The Official Panasonic TC-P50X1 and TC-P42X1 Owner's Discussion & Information Thread - Page 106 - AVS Forum | Home Theater Discussions And Reviews
post #3151 of 3189 Old 07-29-2011, 10:19 PM
CLEHD's Avatar
Originally Posted by _thx1138_ View Post
That sounds about right i have my contrast set to +50 below are my settings after calibration with spears and munsil:
Cinema
Cont: +50
bright: +60
color: +35
tint: +7
sharp: +55
color temp: normal
Cats: off
Video nr: off
Mpeg nr: off
Black level: light
Many people make the mistake of over doing it with their contrast settings thinking more is better Thas so not true. Seems like you are on the right track.
What exactly does "Color" do/control? I don't know if I have ever had a calibration tool (Spears & Munsil, AVC) which has a test for it.
CLEHD is offline
post #3152 of 3189 Old 07-29-2011, 10:30 PM
_thx1138_'s Avatar
Of course Spears and munsil has a calibration tool for this parameter its called the "color bars pattern" The Color control (sometimes called "Saturation") is used to adjust the relative balance between the chroma (color) channels and the luma (brightness) channel. If Color is set too high, the colors on screen will be oversaturated, and if it's set too low, the colors will be muted and washed out. The Tint control (sometimes called "Hue") is used to adjust the balance between the two chroma channels. If Tint isn't set correctly, all of the colors on the display will be wrong.
I recommend If you want to know how to use the Color Bars pattern to set Color and Tint, read this (copy paste link below):
http://www.spearsandmunsil.com/artic...orandtint.html
_thx1138_ is offline
post #3153 of 3189 Old 07-29-2011, 10:43 PM
CLEHD's Avatar
That's a great link. Thanks!
CLEHD is offline
post #3154 of 3189 Old 08-06-2011, 04:46 PM
dconcepts's Avatar
I've searched this thread and the forum in general and did not come up with anything, so if this somehow was missed in the search, I'm sorry but I tried.
Our P42X1 is just over 2 yrs old (out of coverage that I've got on the credit card that doubles mfg warranty). TV and all the related electronics are plugged into a decent surge protector -- but apparently, that did not help. We've gotten tons of storms lately and have had a ton of lightning. I'm thinking that caused a problem the surge strip didn't help prevent.
Picture is fine (great actually) -- but no sound whatsoever.
I have checked:
Mute
Volume
SAP
TV Speakers on
We tried to "reset" the TV, unplugged for an hour but it seemed to make no difference.
The only thing I noted of interest is that in the Audio menu, the RESET TO DEFAULTS option is grayed out!??? Why -- and why would lightning/power spike cause that to happen? Wouldn't unplugging for a hour drain the boards and cause everything to go back to factory defaults?
If anyone here can help lead me in the right direction, that would be terrific. I've read on a few "help fix things" sites that the main board is likely bad and would need to be replaced -- and that it's a pretty easy job to do it yourself.
dconcepts is offline
post #3155 of 3189 Old 08-07-2011, 08:27 AM
_thx1138_'s Avatar
I have checked:
Mute
Volume
SAP
TV Speakers on
Did you check you "viera link settings" have you tried restoring those to default? I'm thinking after dong this step, you should be able to restore the factory settings again and get some sound, let me know, I'll keep running some tests on my 42x to see if I come up with anything else.
post #3156 of 3189 Old 08-07-2011, 03:32 PM
dconcepts's Avatar
I did not see anything in Viera Link that was anything other than default settings. I'm confused -- is there something else that I'm missing here?
I was hoping one of the techs that frequent the forum might pop in and provide some insight.
post #3157 of 3189 Old 08-07-2011, 03:53 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
What is your source -- antenna, cable/sat box. etc? Do you have this audio problem for all inputs?
Larry
LarryInRI is offline
post #3158 of 3189 Old 08-07-2011, 04:41 PM
dconcepts's Avatar
Larry
Hi Larry,
The source is RCN cable box -- connected to the Panny via coax. This set is down at my daughter's apt at college so I have done all of the troubleshooting via the phone and text messaging (with images).
I originally set everything up for them -- pretty simple setup -- standard cable box hooked up to TV via coax. DVD player is not a blue ray, just an inexpensive one that has L/R audio in and 1 video in plug (3 RCA plugs).
I cannot get them to tell me whether the sound is out when using DVD because the DVD player has gone out.
The only thing that I thought was very weird was that the RESET AUDIO DEFAULTS option was grayed out -- so I had them unplug the set overnight and still grayed out today. I had tried walking them through all the options over the phone (I have the 58" Panny so I was walking them through the screens/options/etc and when we came across this Grayed out at the top of the Audio Menu, I thought it was very odd.
