Does anyone use a monoprice wall mount? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 359 Old 03-16-2009, 05:11 PM
daMaster's Avatar
Originally Posted by Konowl View Post
I want to hang my TV in the middle of my living room wall, and there is a stud RIGHT in the centre of the wall. Problem is, the studs are 20 inches apart, so I won't be able to hit two studs with the mount if the mount is centered. I'm new to this... but when you put the tv on the mount itself, does it have to be perfectly centered or can it be moved to one side or the other...
You could use plywood boards as an intermediate between the wall plate and the wall studs. See my post here for pics and some details: http://www.avsforum.com/avs-vb/showt...6#post15803386
daMaster is offline
post #272 of 359 Old 03-16-2009, 10:15 PM
Konowl's Avatar
TV is only 42 inches wide
I do plan to go bigger down the road, but not yet.
Konowl is offline
post #273 of 359 Old 03-16-2009, 10:24 PM
Konowl's Avatar
Originally Posted by eddie501 View Post
Im confused. Are your wall studs 20" or 24" apart?
If you studs are 20 inches apart you could use Monoprice mount 3401 which has a wall plate that is 45" wide. At 20" stud spacing you could hit three studs if you are centered on the middle one.
They're 20.
Konowl is offline
post #274 of 359 Old 03-21-2009, 06:00 PM
ehyo's Avatar
well apparently i'm the worst handyman of all time. i was mounting my 3900 mount, and use a snapped those huge lag bolts while i was tightening it with a socket wrench!
ehyo is offline
post #275 of 359 Old 03-22-2009, 06:39 AM
jaly's Avatar
I did not have any problems, but I did spray some lubricant in the holes before tightening the bolts.
jaly is offline
post #276 of 359 Old 03-22-2009, 06:45 AM
de8212's Avatar
Quoted: 286 Post(s)
Did you pilot drill the holes?
Not that it helps now but I replaced all the lag bolts from the kits with some from Home Depot. Only a dollar or two more for 6 or 8. You could just drill more holes up/down from the ones that broke off. In the end they will be hidden, right?
de8212 is offline
post #277 of 359 Old 03-22-2009, 09:57 AM
PrimeTime's Avatar
Quoted: 556 Post(s)
Liked: 264
I would recommend non-plated lag bolts, as some of the plated ones are much weaker and can snap. Especially if you don't use a large enough pilot drill beforehand.
PrimeTime is offline
post #278 of 359 Old 03-22-2009, 12:22 PM
ehyo's Avatar
i did drill some holes prior, but i guess they werent deep enough, as the bolt snapped at the very end as i was tightening it up. i guess i got to get myself a bigger drill bit
ehyo is offline
post #279 of 359 Old 03-22-2009, 04:54 PM
K9feces's Avatar
Hey guys, I am planning to mount a 42 inch panasonic plasma, at my dads house. Do the monoprice low profile give you enough room to plug in the HDMI cables? Do the kits come with spacers and lag bolts like other brands do?
K9feces is offline
post #280 of 359 Old 03-23-2009, 07:41 AM - Thread Starter
fireman325's Avatar
I used a tilting model, but based on how much room is behind it, you should still have plenty of room for HDMI connections behind a low profile mount. If you think it will be too tight, you can always use this or this. And yes the mounts include spacers and lag bolts. A lot of people opt to use bolts from Home Depot or Lowes instead, but I used the ones that came with the mount. If you drill proper pilot holes, you shouldn't have any problems with them.
Steve
fireman325 is offline
post #281 of 359 Old 07-27-2009, 08:57 AM
khle77's Avatar
I just installed the 3725 with my Pioneer 5020 and I did notice a sag. After reading this thread, I've decided to contact Monoprice to see what they have to say about it. Here's what Tech Support had to say:
Please wait for a site operator to respond.
