Pioneer KURO New Owner's Thread - AVS Forum | Home Theater Discussions And Reviews
Old 02-13-2009, 03:59 PM - Thread Starter
AlexNoVA's Avatar
I just got a 5020 and the owner's thread is just too big for a new owner to handle. Somebody else mentioned that there ought to be a novice/new-owner thread to get answers to oft-asked questions, so here it is.
When I have time, I'll cobble together a rough FAQ. Meanwhile, ask your newbie questions! Veterans, pipe up with some answers!
AlexNoVA is offline
Old 02-13-2009, 04:00 PM - Thread Starter
AlexNoVA's Avatar
work in progress
Helpful Links:
Owner's Manuals (PDF format)
Break-In DVD/Thumbdrive Files
Download ZIP files or buy the DVD
Firmware
Update for PDP-5020FD, PDP-6020FD, PRO-111FD, and PRO-151FD
Display Settings
5020FD / 6020FD ControlCAL Display Profile Set
111FD / 151FD ControlCAL Display Profile Set
101FD / 141FD ControlCAL Display Profile Set
D-Nice's calibration settings
FAQ
A caveat: Much of this is my understanding of things as I've poked around the AVS boards and elsewhere, and may stray into "blind leading the blind" territory. Comments/suggestions welcomed
The manual says to lie the set down on its face to install the speakers. Is that really necessary?
NO! It's a lot of unnecessary - if not hazardous - movement. The author installed his speakers with the set upright with no problems. Chadmak09 said his screen was cracked after he tried the manual's method.
I plugged in the TV but it won't turn on! What gives?
for 5020/6020...There's a main power switch on the back left of the unit. It's a few inches below the side panel inputs. The button is about 2" wide - big enough to find by feel - and upside down (you'll have to push it up). Hit that and you'll see the red power light come on
What is "burn-in?"
rmcgirr83 has the answer
What is "break-in?"
Break-in is a procedure to, well, break in the phosphors of your set. Doing so can help prevent image retention problems down the road.
Evangelo2 has put together a set of files that can be run from a DVD or a thumbdrive. It cycles through a collection of color images (several shades of red, green, blue and white/gray) to evenly "work" all of the phosphors.
How long should this break-in take?
100-150 hours seems to be the rule of thumb. During this time, it's recommended that you don't watch any programming with static graphics or black bars for long periods (or at all). Set the screen to full so the entire viewing area is used.
D-Nice has suggested elsewhere that you run Evengelo2's break-in program for 150 hours at a specific setting.
Chadmak09 also has a helpful summary of the break-in process using the break-in DVD/files
Do I have to break-in my set?
Well, it's your TV... you don't have to, but it can't hurt. Finding a definitive answer on the Interwebs is not easy.
What is "torch mode?"
This is a tongue-in-cheek expression for very bright high-contrast display settings.
What is ControlCAL?
ControlCAL is software used to make more refined adjustments to your TV settings using a computer.
What's this thing about updating the firmware?
Pioneer released a firmware update for the 5020, 6020, 111 and 151 sets. It includes some Home Media Gallery tweaks and a few other fixes. You can either download the firmware update directly or order a free thumbdrive from Pio.
So I got the thumbdrive from Pio (finally!) but I plug it in and nothing happens!
There's something screwy with the thumbrives they send. Could be the formatting used (?) ... In any event, hook it up to a computer. If you can see a folder named "update" copy it to another thumb drive and try the procedure again on the TV.
Do I need to update my firmware?
Your set may have shipped with the updated firmware, unless it wasn't.
Here's how to check:
Hit the home button on your remote
Select Setup >> System Setup >> Technical Info (hit the up arrow once to get it)
Look for the Software Version number at the top
less than 0904-0401: update needed
greater than 0904-0401: no update needed (yaay!)
(Note: Mine is exactly 0904-0401, so some poor writing on Pio's part has me scratching my head.)
AlexNoVA is offline
Old 02-13-2009, 04:35 PM
omeletpants's Avatar
Does it make sense to have parallel thread for the same thing?
Here is the original Kuro thread
http://www.avsforum.com/avs-vb/showt...highlight=kuro
omeletpants is offline
Old 02-13-2009, 04:39 PM
dssturbo1's Avatar
a "newbie" kuro owner would find alot of info in the regular stickied owners thread if they took the time to read it.
