HPT5054 + Not responding to first remote signal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-19-2008, 06:12 PM - Thread Starter
sneakychaos's Avatar
Equipment:
Logitech 880 Remote
Samsung HPT5054 TV
Problem:
Starting sometime today, when using any remote (either the 880 or the factory Samsung remote) the TV doesn't appear to respond to the first (or second) IR commands being sent to it. If I push the volume button, and then push it again and again, eventually it will start responding. But the first signal doesn't seem to get the TV to respond, and that never used to be a problem.
How I noticed:
Using the 880, when turning on any activity involving the TV (read: most), the TV wouldn't turn on. Hitting the help button, it would ask if the TV was turned on, I'd hit no... and it wouldn't turn on, it would prompt again to try and turn it on, and it would respond and turn on.
Possible answers to questions:
I'm running the original firmware that the TV came with.. I don't know what version, and I haven't tried upgrading it yet because this problem never existed prior to today.
I did try upgrading the information on my remote, to no avail.
I have tried using both remotes, and the problem exists at all times. Appears to be related to TV, but I'm no guru and have an open mind here.
Anybody have any ideas why it doesn't seem to read that first command. I've never had this problem before... Thanks in advance for any links, help, or hints.
sneakychaos is offline
post #2 of 5 Old 11-19-2008, 08:00 PM
tomwil's Avatar
Liked: 26
Are any of the suggestions in the following thread applicable?
http://www.avsforum.com/avs-vb/showthread.php?t=1084886
That which may be known of God is evident within man, for God has shown it to them, so that they are without excuse. (Romans 1:19-20)
tomwil is offline
post #3 of 5 Old 11-19-2008, 11:29 PM
discopaul's Avatar
Quoted: 113 Post(s)
Liked: 50
That's a new one. The simple test is simply replace the batteries in the TV remote with new ones. If that doesn't work, I'd call Samsung and ask about repairing the remote section of your TV.
discopaul is offline
post #4 of 5 Old 11-20-2008, 06:56 AM
tomwil's Avatar
Liked: 26
Originally Posted by discopaul View Post
That's a new one.
Not new. The following message is included in almost all owner's manuals.
"Use of some types of fluorescent lighting may reduce the remote control’s transmission range."
tomwil is offline
post #5 of 5 Old 11-20-2008, 12:57 PM - Thread Starter
Thanks Tom. I'll take a look at that other thread. I don't think the lighting is the problem, as I don't have any florescent lights in that room.. but I will double check when I get home.