You are now chatting with 'TS - Tjayi "Chay" M (Level 1)'
TS - Tjayi "Chay" M (Level 1): Thank you for contacting Monoprice Tech Support. My name is Tjayi. How may I be able to assist you?
you: hi
TS - Tjayi "Chay" M (Level 1): hello how may i help you today?
you: i purchased a tv mount from monoprice
you: after the installation i noticed the the arms were sagging
TS - Tjayi "Chay" M (Level 1): i see do you have the product id number of the mount you purchased
you: yes, 3725
you: the wall plate looks good and it is flush into the wall...the arms are a bit worrying since it is sagging
TS - Tjayi "Chay" M (Level 1): the nature of the mount is to flex and rebound allowing it to absorb shock more effectively and protecting the display in the event it gets bumped. That same quality will mean that larger and heavier displays will have a tendancy to sag downward especially with mounts with more complicated mechanism like those found on our tilting/swiveling designs. The forward tilt can be easily compensated for by tilting the display upward and locking it in a position that hold the screen level.
you: ok
you: thank you for the reassurance
TS - Tjayi "Chay" M (Level 1): np
TS - Tjayi "Chay" M (Level 1): Is there anything else I can help you with?
you: it's hard to swallow if a $2000 tv falls into the ground
you: that will be all
you: have a nice day
TS - Tjayi "Chay" M (Level 1): Thank you for shopping at Monoprice. Have a nice day.
you: you too
Please let me know what you think,
Khai
khle77 is offline
post #282 of 359 Old 07-27-2009, 11:37 AM
Monoprice_01's Avatar
Hi Khle77,
Some sag is normal as mentioned. However, if it seems extreme or the joints are loose, it may need to be adjusted or replaced. Send us a photo to tech@monoprice.com and we'll let you know if the sag you are experience is normal.
Howard
Tech Support
Monoprice_01 is offline
post #283 of 359 Old 07-27-2009, 05:12 PM
daMaster's Avatar
Originally Posted by Monoprice_01 View Post
Hi Khle77,
Howard
Tech Support
Wow, it's great to see Monoprice coming on here and answering user questions!
My 3725 mount works great and all the cables I've purchased from Monoprice are awesome and have saved me hundreds of dollars! Thanks Monoprice!
daMaster is offline
post #284 of 359 Old 07-27-2009, 07:07 PM
avnuttyguy's Avatar
Hi Khle77,
Howard
Tech Support
Are you kidding ME? Really? No way would I trust that to be OK. I've posted months ago the Monoprice mounts do not have any agency certification to test for quality of materials and manufacturing standards, like UL or ETL.
I won't go down that path with the folks who slammed me for my last comments in March, but I will state my opinion after researching and asking specific question to monoprice regarding the claims they make for weight they are only speculative, nothing more and no assurance monoprice will back up any damage claim if it fails. I've read too many threads with people saying the "low price" mount are good value, but they sag or the bolts break, for whatever reason and not to use the bolts and go to HD and buy better ones. REALLY? Good luck to you all who want to save a few bucks on a mount that might, yes I said MIGHT fail. Not me, I spent the few buck more for my Sanus to hold my expensive TV on the wall!
avnuttyguy is offline
post #285 of 359 Old 07-27-2009, 08:09 PM
daMaster's Avatar
My 3725 Monoprice mount is rock solid with very very little sag. It's been supporting my 125 lbs Panasonic 58" PZ800U for over 6 months now and hasn't budged.
I just rechecked all my floor-to-screen measurements and the leveling of my TV (both horizontal and vertical) and everything is still exactly as it was when I first installed it over 6 months ago. If that's not stable, rock solid, and reliable then I don't know what is!
daMaster is offline
post #286 of 359 Old 07-28-2009, 08:41 AM
Probe 2C's Avatar
Hopefully you didn't use the bolts that came with your fancy Sanus mount.
http://www.amazon.com/Sanus-VMDD26B-.../dp/B000BYCNMS
The Design is great and exactly what i needed. It's got a very easy brainless setup but the LAG bolts were really cheap. I went and spent 3.86 on new lagbolts and asked amazon compensation! I broke 2 of the lag bolts just ratcheting them. They literally snapped off! I've never EVER had this with a lag bolt, ever. So that's my advice. If you buy this item spend about 3-4$ for higher quality lagbolts. Other than that it's a great item but because i got inferior quality bolts i can't give this item any higher than 3 star.