HD HD HD I Need more HD, Yes I am a HD Addict :)
dssturbo1 is offline
Old 02-13-2009, 04:40 PM
chadmak09's Avatar
Heck, I say let him have a novice kuro thread.
Its not like there will be anymore "official pioneer" threads anyway.
no more will be made.
chadmak09 is offline
Old 02-13-2009, 04:42 PM
Chad, someone was saying in the other thread that they would produce until the end of the year. Doesn't sound like that from the press release
Old 02-13-2009, 04:48 PM
chadmak09's Avatar
man, I don't know what to believe anymore.. lol.
Old 02-13-2009, 04:49 PM
davethestalker's Avatar
Quoted: 49 Post(s)
THE ORIGINAL KURO THREAD IS TOOOOOO BLOATED [WITH USLESS INFORMATION] FOR A KURO NEWB SUCH AS MYSELF. Perhaps if it had sub categories it would be better.
I have had my 5020 for a little over a week now. It has been running almost 24/7 with a mixture off the break-in color files on USB and SD/HD viewing. I think it's safe to say that my break-in period is over?
I've been using the calibration setting suggested by D-Nice. At times, I find this a little too dim for my vision.
I don't have the greatest eyes in the world, I have night blindness. When I go to movie theaters, no matter what theater it is (IMAX or standard multi-plex) the picture is ALWAYS too dark and I often miss out in scenes that are at night or in a dark setting. Unless you have vision problems, I don't think you could releate.
I've checked the other picture settings and Dynamic would be ok, but it is overall too bright and it cannot be toned down, it's adjustments are locked. Sport has brightness levels I like, but according to D-Nice's calibrations Sport must be some sort of self destruction mode; "****UNDER NO CIRCUMSTANCE SHOULD THESE SETTINGS BE USED WITH ANY OTHER SOURCE MATERIAL BEYOND THE BREAK-IN DVD OR THUMBDRIVE FILES****"
I've tried the "Optimum" mode while watching American Gangster in an unlit living room and details in dark scenes were too dark. Naturally Dynamic was overkill. D-Nice's Movie setting looked to be a bit dull in this movie.
So, what calibration and or mode should I be using so I can fully enjoy my Kuro? I need a setting that is in between D-Nice's Movie settings and Sport or Dynamic.
When pausing my Dish ViP722 and switching modes, Optimum provided a nice sharp and clear picture, but is not perfect. I could see details in Dynamic that I could not see in any other mode.
One of the best things about our Sammy LN46A550 is being able to adjust the backlight if the overall picture is too bright or too dim. Unfortunately, there is no such adjustment with plasmas.
Kuro owner from Cleveland Plasma.
Pro-Ject Debut Carbon w/Acryl-It platter, Phono Box S
DENON AVR-X7200wa, Paradigm Monitor 90p v1
Def Tech system: CLR2300 SM450 surrounds, BP1.2x rear surrounds, Polk PSW-505
Previous AVRs: AVR-4520ci, RX-A710, RXV-2200
Instagram: DaveTheStalker, PSN ID: DaveTheStalker GT fan since day 1.
davethestalker is offline
Old 02-13-2009, 05:17 PM
sixfoot6's Avatar
As a new owner, I appreciate this thread. With the recent price drops, I think there are quite a few new 5020 owners. The original thread probably contains all sorts of good info, but without an index its proving very hard to find. Recent pages on the same thread appear to cover mainly "advanced topics" (and related drama).
I'm about 40 hours into my break-in as well, I plan to watch my first 1:2.35 BluRay tonight, cause I'm dyin'.
Per the comment above about settings... I think most will tell you to start with D-Nice's settings and then tweak to your own liking! Maybe just pop up the brightness a notch or two, since that seems to be your main issue.
sixfoot6 is offline
Old 02-13-2009, 05:46 PM
Quoted: 49 Post(s)
One of the questions I have about the break-in images via USB I think should be in the first post is regarding speed. How fast or slow should the Slide Show be? 10 sec, 15, 30, 60 sec, or even 3?
