The Official Panasonic TC-PXXS1 Owner's Discussion Thread - Page 265 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #7921 of 7930 Old 06-22-2016, 03:48 PM
cram501's Avatar
Liked: 2
Originally Posted by galonzo View Post
I just ordered one of @audiodane 's Panasonic Plasma Black Level (MLL) Restoration tools mentioned a few posts back (I hope he still has some in stock, I know he was planning on getting rid of this remaining stock), I'll be sure to report my results here
I did buy one of those. It did appear to help the black level. I had nothing to measure it with so take that for what it's worth.
I believe the overall black to be fine. My problem seems to be with the contrast between dark and darker. Dark scenes are now really hard to see any detail between shades of dark grey/black.
The lighter colors seem fine. I am still playing with settings but have the brightness up in order to help off set it but that just makes the picture look like crap.
galonzo likes this.
cram501 is offline
post #7922 of 7930 Old 06-22-2016, 05:07 PM
Quoted: 23 Post(s)
Liked: 2
Originally Posted by Michael Vincent Praino View Post
How do you check the hours on it?
There's a link on google somewhere that shows you how to access the service menu where you can see usage.
Living Room
LG OLED 55" B6
Sonus Faber Venere 3.0's
Definitive Technology Supercube 2000
Marantz NR1606
Rotel RB1590
Faezan Mob Odhwani is offline
post #7923 of 7930 Old 06-22-2016, 07:25 PM
cram501's Avatar
Liked: 2
Google "panasonic tv time used" and you will find a number of forums that will walk you through it.
cram501 is offline
post #7924 of 7930 Old 08-30-2016, 07:15 PM
aohus's Avatar
Is the PMCv2 worth getting even if you updated the firmware to the latest 2.26 version (from 2013)?
From what I gather, the latest update helped clear dim/dark PQ issues and the black levels look restored.
Is it still worth to get the PMCv2?
http://audiodane.dandk.org/pmcv2/
Can't you just run the firmware update every 150 hours or so as well?
aohus is offline
post #7925 of 7930 Old 11-26-2016, 08:30 AM
Lend27's Avatar
Can't update firmware on my TC-P50S1
I see there was a firmware update in 2013, and I would like to bring my TV up to date.
I followed the instructions here:
http://shop.panasonic.com/support-only/TC-P50S1.html
I downloaded the zip file and copied the extracted firmware folder to a newly formatted 1 GB SD card.
When I insert the card in my tv it just brings up the sd card viewer and says "no photos".
If I insert an SD card with photos it displays them properly. Nothing wrong with the SD reader, but it
just won't boot the firmware files.
Any ideas?
Thanks guys!
Len
UPDATE:
I was already at the latest firmware rev 2.26, that's why it wouldn't read the SD.
Lend27 is offline
post #7926 of 7930 Old 11-30-2016, 07:07 PM
Methodical_1's Avatar
Quoted: 333 Post(s)
Liked: 133
Any ideas?
Thanks guys!
Len
UPDATE:
I didn't even know there was an update. One of the issues I noticed it fixes is an issue I am having - intermittent audio drop outs. Does updating change any of the tv settings?
Also, how do you know what firmware version you have? I looked through the menus, but found nothing on firmware.
Methodical_1 is online now
post #7927 of 7930 Old 12-02-2016, 01:08 PM
Lend27's Avatar
How to check your firmware version
Go to the site, it's a PDF:
https://www.google.com/url?sa=t&rct=...2vS1LxdiAj-99w
Then go to the Self Check section.
It tells you how to check your firmware version. I did it and it was easy.
Len
Lend27 is offline
post #7928 of 7930 Old 12-02-2016, 01:10 PM
Quoted: 333 Post(s)
Liked: 133
Thanks. I will check.
post #7929 of 7930 Old 04-20-2017, 04:59 PM
Astropin's Avatar
So I've had my S1 for seven years now and it's still going strong! Best flat screen I've ever purchased (so far).
That being said it is moving to the basement. Had my old (2004) Samsung 61" DLP down there and it finally crapped out (for the last time)...I'm not spending any more time or money fixing it so out it goes. So the Panny plasma will replace it in the basement and a Sony 65" XBR 4k will be replacing the Panny. It should arrive on Saturday. Of course I never thought about upgrading my AVR or DirectTV becasue of 4k....Doh! No rush to to that though since Direct TV really doesn't have much content yet and I can still get Netflix and Amazon (and YouTube) programming in 4k without needing to upgrade anything. I'm sure at some point I'll upgrade the Direct TV, AVR and add a 4k Blu-Ray player into the mix.
Hope it last as long as my Panny (which will still get regular use actually).
2004 61" DLP - Over 3k (new)
2010 65" Panny Plasma - 2.1k (new)
2016 65" Sony XBR930D 4k - 1.4k (open box)
I like the trend. Maybe next time I can get a 70"+ OLED for 1k.
galonzo likes this.
Astropin is online now
post #7930 of 7930 Old Today, 09:34 AM
Quoted: 333 Post(s)
Liked: 133
I still have mine and wanting a 75 4k, but those few inches makes the prices jump significantly. I'll wait them out until around the end of the year when they are giving them away.
HT Configuration: 7.2.4 l Panasonic Plasma (65") l Denon X4300H l Mono 7 amp l Behringer FBQ3102 EQ l Polk RTi10s l Polk CSI-5 l Polk FXi-30 (x4) l Infinity ERS-610 (x4) - Atmos l SVS PB-2000 l Polk PSW 505 (temp) l Oppo BD-93 l Denon CD player/Turntable 1 Cassette Deck l
Subwoofer Trim and Audyssey EQ setup guide
Panasonic 42 Inch Fhd Plasma Display
