pioneer 5070 and blue ray - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-25-2009, 07:52 PM - Thread Starter
mtbmtb01's Avatar
i was wondering if i would be able to get a good pic with a blue ray player and my pioneer 5070. it only has 720p or 1080i but says it has the Ability to Accept a 1080p/24Hz Signal?
mtbmtb01 is offline
post #2 of 7 Old 01-26-2009, 02:47 AM
dssturbo1's Avatar
bluray should look pretty darn good on your 5070. it will display at 768p and should look just fine.
HD HD HD I Need more HD, Yes I am a HD Addict :)
dssturbo1 is offline
post #3 of 7 Old 01-26-2009, 04:01 AM
optivity's Avatar
For a 720p native resolution display you will see the same kind of improvements regarding the image your PDP renders w/Blu-ray disc versus DVD, as you have experienced with HD versus SD broadcast/cable/satellite content.
optivity is offline
post #4 of 7 Old 01-26-2009, 04:31 AM
Morecambe's Avatar
I have the UK 507XD and Blu Ray is tremendous...Enjoy!
Morecambe is offline
post #5 of 7 Old 01-26-2009, 10:19 AM
Quoted: 21 Post(s)
I have both a HD A2 and a BD300 connected. Both looks great. You have a awesome unit. Enjoy!
HiDef Lover is offline
post #6 of 7 Old 01-26-2009, 10:41 AM
Michael St. Clair's Avatar
I have 5070 and BD via PS3 (output 24fps 1080p) and it looks fantastic.
Michael St. Clair is offline
post #7 of 7 Old 01-26-2009, 02:19 PM
DeltaMW's Avatar
Hi,
I had a question about this farther down, but didn't get much response. I have a 6070 and a Panny BD 35K blu-ray player. I have tried the 1080p/24fps option, and my 6070 doesn't display anything.
Right now I have the Panny set at 720p output. I thought if the bly-ray discs are encoded in 1080p, I figured it would be better to not interlace it then de-interlace the signal in the set. If 1080p/24fps doesn't work, would 1080i be better?
DeltaMW is offline
