The Official Panasonic TC-PXXS1 Owner's Discussion Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #91 of 7930 Old 03-09-2009, 03:16 PM
Arcona's Avatar
Originally Posted by marka04 View Post
I just got an email from my ISP, I violated the AUP by going over the bandwidth limit and they removed the site
You can use photobucket.com or imageshack.com
Arcona is offline
post #92 of 7930 Old 03-09-2009, 03:26 PM
shiznit93's Avatar
Just sold my 42PZ80U to a friend, he needed a tv and was about to buy LCD so I put an end to that and sold him my Panny for what I paid for it (I got a really good deal back in september) knowing I was getting either one of these or a Kuro.
Can't wait for the S1 series to start showing up, I miss my panny plasma so much. Too bad they will still have judder, for the price of the ones with 24p playback I might as well get a Pioneer, right?
shiznit93 is offline
post #93 of 7930 Old 03-09-2009, 04:09 PM
TommyO's Avatar
Would this be why I also cannot see the photos? All I see is red X's here.
Thanks if anyone can advise me; I'm not too tech savvy here folks.
TommyO is offline
post #94 of 7930 Old 03-09-2009, 04:51 PM
rob76's Avatar
I'm new to plasma, what causes this judder?
rob76 is offline
post #95 of 7930 Old 03-09-2009, 05:40 PM
shiznit93's Avatar
it's not just plasma, any 60hz tv has to use 3:2 pulldown to convert 24fps film to 60hz. The side effect of this is telecine judder.
Previous panasonic models used to double the 24fps signal and display it at 48hz, I have never seen it in action but others say it flickered. Pioneer triples it to 72hz and most people say it looks great.
post #96 of 7930 Old 03-09-2009, 06:34 PM
prozak's Avatar
I just got back from Sears and I got a chance to look at the S1 series and I have to say I feel a tad disappointed. Someone else has mentioned that these sets introduce a lot of noise into the picture, and they do!
I noticed this mostly on faces. The S1 was sitting next to an LG plasma and a Sony LCD. The sony had much much deeper blacks but it was experiencing black crush. Curiously, the LG plasma also had a lot of noise in the set but less than the Panasonic. The Sony was very very crisp, you could see a ton of detail on the faces but both plasma's lost a lot of detail to what I would call "white noise". All the tv's at sears were playing the same loop which consisted of a bunch of different things from video games to concerts.
On a bit of a side note, the difference between 1080p and 720p is bigger difference on a 42" set than what most people seem to imply. At about 5 feet back I could tell the difference, but then again, I do like to set close to tvs.
prozak is offline
post #97 of 7930 Old 03-09-2009, 06:45 PM
rob76's Avatar
Yes at 5 feet you can fully notice the difference between 720p and 1080p. At 10 feet, unlikely. I don't usually trust these looping feeds to be of very good quality, nor the connections.
rob76 is offline
post #98 of 7930 Old 03-09-2009, 06:46 PM
rob76's Avatar
I mean, it's sears... what kind of bozos do they have hooking their stuff up?
rob76 is offline
post #99 of 7930 Old 03-09-2009, 06:47 PM
rob76's Avatar
It's weird because movie theaters use 48hz. Do the new sets now run it at a higher frequency with this new 600hz thing?
rob76 is offline
post #100 of 7930 Old 03-09-2009, 06:57 PM
rob76's Avatar
I always hate the choppy panning on movies. Even in the theatre, it makes me dizzy.
rob76 is offline
post #101 of 7930 Old 03-09-2009, 07:14 PM
2ntense's Avatar
I went to BB and looked at the 50" S1. I have to say the body is a great improvement. Other than that I couldn't really mess with it as a ladder was in the way!! Oh well, I asked when the 42" would be in and a guy in sales said the 23rd. I want the 42 S1 but does the G10 support 24p? If so I guess I'll wait for it instead.
2ntense is offline
post #102 of 7930 Old 03-09-2009, 07:19 PM
santori_time's Avatar
Plasmas do tend to be a bit noisier than LCDs by virtue of the way they display the picture (I believe it is referred to as PWM noise). However, the point is moot as we are making comparisons with a Sears demo loop.
Current Equipment:
Panasonic TC-P42G25
Logitech Z680 5.1
Xbox 360
PS3
Gaming PC (Core i7 2600, GeForce 670, 16 GB RAM)
santori_time is offline
post #103 of 7930 Old 03-09-2009, 07:22 PM
Shawn1's Avatar
Quoted: 21 Post(s)
Liked: 26
I have a feeling that Panasonic's 2009 Neo PDPs are going to be a type of display that looks like garbage on the retail sales floor, but once you get it home and do what you need to do with it to get it to look its best, it will look incredible.
Shawn1 is offline
post #104 of 7930 Old 03-09-2009, 07:46 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Let me guess, the tv was in store vivid mode. Unless you put it on Cinema what you saw really doesn't matter.
I don't know what it is with Sears but I've been to two or three of them where they just had a stretched SD feed hooked up to all the tvs and it obviously looked terrible.
StinDaWg is offline
post #105 of 7930 Old 03-09-2009, 07:49 PM
prozak's Avatar
It's not likely that Sears is trying to sabotage the plasmas. It doesn't matter if the sears loop is garbage or if their connections are garbage because they should all be connected the same way and I was comparing three sets right next to each other. If the sears loop is garbage and their connections are garbage the Sony LCD and the Plasma's should all have shown the same white noise, but the Sony showed none.
