Panasonic TH-50PX60U Shut Down LED blinks 5 times - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 09-10-2008, 06:06 PM - Thread Starter
Gwest's Avatar
I have a TH-50PX60U I purchased in November 2006. It recently started shutting off on it's own. It can be turned back on after I hold down the power button for a few seconds to reset it, and then turn it back on.
The LED next to the power button blinks 5 times. Any idea what the cause is?
Gwest is offline
post #2 of 16 Old 09-10-2008, 06:37 PM
omeletpants's Avatar
omeletpants is offline
post #3 of 16 Old 09-10-2008, 06:41 PM
moematthews's Avatar
Wow - great that Panasonic builds that kind of failure identification into their TVs, but I guess it's not so good when you're the one watching the blinks and it's out of the warranty period
Curious - do other manufacturers do the same thing?
moematthews is offline
post #4 of 16 Old 09-10-2008, 06:51 PM
Sure, it helps their tech identify problems quickly
post #5 of 16 Old 09-11-2008, 04:30 PM - Thread Starter
Gwest's Avatar
Thanks! I will assume, and I hate doing that, that there codes are pretty standard across the different plasma models.
Gwest is offline
post #6 of 16 Old 09-11-2008, 04:45 PM - Thread Starter
Gwest's Avatar
After the tip above, I did a google search on "5v SOS D Board", which could be my problem area based on the 5 blinks.
The results of the search.
A bunch of technical trainings from what looks to be Panasonic are available. It talks about a lot of the blinking errors for different generation plasmas from panasonic.
Looks like a pretty good reference for problems.
Gwest is offline
post #7 of 16 Old 09-11-2008, 05:43 PM
BruZZi's Avatar
It is...
http://www.bruzziforum.com/vbf/showthread.php?t=79
__________________________________________________ _
Samsung 55KS800 • Pioneer Elite VSX-90TXV • Oppo BDP-103D
Paradigm Studio 10's • Paradigm Studio CC-490 • Sunfire HRS-8
BruZZi is offline
post #8 of 16 Old 12-31-2008, 01:38 AM
uenwesi's Avatar
I have a TH-50PX60U that will not turn on. The LED next to the power button blinks 10 times. Any idea what the cause is?
uenwesi is offline
post #9 of 16 Old 12-31-2008, 07:49 AM
screwpanny's Avatar
After not being on for a week I return home and turn on my 50panny plasma, it runs for a few min then shuts down with the 5 blink code. How do I resolve this? Should I take it in to get it repaired? How much should it cost? Thanks for your help!
screwpanny is offline
post #10 of 16 Old 12-31-2008, 08:14 AM
Google "10 blinks panasonic"
post #11 of 16 Old 12-31-2008, 08:26 AM
BWDinc's Avatar
in the 42 its the pa and h board
BWDinc is offline
post #12 of 16 Old 12-31-2008, 09:44 AM
screwpanny's Avatar
I just called Abt electronics where I purchased the tv to see if I could drop it off today, and apparently they looked me up and said I purchased a 4 year warranty! I don't remember doing this but I'm not going to argue about it, so they are sending some people to my house to see if they can fix it. Now I know why I always buy my tv's (4 plasma's so far!) from them. I will keep you updated on what the 5 blinking lights what it means and how to fix them.
post #13 of 16 Old 05-16-2009, 09:52 AM
digidog00's Avatar
I had the "5 blinks of death" issue last night. Chatted with the panasonic concierge but they said call a repair man. I bought mine Dec. 06. Fortunately, I got the extended 3 yr warrenty (Which I never buy...)
Looks like a 5V SOS D Board issue. Repair man will be here Monday.
digidog00 is offline
post #14 of 16 Old 06-24-2011, 08:52 PM
sheecatt's Avatar
I just had the 5 blinking lights situation occur on the same tv on 6/20/11, after years since buying it new in 2007. I just had a tech come by today and diagnose the problem. Just in case anyone out there is having the same problem on this same model...the 5 blinking lights mean the power supply board needs to be replaced. Not an expensive part. Love this TV!
sheecatt is offline
post #15 of 16 Old 01-08-2012, 08:12 PM
jzhang2007's Avatar
How much did it cost you to fix? I have the same model and the same problem.
jzhang2007 is offline
post #16 of 16 Old 03-15-2013, 03:29 PM
samnman's Avatar
i pulled my d board my self and sent it out to a guy on ebay and had it rebuilt for like $100 easy to pull the boards its all just screws n a couple of wire clips u can find the location of all the boards on panasonics website plus it gives you a chance to clean out 5-8 years of dust but has worked great for about 2 years or more now
samnman is offline