AFAIK, nothing was changed as far as setup options -- the girls have left it alone since I set it up and everything was working fine.
I'm trying to figure out/understand why the Audio Reset is grayed out -- if it was locked up/caused by a power spike even though it was in a good surge protector.
If the sound is out, I've read it's the main board -- and it is easy to replace yourself. If all I would have to do is find the right part, order it and put it in, I would do that. When I bought this set it was around $600 -- I know they're a bit less now but the picture is still great. Would hate to trash it yet wouldn't want to pay $200 or more to have it repaired either.
Any advice/suggestions you could provide would be most welcome.
post #3159 of 3189 Old 09-02-2011, 02:32 PM
DLim98's Avatar
Quick question. Does anyone know if you have speakers connected via optical out, if you can still control the volume from the tv?
DLim98 is offline
post #3160 of 3189 Old 09-02-2011, 03:39 PM
_thx1138_'s Avatar
You would use your Receiver that's my recommendation..turn you tv sets speakers to the "off" setting! Some people put their receiver on a volume setting which is comfortable and use their cable box to turn the volume up or down (on the box) if possible. Others may prefer to program their cable remote to control the TV (which would be basically to turn the set on), their receiver (to change between sources like tv,DVD,radio and adjust volume), and their cable box (to switch channels). This is what I do I control everything with my cable box remote which I programmed but I have my tv speakers off and I have my cable box connected to my receiver via optical, and my ps3 via coaxial on my receiver. On my cable box i have dolby digital as my default format output..I put the cable box volume to the max and locked that so no one messes with it and control my desired volume level on my receiver. You follow?
post #3161 of 3189 Old 09-06-2011, 04:16 PM
Avalon65's Avatar
I'm trying to route the signal from the digital audio out of my TC-P42x1 into my Cambridge Audio DacMagic DAC so I can play the sound from my 2-channel stereo system. Does anybody know what signal is being sent from this output? My DacMagic can only accept a 2-channel PCM signal. It appears that is not the signal being sent by the TV. Does anybody know if I can change this setting to get a PCM signal? Does it matter the what the source of the signal is (DVD, antenna, etc)? FYI. I am not using an HT receiver. I should have paid more attention when I bought this set. Had I known there was no analog audio out, I would have gone with the Sammy.
Avalon65 is offline
post #3162 of 3189 Old 09-06-2011, 10:41 PM
DLim98's Avatar
So I would be able to have a receiver set at a volume and use either the tv or cable volume. The reason I ask is instead of buying a receiver I'm going to hook the tv up to a dac, but the dac only has analogue volume controls. I just wanted to make sure that the optical out doesn't bypass the tv's volume control cause I know sometimes it could.
DLim98 is offline
post #3163 of 3189 Old 09-07-2011, 09:06 AM
zachgeo's Avatar
I use a dac (with no volume controls) and my TV speakers stay on. You can control the volume on the TVs speakers using the volume control, but not the receiver's volume. You will need to control the receiver separately.
zachgeo is offline
post #3164 of 3189 Old 09-07-2011, 11:51 AM
DLim98's Avatar
I'm glad I asked in that case haha. So if I have a dac connected to the audio out there is no way to control the volume that is coming from the tv to the dac, but I the tv volume controls would adjust the tv's speakers? Dang that is what I was afraid of. Looks like I need to get a receiver. I was really hoping that the tv would have variable audio out :/
DLim98 is offline
post #3165 of 3189 Old 09-09-2011, 06:44 PM
_thx1138_'s Avatar
I got the Spears & Munsil HD Benchmark Blu-ray Edition disc yesterday. I went through the calibration tests and found that when I got to the "Clipping" test I had to lower the Contrast down to 46 to make the smaller boxes appear within the larger boxes. This was mostly due to the red and green boxes. Pre-Spears & Munsil I had the contrast up in the 80's, which is where most people who have posted calibration settings have it pegged. The actual "Contrast" test did not show me anything to make me lower it that low (maybe I just missed the signs), but per the "Clipping" instructions, "If either of these [...patterns all are solid with no visible steps...some of the steps look wider than others...] occurs, try lowering the contrast control just until all levels are distinct and visible..." Does anyone have thoughts on what I found?
I found the same problem after I applied dnices settings it was just too much everything was over blown in a way.. I consulted with another member and made some minor adjustments to my set with the spears and munsil disc and now everything is right as rain!
post #3166 of 3189 Old 05-05-2012, 08:37 PM
Millott's Avatar
I had originally started following this tread back in early 2010 or late 2009 when I ordered my P50X1 as a cheap cost effective stop gap solution when our JVC HD-ILA 56FN97 started blowing bulbs much too fast and developed some dark patches that looked like finger prints right as it seamed everything was breaking all at once in our lives.