There have been some moments (watching Heroes, 24, or LOST with OTA, or 300 in HD) I have simply been floored with the picture on my Kuro. Other movies such as American Gangster, I think were filmed in a particular way to give a gritty 70's sort of look.
Old 02-13-2009, 08:55 PM
COACH2369's Avatar
Quoted: 801 Post(s)
Liked: 673
I am all for a thread like this one... My 151FD should be here on Tuesday or Wednesday.. Not sure what to expect, but I am hoping it is everthing I expected it to be..
COACH2369 is offline
Old 02-14-2009, 08:28 AM
Yoma44's Avatar
I'll join in here. I just got a 151FD yesterday. Now I'm searching for what to do and how to calibrate it.
Should I break it in using a thumbdrive or something? I've heard mixed reports of doing this and am hesitant, as I don't want to mess it up.
Yoma44 is offline
Old 02-14-2009, 09:04 AM
chadmak09's Avatar
Most that i know (including myself) go 30 seconds.
Old 02-14-2009, 09:07 AM
chadmak09's Avatar
this is totally up to you.
I did it and will continue to do it with every plasma I buy.
here is a quick "tutorial" on the procedure:
When you get the Elite, (Pro-111FD or Pro-151FD)
1. Plug it in (LOL)
2. Press the Home Menu button on the remote.
3. then go to setup and press enter.
4. The go to Picture and press enter
5. Now set your settings up like this:
Picture:
AV Selection: Sport
Contrast: 50
Brightness: 0
Color: +20
Tint: 0
Sharpness: 0
Pro Adjust
Pure Cinema
Film Mode: Off
Text Optimization: Off
Intelligence: Off
Picture Detail:
DRE Picture: Off
Black Level: Off
ACL: Off
Enhancer Mode: 2
Gamma: 2
Color Detail:
Color Temp: High
CTI: Off
Color Management
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space: 2
Noise Reduction:
3DNR: Off
Field NR: Off
Block NR: Off
Mosquito NR: Off
Screen Size: Full
Power Save Mode: Off
Orbiter: Mode 2
6. Click Here-----> Thumbdrive Files and put the files on your thumbdrive.
Then plug the thumb drive into the usb port on your Kuro.
And follow these instructions:
*Press home/menu on the remote
*Then go to "home media gallery"
*Then go to USB
*Then go to "USB Disk" (it may say 2.0 or something beside it)
*This should open your thumb drive and show you a list of the break-in jpg's.
*Press the "tools" button on the remote.
*Scroll down to slide show and press enter.
*Set the settings up like this:
Effect: Off
Monochrome: Off
Interval: 10 seconds - 30 seconds (your choice, But I used 30 sec.)
Random: Off
Play mode: Repeat All
BGM:Off
Then click "start"
This should start up the slideshow Break-in process.
Let the TV run the slideshow and break-in for 100-150 hours.
Feel free to watch TV when you want. Don't be afraid to.
Once you have finished the break-in process, Put in D-Nices reference settings for whichever Elite you are getting (111 or 151).
Here is a link to where you can find those settings.
D-Nice's settings page
Make sure you carefully read the instructions above the settings that D-Nice put there to determine which setting are right for you.
He put them in bold red.
that should do it for you! let me know if you get stuck anywhere.
-Chadmak09
Old 02-14-2009, 09:39 AM
dantes67's Avatar
Wow, thanks for the great post, chadmak. We're going to getting a 5020 or 111 elite in the next week or so and I've been a little intimidated by the break-in process as this is our first plasma. Even though the info you shared is available elsewhere on avs your post will prove to be a great one-stop reference.
dantes67 is offline
Old 02-14-2009, 09:42 AM
E-A-G-L-E-S's Avatar
You can "search within thread" on the owners thread, just thought I'd let the newbs know.
You'll get an answer for yourself much quicker than this thread will get responded to.
The guys with the Kuro knowledge most likely wont chime in here when they are already actively participating in the owners thread.
Chad....isn't Orbiter Mode 2 the one to use? Then you have the orbiter work on all screen size modes.
E-A-G-L-E-S is offline
Old 02-14-2009, 10:47 AM
ayilar's Avatar
Just bought the pair from BB, delivered yesterday. Many thanks for the posters on the AVS forum -- the wealth of info has been extraordinarily useful. My time to return the favor -- this thread is a good idea.
