Connect a PC to a plasma via DVI to BNC (Panasonic th-42pwd5) - AVS Forum | Home Theater Discussions And Reviews
Old 11-20-2008, 12:22 AM - Thread Starter
wuthless's Avatar
Hello All,
First off, I apologize if this question was already answered.
Secondly, I'm a newbie so please be gentle.
I recently purchased a used Panasonic TH-42pwd5 TV/Monitor off of craigslist. It was built in 2003 but appears to be in good working order. It has several input to include PC (VGA DB9), Component/RGB (BNC style), S-Video composite, and RCA audio.
I want to connect my PC/MAC to this TV/Monitor at the highest resolution so I can use it as my monitor.
I am able to connect my PC's VGA port (or DVI with an DVI-to-VGA adapter) to the 'PC' port and the resolution is OK but not great. The manual says I can go to 1600 X 1200 @ 60mhz but it looks terrible.
So I tried to hook up the DVI port on my PC to the BNC ports on the TV/Monitor. In order to do that, I had to purchase a DVI-to-Component cable and a couple of Component-to-BNC adapters
Unfortunately, that didn't work at all. I tried different frequencies and settings but nothing seems to work.
Does this setup even work? Is it a digital signal the entire way through? Does the signal get converted at all, if so, do I need a converter to make it work?
Does anybody know of a better way?
Any help would be much appreciated.
Thanks in Advance
Wuthless
wuthless is offline
Old 11-20-2008, 01:42 AM
elmoizme's Avatar
There is a DVI card for your older plasma. The model number is TY-42TM4D/DB
Here is a brochure for the the 5 series with the DVI card.
http://www.pave.com.sg/pdfs/visual_s..._th_42pwd5.pdf
Would be tough to find it now. Good luck
elmoizme is offline