Truly had everything from reciever, two other older bedroom tv sets, tv stand, washer & dryer, microwave and car troubles all in a very short time period which was also the holiday season (which is also our three kids bday season to boot) and from this threads I chose this TV to be our hold us over display and our first plasma inspite of my wifes fears and our naive friends warnings of burnin and lower quality compared to LCD.
I know its late and now with this thread long since dormant nobody will likely see this but I would just love to say thank you so much for steering me towards this set and turning our family into a plasma family.
From day one we were blown away by the picture quality, colors, motion, black levels, etc but after all those things breaking so close together I was unwilling at the time to mess with the service menu. I found a used VT20 for an incredible deal back in Febuary of this year which free'd up the X1 for bedroom duty.
I then decieded that I was now willing to risk the service menu and went in and tweaked the picture using Dnice's offsets and just wow. Even now with the VT20 (also using his SM offsets and settings tweaked slightly for our enviorment) the picture on the X1 is just beautiful.
I have friends with far more expensive sets (newer ones too) who are just blown away by the 50X1 and even more so admittedly by the 50VT20 who would flip if they knew they had spent nearly if not more then 2X more then I did on the two sets combined for their lesser picture quality.
I know how floored I was going from a pretty pricey top of the line (at the time) JVC HD-ILA 56inch 1080P set to what I was expecting to be a budget 720P plasma for nearly a fourth of the price (hell it was damn near the same as the cost of the lamps we'd gone through in 30 months with the JVC) when we fired up that X1 the first time.
So just incase any of the regulars from back then ever still check out this thread, I wanted to say thank you so much. If only i'd been turned into a plasma guy in time to get in on the Kuro's life would be so much easier, that said i'm still loving my Panny's and i'm eyeing stepping up to a 55-65 incher this year.
Millott is offline
post #3167 of 3189 Old 06-02-2012, 11:24 AM
jcmance's Avatar
I was able to procure atc-p50x1 from my brother for nothing. Only problem was the tinted screen played catch with his remote. It dropped it. Anyways, broken screen. Decided to replace with a piece of glass. Carefully disassembled the TV and finally made it to the broken piece of glass. Wasn't spending much so decided to replace it with a regular piece of window glass from the local glass co. $40 and some foam weather stripping and was good to go. Reassembled and now have a 50" plasma in my man town.
jcmance is offline
post #3168 of 3189 Old 06-19-2012, 05:55 PM
peecee69's Avatar
I'm looking for a stand. I just picked up one of these from Craigslist and it was mounted to the wall. The owner didn't save the stand, so I'm hoping someone in this thread will take pity on me and sell me theirs.
Paul
peecee69 is offline
post #3169 of 3189 Old 12-30-2012, 08:09 AM
haichi's Avatar
I have an Overscan issue with my TC-P50X1
I was hoping maybe in the history of this thread someone found a solution to this problem. Is it correct that this set has no way to turn Overscan off?
I was able to live with it for a few years but now that I plugged in my new Wii U I would like to find a way to get more of the space that is getting cut off.
Any Service Menu step by step tips?
I read someplace online change H Size 1 to Size 2 but this is always grayed out for me in HD can only change it with SD sources.
haichi is offline
post #3170 of 3189 Old 12-30-2012, 10:10 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Since this is a 720p set, unless you are watching 480p or lower rez content, you can not.
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
post #3171 of 3189 Old 01-15-2013, 01:48 PM
niceguy88's Avatar
Well since this got bumped lol, I have a question: I've had a TC-p42x1 (came from Sam's Club) for around 3 years now (either 2 or 3). This TV didn't come with built in Netflix streaming,etc so is there any way to stream wirelessly from a laptop?
I do have an Xbox 360 hooked up but as far as I know, you have to pay MS for a stupid Live membership. I don't do online gaming and I hate the idea of paying more for streaming.
Is there any workaround this?
Thanks guys!
niceguy88 is offline
post #3172 of 3189 Old 07-25-2013, 09:10 AM
shutdown20's Avatar
Thanks guys!
I know it's been a while since you posted this, but you might want to check out Chromecast from Google. It is an HDMI dongle that plugs in to an open HDMI input and uses USB for power. It is brand new, as of yesterday, and at the moment works with Google Play TV and Movies, Google Play Music, Netflix, and Pandora over wifi. You can also play media that you have opened in a Chrome Browser on a PC/Laptop sharing the same network. I will be receiving mine today and will test it out on my TCP42X1 later tonight. It can be found at amazon.com, the google play store, and will be availablie in Best Buy starting this Sunday, July 28! The best part is that it is only $35 and, at the moment, comes with 3 months free of Netflix. It's worth a try!
shutdown20 is offline
post #3173 of 3189 Old 08-17-2013, 08:18 PM
hellwings's Avatar
Hi all.