1. Purchasing the unit.
I bought from BB, the place where I spent most of my in-person research time. I made it a point to give them first shot at the sale, as they went through the cost of making my decision much more comfortable. The price for the pair (5020 and 51BD air), after minimal negotiation (i.e., a polite "take it or leave it" offer), was as low as anything I have seen from reputable online places. In sum, a win-win situation. Delivery was painless, the panel and player both appear flawless, all seems to work as it should.
2. Initial impressions.
Positives: TV has very deep blacks, superb finish, no judder that I can detect, good color (could not live with the red push on the Panasonic), and pretty good sound.
Negative: I have only one gripe so far -- the remote. One, the various controls consist of multiple small buttons that seem to be arranged haphazardly. Two, the backlighting is much too weak to be of almost any use. This is an even bigger issue, because the buttons are poorly (IMHO) placed. Three, a rotary dial such as the one found on the Samsung would be a nice addition when navigating menus.
Question 1: When the credits roll, the text does not roll perfectly smoothly (it's close, but not perfect). I had not noticed this in the store, where the motion smoothness of the Pioneer was IMHO clearly superior to that of the Panasonics and Samsungs (let alone LCDs). Does this phenomenon reflect the movie itself (in a movie theater I see this even more) or can the choice of TV settings make this avoidable? If so, please advise!
Question two: I watched some OTA digital broadcast as well as a Winnie the Pooh DVD and the BR-remastered version of "from Russia with love" yesterday night, using D-Nice’s settings. While his settings seemed perfect for regular TV, they seemed a little too bland for the two movies. As a result, I ended up watching the Pooh DVD on “Standard”. The difference between D-Nice’s Movie setting and the "Standard" could can be compared to the difference between the colors in the original Winnie the Pooh books and the colors of a regular, modern comic book. Both have their fans, but one is punchier. Question -- will the colors on D-Nice's ses become more vibrant as the panel matures?
3. Break-in or no break-in? That is the question...
Before receiving the unit last evening, I had downloaded the break-in images to a thumb drive. However, I was so eager to start enjoying the TV that I decided not to wait. I have since watched several movies in a couple of hours of on the air digital TV, all a maximum resolution. Once the work week starts, I will most likely run the USB pictures, just to be on the safe side.
Question: is it okay to intersperse regular watching with periods of break-in?
4. BDP-51FD:
I bought this unit because of the good reviews, the many comments on how robustly the unit was built, and the hope that it would come well integrated with the panel. In particular, I was hoping that I could live with a single remote. Initial impressions are positive. On the plus side, it plays extremely smoothly and seems to change regular DVDs nicely. The two Blu-Ray discs I have watched so far have been fine (From Russia with Love, a documentary Bears), as has the DVD (Winnie the Pooh’s Heffalump). On the minus side, it takes a tad too long to load up, and in practice, I have yet to figure out how to get to my goal of a single remote.
I will try the BR and DVD versions of Cars tomight, to compare.
Thanks and cheers!
ayilar is offline
Old 02-14-2009, 10:57 AM
chadmak09's Avatar
yep,
mode 2 is best. Its like the "automatic" of orbitor modes. It works with everything and is the best mode to use IMO.
I had copied those break-in settings from D-Nices, And he has mode 1 on there (which works as well).
I will change.
Old 02-14-2009, 11:23 AM
Pyredesign's Avatar
I must say, that after extensive research for a total of two weeks, I have been sold on the 5020FD. I am going to be moving from a Samsung 50" 720p DLP to the Kuro. I placed my order yesterday on Amazon. My delivery estimate is between the 20th through the 24th. I am super excited for next week. I imagine some people from here have ordered from Amazon before... if so, some input on what to expect for delivery would be nice.
Any new/beginners advice would be greatly appreciated, as this is my first Kuro (probably last now) and plasma TV. I had one important question that I would like to have answered. Is getting ControlCAL a good idea for $25? Would any female-female straightthrough cable with with the program and the 5020? Should I get ControlCAL right away?
Any other input would be appreciated. I plan on letting straight break-in images for the first 24 hours or so, maybe a break for some hd content, and then mixing it up from there. Letting the break-in images run while I am gone at school or work.
