The Official Panasonic 12G Settings/Issues Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
Old 03-23-2009, 05:03 PM
lucky logan's Avatar
Originally Posted by whiteboy714 View Post
Honestly I loved it as well straight out of the box. Its just that the more I read here the more I wanted to tweak it to make it better.
Although the other day I was admiring the picture quality, then went into the menu and noticed I had in on standard mode with all the settings like they were at default lol.
LOL - This is definitely the place to learn all about the X-1! Maybe a little too much info for non electronic people like me But I have found myself addicted to this forum I may venture into the SM down the road but for now I LOVE THE 50X-1 the way it is!
lucky logan is offline
Old 03-23-2009, 06:38 PM
youngnahj's Avatar
Originally Posted by StinDaWg View Post
Not everyone likes an industry standard calibrated picture. I can't stand the warm color temp look so I will never be one of those people that pays for a calibration. I also am not one of those people who likes a vivid people you see at the stores, I want something in between. That is why I will take settings posted here as a starting point and then change to my liking. It doesn't make sense to pay $1000 for a tv and then not watch it the way you like because technically it is "incorrect".
If you think about it we probably represent less than 1% of the population who actually understands what calibration and an "accurate" picture is.
I went over to visit a friend's house and he had a lcd in vivid mode set up. Picture was way too bright and there was no detail in the blacks. When he was in the other room I changed the setting to Cinema and immediately the picture looked better. He probably won't even notice the difference though.
You'd be amazed at the amount of people who buy a tv, plug it in, and just leave it as is.
I just did the same thing last weekend at my friends house on his Sam A550, he was already in love with the PQ and then i tweaked it according to the official thread here on AVS and it looked extremely better, but I doubt he really can see the difference lol.
youngnahj is offline
Old 03-23-2009, 07:13 PM
smilejedimind's Avatar
Quoted: 14 Post(s)
ok so im confused on how to do this whole sm set up ive spent the time to break in properly and everything i can get in to the sm menu and what not, but as for the values im confused these are the values i see i dont believe i messed anything up but if someone would please help me set it would greatly appreciated. this is for the 42inch
sub brt 000
r,g,b cut 80
r drv f8
g drv fd
b drv a3
all 80
all drv fd
its on warm and on cinema
smilejedimind is offline
Old 03-23-2009, 07:37 PM
outsidordinary's Avatar
should the all cut and all drv values change after the other ones are changed to the new offsets? anyone know? I just noticed that mine have
outsidordinary is offline
Old 03-23-2009, 08:04 PM
C*Tedesco's Avatar
Quoted: 40 Post(s)
Liked: 56
So I just burned Evangelo2's Break-in DVD and wanted to make sure it worked, so I'm using it in my ol' CRT to test on. So for what feels like the first 5 minutes, the color is white, just when I thought it didn't burn correctly, the colors start changing. Question is, should this be this slow? How would I speed it up if that's the case?
This might not even be revelant because I have an S1 and I'm waiting for the settings for that for the break in.
S1 coming later this week, just preparing for it. thx.
C*Tedesco is offline
Old 03-23-2009, 08:38 PM
hydroponik's Avatar
Quoted: 22 Post(s)
It's perfectly normal, I believe the first minute or two are just white, then it will start changing colors every 30 secs.
hydroponik is offline
Old 03-23-2009, 08:57 PM
whiteboy714's Avatar
sub brt 000
r,g,b cut 80
r drv f8
g drv fd
b drv a3
all 80
all drv fd
Yah that looks right pretty much like mine was, a tiny bit off but I guess thats normal.
Now you just apply dnices offsets. Dont worry about the values.
If it says R DRV -33, then hit volume down 33 times. Thats all you gotta do. Everyones before and after values can be a tiny bit off it seems.
whiteboy714 is offline
Old 03-23-2009, 10:03 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Yes. They assume tha maximum value of the rgbcut and rgbdrv repectively. Also, just to add more to the confussion, increasing/decreasing allcut or alldrv wiil change all the cuts or all the drvs by a respective amount.
Larry
LarryInRI is offline
Old 03-24-2009, 05:43 AM
walt73's Avatar
Is it possible to get the P50X1 down to 0.0% overscan, so that it upscales a 1280x720 image (say from a games console) to 1366x768 and displays it at that res? (Instead of upscaling it still further and cropping the sides of the image?)
Looking at the manual it doesn't appear that this adjustment is available in the regular user menu and I can't tell from LeM22's pics in post #183 above whether the option is in the service menu.
TIA to any P50X1 owner who can answer this.
"... we wonÂt be stopping plasma production any time soon. We see it going on for another ten years." -- Kevin Lee, VP, Smart TV Partnerships (Samsung), 1/7/11
walt73 is offline
Old 03-24-2009, 05:21 PM
oldgrumpy's Avatar
With overscan set "off" it wont crop the picture.
oldgrumpy is offline
Old 03-24-2009, 05:22 PM
BUFFALOSOLDIER's Avatar
TC-P42X1/50X1 Reference Settings
Which is the latest settings ?? thanks
Picture:
Picture Mode: Cinema
Contrast: 80
Brightness: 78
Color: 30
Tint: G8
Sharpness: 42
Color Temp: Warm
C.A.T.S: Off
Video NR: Off
Advance Options
MPEG NR: Off
Black Level: Light
Service Menu Offsets
ADJUST MENU
SUB-BRT: -1
WB-ADJ MENU
R-DRV: -2
G-DRV: -30
B-DRV: -12
R-CUT: -33
G-CUT: -27
B-CUT: -24
OR
Picture:
Contrast: 80
Brightness: 62
Color: 30
Tint: G8
Sharpness: 42
Color Temp: Warm
C.A.T.S: Off
Video NR: Off
Advance Options
MPEG NR: Off
Black Level: Light
ADJUST MENU
SUB-BRT: -1
WB-ADJ MENU
R-DRV: +4
G-DRV: -30
B-DRV: -12
R-CUT: -8
G-CUT: 0
B-CUT: -1
BUFFALOSOLDIER is offline
Old 03-24-2009, 05:33 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
WB-ADJ MENU
R-DRV: -2
G-DRV: -30
B-DRV: -12
R-CUT: -33
G-CUT: -27
B-CUT: -24
See post #2 of this thread. The intent is clearly stated.