Overall, this is a great product and very sturdy. However, beware of the four lag bolts supplied with the product (these are the bolts that secure the mount to the wall). One of the lag bolts snapped in half during our installation and I see that this has also happened to other reviewers of this product. Considering that these bolts are 'where the rubber meets the road' I highly recommend purchasing stainless steel lag bolts and tossing the Sanus supplied bolts in the garbage.
We had to buy new hardware for it because the included hardware didn't seem sturdy enough, but overall is was easy to install and works great.
The instructions were pictures with minimal use of writing. Would have been better to use both. And the screws used to hold the mount to the TV were way too short. Had to make a trip to Lowe's. But the design and function is outstanding when you get passed that...
http://www.crutchfield.ca/sanus_vmaa.../051vmaa26.htm
Wall mount is very strong, and attached well to Sony 40" TV. I would rate this a 5, but had a poor experience with lag bolt. Head broke off in ratchet without significant torque. If you purchase, make sure to replace lag bolts.
Now for bad news, the lag bolts that come with this mount are terrible. I followed the instructions to the letter, pre-drilling pilot holes and not overtightening but the darn bolt snapped off in the stud. I was able to fix the holes and reposition, this time using stainless lag bolts from a local hardware store. With the new bolts it went up without a problem. Buy new bolts before you install!
And Sanus is also very capable of building wallmounts that sag:
http://www.amazon.com/Sanus-System-V.../dp/B0002XD0A2
The product description says this item can handle up to 50 pounds. My panel is about 44 pounds and the vertical adjustment simply cannot handle the weight of the panel. I used the "heavy load" bolt that's supposed to take care of this but it doesn't even come close. The TV doesn't just slip down a bit. It just sags against the wall. I can't imagine this mount could hold up a panel over 20 pounds without assistance.
I could go on but you won't care. Point is I've had my 42" plasma mounted on the wall for a long time, and it hasn't budged at all. I have the monoprice mount that extends as well as tilt/swivel. Rock solid, no sag.
Probe 2C is offline
post #287 of 359 Old 07-28-2009, 08:54 AM
Shade00's Avatar
I had my 42" Panny on one monoprice mount for over a year, then moved up to a low-profile mount for the 50" Panny. The 42" still sits on the same mount at my in-laws' house. I also used a smaller mount for a 17" lcd. All of them have worked very well. Just my experience, though.
Shade00 is offline
post #288 of 359 Old 07-28-2009, 09:01 AM
captclueless's Avatar
Quoted: 17 Post(s)
Had my 42" panny plasma on a monoprice mount for 6 months or so. Used the lag bolts supplied with it, and not a single problem. No sagging, no broken bolts when installing them. I am 100% satisfied with this mount.
captclueless is offline
post #289 of 359 Old 07-28-2009, 09:23 AM
kevrol's Avatar
I have a low profile mount for a 32" LCD and an adjustable one with the aluminum arms for a 50" plasma from monoprice.com. Couldn't be happier with my purchase. However the only time I extend the adjustable one out substantially is to plug in components.
kevrol is offline
post #290 of 359 Old 08-03-2009, 06:22 PM
FourDoor's Avatar
OK I just read this thread from start to finish and did a quick search at the end. Is anyone using the monoprice swiveling mounts on larger heavier plasmas like a 60"?
I see that monoprice is coming out with the 5920 which is going to be rated at 200lbs but the tech chat person didn't know when they were being released:
http://www.monoprice.com/products/pr...#specification
FourDoor is offline
post #291 of 359 Old 08-03-2009, 07:35 PM
castdude's Avatar
Just a two cents post. I've had my Pioneer 6010 mounted to a tilting monoprice mount for almost two years, can't remember the actual model number. No sag, solidly mounted to studs, and there is some lateral adjustment to make up for the mismatch between the mounting point and the ideal location for the TV itself. Am going to order another one when I replace my rear projection Toshiba in the bedroom with a plasma (hoping to find a KRP-500M in the next few months).
castdude is offline
post #292 of 359 Old 08-04-2009, 01:06 AM
fourtytwoinch's Avatar
avnuttyguy, they are slamming you because you sound childish.