Thanks in advance guys!
Pyredesign is offline
Old 02-14-2009, 12:47 PM
jiholl's Avatar
Hi...like this "new" thread..perhaps can help with similar basic questions...have tried D-Nice settings, etc...but, perhaps its just me, but often movies and tv look very "dark." ?? Like you cannot see a lot of detail in the blacks..shadows, etc....so...wondering... lets say if in MOVIE mode, how to best adjust CONTRAST and BRIGHTNESS to "brighten" picture overall....obviousely you bring brightness UP...but how far is safe without potential damage to the panel...and the which direction to take Contrast if raising brightness up a lot??? Thanks!!
jiholl is offline
Old 02-14-2009, 12:55 PM - Thread Starter
AlexNoVA's Avatar
I ordered from buy.com, not Amazon, so I can't speak precisely to the situation. Nevertheless, a few of my set-up observations...
  • check the screen with a flashlight for cracks
  • the 5020's stand is already attached and the set is ready to place
  • if you can - and the delivery guys are patient enough - power it up before you sign off on the delivery
  • there is another power button on the back left, about 3-4" below the side inputs... gotta hit that one first.
  • the manual recommends laying the TV face down to install the speakers, but I put mine on while it was upright with no difficulty at all.
  • the set doesn't seem that heavy and isn't too hard to maneuver. I was able to place it on my TV stand by myself. Then again, the 5020 replaced a 160# Tosh CRT...
I wouldn't worry about ControlCAL just yet. Get the set broken in first. I'm just doing the break-in and fiddle with some of the other settings before I go that route. If you're an inveterate tinkerer, you'll prolly get it eventually.
AlexNoVA is offline
Old 02-14-2009, 02:06 PM
ayilar's Avatar
Originally Posted by AlexNoVA View Post
[*]the manual recommends laying the TV face down to install the speakers, but I put mine on while it was upright with no difficulty at all.
Ditto here. It helps if someone is holding the speakers while you screw the brackets (n my case, the BB delivery guy helped me). The middle bracket is harder to fasten than the side ones -- keep it for last (and only tighten the side brackets after you are sure that the middle one fits well).
ayilar is offline
Old 02-14-2009, 02:23 PM
chadmak09's Avatar
YES YES YES.
The manuals method is CRAP!!!
DONT DO IT THAT WAY ANYONE!!!.
I had 2 6010s that I laid down face first on my tablewith a blanket on top of it when I put the stand on.
When I powered them on BOTH were dead due to cracked internal glass.
I am not sure if it was done during shipping or when I laid them down, but on the 3rd 60inch Kuro I had delivered, I lifted the panel on the assembled stand instead of laying the panel down face first.
It powered on immediatly.
Old 02-14-2009, 02:52 PM
Tom V's Avatar
4. BDP-51FD:
I bought this unit because of the good reviews, the many comments on how robustly the unit was built, and the hope that it would come well integrated with the panel. In particular, I was hoping that I could live with a single remote. Initial impressions are positive. On the plus side, it plays extremely smoothly and seems to change regular DVDs nicely. The two Blu-Ray discs I have watched so far have been fine (From Russia with Love, a documentary Bears), as has the DVD (Winnie the Pooh's Heffalump). On the minus side, it takes a tad too long to load up, and in practice, I have yet to figure out how to get to my goal of a single remote.
Thanks and cheers!
Blu-ray load times are a function both of the player and whether the specific title is authored as HDMV or BD-J. Blu-ray Java titles take longer because of reading that code.
- TV
Tom V is offline
Old 02-14-2009, 04:06 PM
stickb5's Avatar
hey guys, i have now 1 week with my 5020 and since i brought it in i have been using the Break In Images via usb, yesterday i wanted to put the black levels to the test, i have seen pictures of the 5020 that you cant actually tell where is the bezel of the TV, i control the lighting of my TV room so i made it as dark as possible and putted on the episode of CAVES from PLANET EARTH on Bluray, well the black level of this tv is really great is the best of all the other TVs i have owned LCD and plasma alike. But the black level never plunged at a point where i could not see the differences between the screen or the bezel of the TV, again, pretty impressive black levels but did not see what other people are putting on pictures saying that they can not see the bezel of the TV.
