my Pano plasma with a 141............what a wonderful picture. One problem..........the subtitles are mostly off the screen. I have an Oppo player and have checked and reset the settings on it, as well as the settings on the 141. Moving the subtitle location all the way up with the Oppo settings "seemed" to help a little. Obviously worse on the zoom settings............(actually can't see the subtitles at all)..........so what gives??
What am I missing??
Jack
jvvjvv is offline
Old 03-03-2010, 10:41 PM
Thanks, James
thx
bob
Hit the drop down box and select a point from 1-9 to fine tune the temp using an offset slider, or move all 3 sliders in unison to change the luminance and gamma at that point.
You normally don't need to mess with these settings however.
Old 03-03-2010, 11:10 PM
spongebob's Avatar
Quoted: 38 Post(s)
So if I had a red 'Hump" only at 40%, I would pick gamma point 4 and adjust the red gamma down?
BTW, do these gamma settings over ride the hi/lo rgb settings?
thx
bob
Old 03-04-2010, 05:10 AM
sillysally's Avatar
Quoted: 829 Post(s)
Liked: 850
thx
bob
Excuse me, I am sure I have used Controlcal longer than most anybody on a 141.
Not many calibrators have better hardware and software than I do for Kuro's ISF Calibration.
I was train by D-Nice and Jeff (AccuCal) so I don't think there are any better Calibrators than them.
But don't worry I am not going to give you anymore of my lowly advice.
And please don't PM anymore asking for my advice.
And guess what my post did clear it up. And btw that is for your gamma not temp, that's why it says Gamma. The drop down box (Gamma) is after you set ISF night or day for what ever input you are using for your settings, after entering all your settings including Gamma (don't Use) you must hit save calibrations button.
Old 03-04-2010, 07:34 AM
spongebob's Avatar
Quoted: 38 Post(s)
Don't worry be happy!
Old 03-04-2010, 07:39 AM
bodosom's Avatar
Quoted: 206 Post(s)
Liked: 68
No.
Please consider starting a thread in the calibration area after you read the Spears and Munsil guides, Tom Huffman's guide, Kal's guide and the CalMAN help files.
bodosom is offline
Old 03-04-2010, 07:46 AM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
thx
bob
You should not be using the gamma controls to correct grayscale errors.
D-Nice is offline
Old 03-04-2010, 09:59 AM
RJVR23's Avatar
So last night after watching a movie I turned my PS3 and receiver off, walked closer to the TV to turn it off and noticed that I have image retention It was from the Street Fighter 4 video game.
It's just the monitor that's on so there is no signal but there it is on the bottom and top where the "Super" and "Health" bars are displayed. I only see it when it's just the monitor on, when I turn it off it goes away.
I got this set December 09 and I ran the break in slides for 150 hours. I've been playing SF4 since December for about 2 hours about 4 times a week. I did not have the orbiter on.
I ran the video pattern twice last night and twice this morning. Afterwards the only time I can make it out is when the white bar is going accross the screen in the video pattern.
Serves me right for playing SF4 hours at a time without running the video pattern afterwards
Crossing my fingers and hoping it goes away completely, wish me luck guys
Is there anything else I could do besides running the video pattern to help get rid of the image retention?
Also should I set the orbiter to 1 or 2?
Thanks in advance
RJVR23 is offline
