Accessing Panasonic Service Menu? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-23-2009, 07:11 PM - Thread Starter
DPAsghar's Avatar
Quoted: 48 Post(s)
Liked: 52
Sorry i tried searching but didnt find exactly what i was looking for. I have a Panasonic 50PZ85U. I want to find out the hours ive used and not sure where to look.
I hit the volume down button on set and then info three times and a service menu pops up. However i dont know where to go from here. It seems ive hit every button and the menu seems unresponsive. I admit i am a bit afraid to do the wrong thing and ruin any setting.
Can anyone help?
Dan
DPAsghar is offline
post #2 of 5 Old 02-23-2009, 09:11 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
1. Enter Service Menu (Hold Vol. - down on the TV while pressing the INFO button on the remote 3 times).
2. Press the {2} button on the remote 1 time, to go to SRV-TOOL.
3. Press the {OK} button. A blue grid will appear with the following information.
TD2Mictocode: 81c00011
Flash ROM: 1-227E
PTCT :00.00.00.00.00
4. Cursor down to the PTCT :00.00.00.00.00 line and then cursor over to the right to highlight the empty box.
5. Press and hold the {MUTE} button on the remote for 3 seconds.
The TIME / COUNT info will be displayed in Hours and Minutes of Operation.
6. To exit, press and hold the {POWER} button on the TV for 2 seconds.
The display will re-start by itself.
<<<< WARNING - WARNING - WARNING >>>>
The {VOL+} and {VOL -} buttons are used to change
values in the Service Menu. Make sure not to touch
those buttons anytime while checking the hours used.
vivatech likes this.
JChin is offline
post #3 of 5 Old 02-23-2009, 09:30 PM - Thread Starter
DPAsghar's Avatar
Quoted: 48 Post(s)
Liked: 52
JChin,
thanks so much for your help. I wanna get to 100 hours ASAP and get this puppy calibrated!!
DPAsghar is offline
post #4 of 5 Old 02-23-2009, 09:40 PM
Holiday121's Avatar
Quoted: 539 Post(s)
Liked: 147
I just bought a pz80u.. Havent taken it out the box yet. Going to run the first 100 hours. But i been reading alot on Calib. Have you done a unit before?
Holiday121 is offline
post #5 of 5 Old 02-23-2009, 09:40 PM
JChin's Avatar
Quoted: 348 Post(s)
Liked: 204
DPAsghar, if you have further question you should post it here, alot of info: http://www.avsforum.com/avs-vb/showthread.php?t=1000479
JChin is offline