People have owned both types of mounts and compared them and feel safe with their monoprice mounts. People have hung from there mounts and trusted them with 58" plasmas with no problems. You seem to ignore everything just because you want to slam monoprice.
fourtytwoinch is offline
post #293 of 359 Old 08-11-2009, 11:55 AM
Jimsaudiovideo's Avatar
Note UL and GS certifications are very stringent. In order to get UL approval a TV mount must hold 4 times its weight for at least one minute. That means the mono price mount that is mentioned in this thread could support 600 pounds while fully extended!! I don't think so, so what does the rating mean ? YOur guess is as good as mine. I recommend sticking with mounts that are at least GS certified, if not UL approved for assurance.
I have installed mounts from Mono, some with little or no trouble, some with a lot's of sag. I have recently started buying some mounts for my installs from www.av-express.com as their mounts are virtually same price as mono and are GS certified for strength. Their mounts seem a little more stable with heavy gauge steel and no sag.
Jim
Jimsaudiovideo is offline
post #294 of 359 Old 08-23-2009, 10:31 PM
bouses's Avatar
I'm planning on wall mounting my Samsung PN50B650 using a low profile mount. The Monoprice 4114 seems to fit my needs. Do you have experience with this mount?
My other thought is to use this Monoprice 5918, which is an ultra-low profile mount. Anyone with experience with this one? Advice in choosing between the two?
Will I need the port saver to make my HDMI connections, given that the mounts leave only 1.25" and .75", respectively, of room between the TV and the wall?
(The board wouldn't allow me to post URLs to the products I mentioned above since I have not yet made 3 posts.)
bouses is offline
post #295 of 359 Old 08-24-2009, 09:22 AM
Lostman's Avatar
I've got a year old Samsung 58" Plasma (don't have the exact model handy) and was looking at the mono 3725 or the mono 4174. It seems like everyone has the same 58" Panasonic. Anyone have any experience with these mounts and Samsung Plasma's? I'd like to make sure it fits to the back of the TV without any issues.
Also, on the 4174, it's just a tilt model and it doesn't seem to have a lot of clearance between the set and the wall. How are you able to plug in your cables with the TV mounted? Do you have to make all of your connections first then mount the TV? Do you have to take the set down if you want to make any future changes?
Thanks in advance.
Lostman is offline
post #296 of 359 Old 09-06-2009, 11:11 PM
Fievel93's Avatar
I just want to thank everyone in advance for their comments in this thread that I've read on and off all day. Very helpful and informative.
I just purchased a LG 55LH90 (55", about 80#) and have been looking at the Monoprice mounts. I'll either lean their way or at Jimsaudiovideo's recommendation of av-express.
Fievel93 is offline
post #297 of 359 Old 10-01-2009, 11:53 AM
OJ Bartley's Avatar
Quoted: 139 Post(s)
Liked: 202
Originally Posted by mycatsnameis View Post
I bought mine from onlybestrated.com (they resell some Monoprice products) as it was in stock and in Canada (therefore shipping was less for me).
Thanks!!! This is great, I had been debating ordering a mount from MP for a while, and I think this place might have just sealed the deal. Local pickup makes it even easier. I'll still order the smaller stuff from MP, but the mounts really add up to ship.
OJ Bartley is offline
post #298 of 359 Old 10-12-2009, 09:04 AM
shortstop11_jeff's Avatar
would it be ok to still do this or should I buy a slightly longer lag bolt to replace the ones I have now- I tightened the first 2 lag bolts without putting a washer between the bolt and the mount DOH- I was rushing of course- so the 2 right ones do not have washers and the 2 left ones do have them- can I just unscrew them- and put washers on- then put lag bolts back and they will be ok in that hole?
shortstop11_jeff is offline
post #299 of 359 Old 10-12-2009, 09:49 AM
Rick46's Avatar
IF the lag bolt screws in easily by hand I would use longer bolts as long as you don't go thru the stud. If you have to use a wrench or socket you will be fine as long as they really tighten up.
Rick46 is offline
post #300 of 359 Old 10-13-2009, 04:44 PM
thanx rick
