Kuro 6020 Direct TV Remote Codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-22-2009, 09:20 PM - Thread Starter
amarzano's Avatar
Trying to control my Kuro with the Direct TV Remote (RC34). I can get the Power on/off to work on the TV, but not the volume.
I do have this remote set to RF and am controlling the HD PVR in another room. I have tried all the codes listed on the HD PVR - but like I said - no luck on controlling the volume.
Any other Pio 6020 owners get this to work?
Thank you!
Alex
amarzano is offline
post #2 of 3 Old 02-22-2009, 10:15 PM - Thread Starter
amarzano's Avatar
Got this answer from the Direct TV forum. Worked for me - and I thought I would post it - in case anyone else had the same issue..
With a code that at least powers the tv , try the following to get the volume:
1. tv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 3
4. press SELECT
amarzano is offline
post #3 of 3 Old 05-11-2009, 01:05 PM
Daniel Hutnicki's Avatar
what was the code that work for power button?
Daniel Hutnicki is offline