I have a Panasonic 42x10b that i bought here in Brazil. Its a great TV, but i think i need update its firmware, since i havent the option to turn off the overscan.
Do you know where i can found the update firmware for my TV, because i was looking at the panasonic websites, but i found none!
Thanks in advance!!
hellwings is offline
post #3174 of 3189 Old 08-17-2013, 08:38 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
hellwings,
The x1 series has no method for defeating the overscan. You will find no help in the service menu either. The overscan is hardwired into the TV. (I still have a 42 inch one in my guest bedroom.)
Larry
post #3175 of 3189 Old 08-17-2013, 08:44 PM
hellwings's Avatar
larry, thanks for the fast answer. Let me do another question:
There is any difference between the x1 and x10b plasma models? Because mine is a x10b, not a x1... I just saw this right now while iwas waiting for an answer.
Sorry if i post in the wrong topic...
post #3176 of 3189 Old 08-17-2013, 08:50 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
If you are talking about the 720p 2009 model, there probably is no basic difference between the X1 and the X10b with regard to the overscan issue.
Larry
post #3177 of 3189 Old 12-30-2013, 01:02 PM
J-e-L-L-o's Avatar
Quoted: 17 Post(s)
I have to say I love this tv. I have a Phillips 1080p LCD set, I have always liked plasmas since I love movies..but I didn't expect the gaming to be so good!
I am playing COD on my girlfriends and I am constantly top 3 on my team. There is no bouncing around of people on the screen and way less lag than my tv at home. 1080p is not an issue and thinking of finding a 42 or 50in for my house because the picture is really great.
Panasonics are awesome!
J-e-L-L-o is offline
post #3178 of 3189 Old 04-22-2014, 03:01 PM
Nixterdemus's Avatar
Nothing quite like dredging up an old thread. I subscribe to Fidelity Cable & recently opted for a couple of their new/cheap HD converter boxes w/HDMI. So, I snagged a refurb Samsung and relocated the P50X-1 to the bedroom. The Panasonic doesn't jive w/converter box after powering back up from off. I get a lavender hue that covers the entire screen as if layered over the screen from all 3 HMDI ports. Now, I can power down the box, by unplugging, then bring it back up, but I have to go into the menu to select 720 resolution again. I think. The other easier option is to unplug the HDMI cable and slam it back in providing instant pic ready to roll. It isn't the set/processor because I have a P42X1 as well and it does the same. I also tried the box from the Samsung w/same results. I need to be able to disconnect the HDMI via a remote somehow. Otherwise I'll have to chunk the box & the HD resorting to SD plugging the cable directly into the set.
I'm all ears for ideas.
I've had the sets for almost 5 yrs and they're still chugging along nicely. The person using the 50" is older & I'm trying to keep this as simple as possible, so the 720 can be enjoyed. I'm not sure why there's a connection snafu after turning the set off or why I have to jump start the box every time the TV powers up.
Nixterdemus is offline
post #3179 of 3189 Old 04-22-2014, 04:33 PM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
Originally Posted by Nixterdemus View Post
Nothing quite like dredging up an old thread. I subscribe to Fidelity Cable & recently opted for a couple of their new/cheap HD converter boxes w/HDMI. So, I snagged a refurb Samsung and relocated the P50X-1 to the bedroom. The Panasonic doesn't jive w/converter box after powering back up from off. I get a lavender hue that covers the entire screen as if layered over the screen. Now, I can power down the box, by unplugging, then bring it back up, but I have to go into the menu to select 720 resolution again. I think. The other easier option is to unplug the HDMI cable and slam it back in providing instant pic ready to roll. It isn't the set/processor because I have a P42X1 as well and it does the same. I also tried the box from the Samsung w/same results. I need to be able to disconnect the HDMI via a remote somehow. Otherwise I'll have to chunk the box & the HD resorting to SD plugging the cable directly into the set.
Doesn't your cable box offer component video outputs? You may have better luck just using them. My brother in law has a TC-P42C1 and there is very little difference in PQ when using component verses HDMI.
Ian
mailiang is offline
post #3180 of 3189 Old 04-22-2014, 04:56 PM
whipit's Avatar
Quoted: 98 Post(s)
Liked: 84
If the cable box will support it you may want to try feeding the tv a 1080 signal.
whipit is offline
Panasonic Viera X1 Series Tc P50x1 50 Inch Plasma Hdtv
