Pioneer Pro1150hd Light blinking - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-12-2009, 01:40 PM - Thread Starter
skull791's Avatar
I have Pro 1150HD and last night turn on my Tv and it went from red light to blue light blinking 12 times then stop blinking 12 and stop. no picture. So I turn off the tv with remote turn it back again and it works fine. Dose anyone knows what it is?
skull791 is offline
post #2 of 5 Old 01-12-2009, 11:53 PM
Killer65's Avatar
I have read several threads dealing with this same problem. I don't remember what exactly it was but doing a search will bring them up.
Hope things work out.
Killer65 is offline
post #3 of 5 Old 01-13-2009, 05:06 AM
dark1x's Avatar
Quoted: 14 Post(s)
Something related to an error in receiving the latest updates from the tuner. If you are not using the built in tuner, you should set your zip code to 00000, which should disable this completely.
dark1x is offline
post #4 of 5 Old 01-13-2009, 06:57 AM - Thread Starter
skull791's Avatar
Cool I tough my Tv is going crazy. That is wierd that tv wont turn on it will just flash that code till you turn it and and off again. I will channge the zip. Thank you.
skull791 is offline
post #5 of 5 Old 01-13-2009, 08:50 AM
DNbass's Avatar
Quoted: 23 Post(s)
I have the 1130, and I believe the blinking blue lights (in 12 blink intervals) is your TVGuide attempting to update, but unsuccessful.
If you don't use the TVGuide, then changing the postal code would work (as I've read on this forum). If you do use the TVGuide, then you may want to enter your postal code and give it another shot.
DNbass is offline
