50PNA550 or PDP5080HD - Which one should I choose? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-26-2008, 11:46 AM - Thread Starter
kes98's Avatar
Please help me decide whether to keep my PDP5080HD or get the Samsung 50PNA550. Both units cost about the same, I currently have the 5080 and could return it and get the 50PNA550 for $50 less.
kes98 is offline
post #2 of 6 Old 09-26-2008, 12:47 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
Why are you considering returning the 5080? That's a high end set and the 550 is really just mid-range.
There are ways in which the 550 is better (resolution and color accuracy), but I think most likely you'll be happier with the 5080.
How close do you sit to the TV?
chrisherbert is offline
post #3 of 6 Old 09-26-2008, 01:00 PM - Thread Starter
kes98's Avatar
I'm sitting about 9 feet away from the TV.
kes98 is offline
post #4 of 6 Old 09-26-2008, 01:04 PM
Albo23's Avatar
Keep the 5080.
Albo23 is offline
post #5 of 6 Old 09-26-2008, 01:19 PM
bflip1080's Avatar
Originally Posted by Albo23 View Post
Keep the 5080.
+1
if you are concerned about color accuracy then get the pio calibrated. I really don't see what reason you have for wanting to get a 550 when you have a kuro. Less depth, less detail, worse blacks, super reflective screen. It just doesn't make sense. Professional reviewers still picked this over other 1080p sets in a blind test and most said that at your distance the 5080 had more detail anyway.
http://www.hometheatermag.com/lcds/2...ce/index7.html
"But if you didn't know the test set was 768p and not 1080p, you would never guess. And no one on the panel did".—Tom Norton (That was at a distance of 8ft(4X the screen ht)
please explain why you are thinking about getting the 550.
Beauty, thy name is KURO.
bflip1080 is offline
post #6 of 6 Old 09-26-2008, 01:23 PM
Quoted: 17 Post(s)
Originally Posted by bflip1080 View Post
+1
if you are concerned about color accuracy then get the pio calibrated. I really don't see what reason you have for wanting to get a 550 when you have a kuro. Less depth, less detail, worse blacks, super reflective screen. It just doesn't make sense. Professional reviewers still picked this over other 1080p sets and most said that at your distance the 5080 had more detail anyway.
While I think that the 5080 is better, let's be fair to the 550. First, it will have a more detailed picture than the 5080 -- more than twice as detailed, as a matter of fact. From nine feet, chances are that doesn't matter, and there's a whole lot more to picture quality than resolution. Still, the 550 is more detailed.
Also, no calibrator can get the 5080 to have color as accurate as the 550. It's just not possible.
