Samsung P50H Professional Plasma? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-12-2009, 06:20 PM - Thread Starter
Joony's Avatar
Does anyone know anything about this? I can't any reviews on this either on google or on the forums.
Samsung P50H Product Page
My department is looking at using this for a smaller classroom, vs a normal projector.
Basically it's this PDP or the Panasonic TH-50PH11UK.
I like the Samsung since it has native DVI for digital 1:1 pixel, whereas the Panasonic you have to buy the DVI board.
LCDs are out of the question because they're a tad too expensive for our budget. Both of these PDPs are about $1500 and under.
Joony is offline
