TH PF series PIP rs232 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-26-2008, 06:18 PM - Thread Starter
avdorks's Avatar
Anyone have luck swapping the pip Sub picture Input Select ISS:***(*)
Currently sending \\x02ISS:PC1\\x03
I can move the picture but does not seem to like the sub picture select command
All other commands seem to function...
avdorks is offline
post #2 of 4 Old 12-26-2008, 10:38 PM
Techniwizard's Avatar
ISS:xxx is the correct command so it should work.
Note that PIP cannot be two analog signals (ex:PC-component), one of the inputs must be digital. analog-analog combinations are invalid.
See attached.
T Wiz
PEE-P021-R2_PIP.pdf 189.119140625k . file
Techniwizard posts as an Independent Servicer
Techniwizard is offline
post #3 of 4 Old 12-27-2008, 06:10 AM - Thread Starter
avdorks's Avatar
Yup.... lol figured I would stop spinning my wheels.. last line of page 20 HA! thanks for the pdf!
avdorks is offline
post #4 of 4 Old 12-27-2008, 08:01 AM
In these cases, composite is considered a "digital" input if that helps.
Component, RGB, and PC (VGA) are analog signals.
HDMI, SDI, DVI, and composite noted above are digital inputs.
For dual input boards (TY-FB10HMD; HDMI and TY-FB9BD; composite) you may use only one of the dual inputs at a time. In other words you cannot use both inputs of a dual input board as both imputs of PIP.
TW