It just doesn't add up that the Plasma's exhibit white noise. I could understand something like the color being off because its not calibrated, but I've never heard of a setting that reduces white noise. Sure you can put in good cables but then we go back to my first argument, that if the cables in sears were bad then the Sony should of showed similar flaws.
What Santori is saying about plasma's being noiser makes sense to me though, since the noise is something I saw on all of the plasma's to varying degrees that I didn't see in the LCDs. The panasonic though was particularly bad.
*edit*
StinDaWg,
So what you are saying is that the vivid setting in the panasonic introduces a lot of noise into the signal? Can someone who has the set or played with it confirm this?
prozak is offline
post #106 of 7930 Old 03-09-2009, 07:50 PM
2ntense's Avatar
BB's was set to Vivid as well. Silly.
2ntense is offline
post #107 of 7930 Old 03-09-2009, 08:11 PM
vader8806's Avatar
when any panasonic set is set to "store" mode instead of "home mode it resets to vivid automatically every 3 min......this is per manufacturer
vader8806 is offline
post #108 of 7930 Old 03-09-2009, 08:13 PM
vader8806's Avatar
my store is set to a 1080i 26 min loop....but often when the loop is intalled the tech screws up and it is recorded at 480p
post #109 of 7930 Old 03-09-2009, 08:45 PM
I vaguely recall that the THX mode on the pz800 models had significantly less noise than the other modes, so maybe the same applies here.
Current Equipment:
Panasonic TC-P42G25
Logitech Z680 5.1
Xbox 360
PS3
post #110 of 7930 Old 03-09-2009, 08:46 PM
ercc's Avatar
Prozak:
The TV was in vivid, and has nothing to do with anything regarding the TVs real technical capabilities. This fake mode massively over enhances the sharpness of the signal and one of the common side effects is noise when viewed close up. The sony may have had a more effective torch mode that squelched the noise better, but that is simply a useless torch mode done differently.
Basically with torch mode the display is drawing its own picture on the fly, based on some of the real info from the source. But the source is completely butchered.
It is also common for quality of feeds to vary widely within the same store.
Obviously the set needs to be evaluated with the proper 'home' viewing modes. I think we are all expecting a very high performing display that hopefully improves further on the well-regarded pz80 series of last year.
ercc is offline
post #111 of 7930 Old 03-09-2009, 09:08 PM
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
damnit, the Pics wont show for me....
WaveBoy is offline
post #112 of 7930 Old 03-09-2009, 09:46 PM
rob76's Avatar
So telecine judder...is that when the picture sort of bobs around like it has epilepsy? I mostly notice that in the rolling credits and other slow moving things. I currently have a tiny ass 27 inch CRT. It doesn't bother me too much right now but I do notice it. I can imagine it's much more noticeable on an HDTV with the larger picture.
rob76 is offline
post #113 of 7930 Old 03-10-2009, 03:17 AM
oldgrumpy's Avatar
Originally Posted by RandyWalters View Post
Also, the G10 has been released in Europe and the specs show 6,144 Shades of Gradation but i'm wondering if the the S1 will have 4,096 like the X1 or 6,144 like the G10. So far there is no official mention of the S1's spec from Panasonic. If it's 4,096, the G10 might be the better choice.
The S1 in Europe has 5120 shades of grey, 4096 on the X1, and 6144 on G10 upwards
. But the Europe specs can be different to USA, eg. X1 sub-field drive in Europe is only 400Hz and the S1 is not Neo-PDP panel.
oldgrumpy is offline
post #114 of 7930 Old 03-10-2009, 04:43 AM - Thread Starter
marka04's Avatar
I'll try to repost them tonight.
marka04 is offline
post #115 of 7930 Old 03-10-2009, 06:23 AM
RoyG's Avatar
Sears.....
Just happened to be there yesterday to try and see one of these new Pannys. Not here yet(one of the few drawbacks to living in the boonies . While there I overheard this conversation.
Sales Rep. "May I help you"
Customer "We are looking for a TV"
(of all the questions to be asked to really help the customer. this is the one she came up with)
Sales Rep. "Do you have a brand in mind?"
Customers "We have heard that both that Sony and Samsung is best. What do you think?"
Sales Rep. "Oh I would chose the Sony"
I walked out then. As they say "We get what we deserve"
Roy
RoyG is offline
post #116 of 7930 Old 03-10-2009, 06:30 AM
rob76's Avatar
I'm surprised the salesman had such poor grammar. Must have been from the south!
rob76 is offline
post #117 of 7930 Old 03-10-2009, 06:41 AM
RoyG's Avatar
LOL
Yes I guess the south. It seems sometimes neither want Ky sometimes. But probably it is due to the Loritabs I am taking effecting my typing????
Roy
RoyG is offline
post #118 of 7930 Old 03-10-2009, 07:50 AM
caeguy's Avatar
I thought the same about the noise on the Panny until the Panny internal ad came up. The one that talks about Viera link and 600 sub-field. That looked perfect! no noise at all. So i assume its the source.
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
post #119 of 7930 Old 03-10-2009, 09:44 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
StinDaWg,
Yes, that is exactly what I am saying. The only modes that are acceptable to watch on Panasonics are Cinema and THX.
StinDaWg is offline
post #120 of 7930 Old 03-10-2009, 12:18 PM
prozak's Avatar
Originally Posted by ercc View Post
Prozak:
Ok you are both basically saying the same thing, so you've restored my faith in this set. I'm just going to wait for the reviews between the S1 and the G1 now.
prozak is offline
Panasonic 42 Inch Fhd Plasma Display