Larry
Old 03-24-2009, 05:58 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
There are overscan controls? Where? The consumer models haven't had that option for years.
chrisherbert is offline
Old 03-24-2009, 06:02 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Is this in the service menu because there is no adjustment in the regular menus.
StinDaWg is offline
Old 03-24-2009, 06:09 PM
Maybe he thought you were using a PC, like someone else said if this there its in the SM because I've been all through the user menu.
Old 03-24-2009, 06:13 PM
Blerghass's Avatar
Originally Posted by D-Nice View Post
The lowest minimum luminacne level i could achieve in Cinema mode was 0.015fL. I measured 0.012fL in Custom mode however, it has a S-shaped gamma curve that just does not jiive with me... though others may like it.
D-Nice,
You mentioned before that PX75U blacks were around 0.012-0.014fL. Does this mean that if I buy an X1 I should expect no black level improvement over my PX75U? Or is it wrong to compare these luminance numbers to each other? Thanks!
Blerghass is offline
Old 03-24-2009, 06:44 PM
Quoted: 17 Post(s)
I doubt it's in the service menu. About the only thing you can do in there is adjust grayscale and check the hours.
Old 03-24-2009, 08:59 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
Originally Posted by Blerghass View Post
D-Nice,
Reference to a PX75U with a 0.012FtL black level, please.
Larry
Old 03-25-2009, 03:11 AM
oldgrumpy's Avatar
Sorry, us Brits have an Overscan option on all the Viera models, X1 upwards... In the setup menu.
Old 03-25-2009, 04:41 AM
walt73's Avatar
So is that right -- the North American models of the P50X1 have _fixed_ overscan -- no vertical size and horizontal size adjustments buried in the service menu or a "just scan" or "1:1" mode? (Strange to say "1:1" when you're mapping 720p or 1080p onto 768p but anyway.)
If so has anyone measured the % overscan using the test pattern on the DVE HD Basics disc or similar?
(I'm moving from a 1080i CRT and one of the worst drawbacks with it is an overscan which I can't seem to tweak down to much below 4%.)
walt73 is offline
Old 03-25-2009, 07:25 AM
skroh's Avatar
Man, I've really been on the fence about just getting an X1 and saving the money since user reviews of the PQ have been so positive, but if there's no 1:1 mode without overscan, that kills it for me.
skroh is offline
Old 03-25-2009, 07:28 AM
Blerghass's Avatar
Larry
http://www.avsforum.com/avs-vb/showt...1#post15788331
Old 03-25-2009, 07:38 AM
Quoted: 17 Post(s)
If you want no overscan, get a 1080p model.
Old 03-25-2009, 11:17 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
Yup, that's pretty much your only option.
StinDaWg is offline
Old 03-26-2009, 05:10 AM
Blacklac's Avatar
So the S1 does 1:1?
Blacklac is offline
Old 03-26-2009, 07:43 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 501 Post(s)
Liked: 768
Originally Posted by Blacklac View Post
So the S1 does 1:1?
Yes, with an HD signal. All the 1080p Panasonics have this ability, while the 768p models do not.
From the manual:
(HD Size Setting) Selects between 95% (Size 1) or 100% (Size 2) for the scanning area with High-definition signal..... Select Size 1 if noise is generated on the edges of the screen.
Size 1: Selected item for HD size. Scanning 95%
Size 2: Selected item for HD size. Scanning 100%
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
Old 03-26-2009, 08:10 AM
sadmaker's Avatar
From the manual:
(HD Size Setting) Selects between 95% (Size 1) or 100% (Size 2) for the scanning area with High-definition signal..... Select “Size 1” if noise is generated on the edges of the screen.
Size 1: Selected item for “HD size”. Scanning 95%
Size 2: Selected item for “HD size”. Scanning 100%
ok, my set doesnt get in til saturday. which of these options fills the screen completely? and which shows pic in native?
XBL Gamertag: RagingPhinsFan
sadmaker is offline
Old 03-26-2009, 08:57 AM
Zorfunk's Avatar
D-Nice - Will the new service menu offsets work with the custom settings that you posted earlier?
Zorfunk is offline
Old 03-26-2009, 09:09 AM
ssdark1's Avatar
will someone please explain this overscan issue? is it something i will have to look for to notice? does it effect 720p and 1080p or only 1080p? someone said it is a deal breaker so it must be a significant issue, just wondering as i already have the x1 but am still in my timeframe to return it. thanks.
ssdark1 is offline
Old 03-26-2009, 09:18 AM
dabigwaxy's Avatar
As far as I know, overscan is not an issue. In fact I found to watch TV with overscan off to be kind of annoying as some channels and/or commericals would show up with white flickering lines on the bottom or the top of the screen. When you have a tad bit of overscan this issue is elminated. The amount of softness watchting this TV in FULL mode vs a no overscan mode (which it doesn't have) is tiny. I would not personally find this to be a deal breaker.
dabigwaxy is offline
