Philips 42PF7321D/37 Blue Dot Problem Fix - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-03-2009, 03:54 PM - Thread Starter
rbringh's Avatar
http://forums.legitreviews.com/about14611.html original link with picture of issue.
Service Tech then calls a Philips service support hotline and gives them a numeric password. He then gives them my model number and tells them it has blue dots. I hear him say that he checked the voltages and confirmed the voltages with them. He then said that isn't what the inside of the TV shows... It turns out Philips/Samsung has lowered the voltages on the Television in a service bulletin.
The test points labeled inside my TV set shows
VE- 110v
VS- 198v
Vset- 195v
The new factory voltages should be
VE- 100v
VS- 190v
Vset- 188v
Tech used a voltmeter to set/check them and adjusted the pots on panels... When the repair guy called the repair service line they were well aware of the problem and knew the fix right away. I hope me peaking over his shoulder and copying down the correct settings helps out someone else with this problem and will save them the $200 service fee that I just paid. Remember these settings are for a 42PF7321D/37 model Philips TV, so if you have a different version you will need to get a service tech to call and get the right voltages from Philips.
All is fixed now!
By the way all componets in this TV are Samsung and are labeled as such.
rbringh is offline