I Am Legend
stickb5 is offline
Old 02-14-2009, 05:11 PM
dalton3409's Avatar
Just before Christmas I bought an ex -display Pioneer PDP-4280XD. At the time I really turned myself inside out trying to make the decision as I wouldn't know the history of the screen and how much it had been played with but the price was so low... £997! Yep, under a grand for an 8G Kuro!!!
It was an awful predicament as I've been wanting a Pioneer Plasma for years, watching generation after generation be released and never able to afford one. I even advised my dad to buy the same screen which resulted in much jealousy. Anyway, the salesman advised me that it was the last one that they had and had only been on display for 2 months, and besides, Pio don't make a 9G under 50" anyway so it would have to be an 8G, the cheapest 42" Kuro I've seen anywhere is £1400.
After spending 2 and a half hours watching the screen, checking for dead pixels and scratches (none!) and making sure that the contrast/brightness hadn't been set too high I bit the bullet and for the most part I've been pretty ecstatic.
Its only tonight that I have spotted a problem. When there is a bright, white scene, burnt directly in the middle of the picture is a BluRay logo where the screen must have been left on pause for too long. Can't have been me as I don't have BluRay and now I'm gutted!
So was it a good idea to buy ex-display? And is there anyway of getting rid of image retention like this? I've searched for hours in the forums which are HUGE and found no real mention of a tried and trusted method.
Please help...
dalton3409 is offline
Old 02-14-2009, 05:17 PM
Quoted: 49 Post(s)
What are the differences between "Dot by dot" and "Full"?
As for picture modes, I find it interesting that each mode has it's own brightness, sharpness, or POP in the mode itself and not due to adjustments being boosted. The adjustment sliders are mostly neutral by default.
So, this begs the question are the modes actually targeting specific content? Such as Sports for racing, football, baseball and other sports? I know Optimum is fully automatic and utilizes the room lighting sensor and it's neat to see it working. Movies would be for watching movies or general TV content? What would "Standard" and "Performance" be used for?
Watching NASCAR racing in Movie mode, the colors look pretty bland and not real.
Old 02-14-2009, 06:01 PM
Jamezuva's Avatar
Once I get the 6020 on the base stand and put it on my furniture, is it hard to mount the included speaker by yourself on the underside? Do you have to lift the tv to properly set it? Also when securing the base stand to the tv, is it ok to rest the tv directly on the stand or do you have to lift it slightly to line up the screw holes?
Jamezuva is offline
Old 02-14-2009, 09:40 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
Please help...
Well if you bought it right before Christmas. That means you are now coming up on close to two months or slightly longer that you've owned it and have been using it, so it probably has a fair amount of hours on it where just you have watched it in your own home, and that has done nothing much to get rid of the Blu-Ray logo image that it has in the center. Sad to say, is that if after the two months that you have had it in your own home and that you just now noticed seeing it. Is that it sounds like the set actually has burn-in of the Blu-Ray logo from being on display at the store, and it's not just image retention. And if is burn-in, burn-in is permanent and there is pretty much nothing you can do to get rid of it.
Johnla is offline
Old 02-14-2009, 11:02 PM
Hedge-Hog's Avatar
Hiya,
Kinda new owner...got the 151FD three weeks ago. Nice unit. One thing I'm having trouble with is the subwoofer out on the back. I run my BD player and HDDVR via HDMI to the set and use the set to send audio out (2-ch to preamp and sub out to subwoofer). Problem is, I get no sub signal but the 2-ch is fine. I then tried plugging the sub to the BD player's sub out and I get signal. Any trick to getting sub out of the TV? (this is kinda temporary as I'm awaiting my pre/pro)
BTW, I ordered an OmniMount ULPT-X tilting wall mount for this unit...got a decent price from some well know web auction site . They drop shipped it and I notice it came from a liquidator place. Being curious, I checked it out...wow, cheap (way cheaper than what I paid...and I got a good deal already). Anyhoo, here's the place if anyone's interested in a great discount: http://www.shopbiglots.com/family/in...goryId=3280685 I have zippo affiliation with this.
Cheers.
-Hedwig
Hedge-Hog is offline
