The Official Panasonic 12G Settings/Issues Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 4419 Old 03-11-2009, 09:50 AM
chrisherbert's Avatar
Quoted: 17 Post(s)
Originally Posted by BrahmaBull View Post
Probably don't get the same results. Think of the volume control on your PC in windows as opposed to the volume control on your speakers.
If your speakers are down all the way, it doesn't matter how high you set your windows volume.
True, but I wouldn't think any grayscale changes would make a big difference to the recommended brightness or contrast settings. Maybe some but it would be pretty minor.
Sharpness shouldn't be affected at all.
chrisherbert is offline
post #62 of 4419 Old 03-11-2009, 09:51 AM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
Originally Posted by StinDaWg View Post
If we aren't comfortable going into the service menu, will these basic settings still be accurate or do they become worthless without the service menu offsets?
No. Unfortunately you have to plug in these SM offsets due to how bad these sets are without them. Simple user menu settings are not going to help beyond color lumiance levels and picture sharpness.
TC-P42X1_50X1 Pre Calibration Report.pdf 208.8603515625k . file
File Type: pdf TC-P42X1_50X1 Pre Calibration Report.pdf (208.9 KB, 56 views)
D-Nice is offline
post #63 of 4419 Old 03-11-2009, 10:28 AM
skroh's Avatar
Thanks for the pre-cal report, D. Putting it up side by side with the post-cal is very educational.
skroh is offline
post #64 of 4419 Old 03-11-2009, 10:54 AM
whiteboy714's Avatar
ok thanks then I'll be doing it after break in
whiteboy714 is offline
post #65 of 4419 Old 03-11-2009, 11:16 AM
JCBoomer's Avatar
D-Nice, it looks like Panasonic is still over saturating the greens and reds, but the reds look less saturated than last years non-THX models (at least from the few reports I saw). Is the difference noticeable?
Nice work, btw. Wish I had this last year for the 11G's!
JCBoomer is offline
post #66 of 4419 Old 03-11-2009, 11:26 AM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
You will have to wait for my review to get an answer to this question
D-Nice is offline
post #67 of 4419 Old 03-11-2009, 11:34 AM
TayC's Avatar
I know! I'm considering returning my PX80 that I got not too long ago and getting an X1 just to use those settings.
TayC is offline
post #68 of 4419 Old 03-11-2009, 11:36 AM
noc_noc's Avatar
If you see a rainbow on any plasma, you will see them on all plasmas.
Before I had my 9G Kuro I tested a Samsung PN50A656 for a few days and on this set I didn't notice any rainbow. Isn't it possible, that the intensity of the RBE differs from set to set and might be improved in the new Panasonic 12G?
noc_noc is offline
post #69 of 4419 Old 03-11-2009, 11:39 AM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
Intensity? Yes. Completely gone? Not a chance. I don't know how, if and why you see in on a Kuro, so I cannot say 100% whether you would see it on a 12G Panasonic. However, its is very possible.
D-Nice is offline
post #70 of 4419 Old 03-11-2009, 11:43 AM
outsidordinary's Avatar
DNICE, stupid question, how do you get negative or ("-") values in the service menu,, it goes from positive values to letters...
outsidordinary is offline
post #71 of 4419 Old 03-11-2009, 11:46 AM
Quoted: 17 Post(s)
It's really only visible on high contrast material (something like Sin City, which has a lot of stark white on jet black backgrounds). If you didn't see anything that contrasty in the days that you tested the Samsung (which is very possible), then you probably wouldn't notice the trails.
In my experience all plasmas have the trails, and the severity is about the same for all of them. You'll also probably get used to them. I hardly ever see them now.
post #72 of 4419 Old 03-11-2009, 11:47 AM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
The SM settings are offsets. a "-" means you reduce that paticular setting by the number beside it while a "+" means you increase it.
D-Nice is offline
post #73 of 4419 Old 03-11-2009, 11:58 AM
makes perfect sense... i just wanted to be sure. thanks so much
post #74 of 4419 Old 03-11-2009, 12:05 PM
noc_noc's Avatar
I'm not talking about phosphor trails. I'm talking about the rainbow effect which DLP beamer also have. The RBE is also visible with a freezed image.
On my 9G Kuro I see the RBE very often, not only in movies like Sin City. But you're right, perheps I tested the wrong content on the Sammy.
noc_noc is offline
post #75 of 4419 Old 03-11-2009, 12:10 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Could you give us a quick pointer of what to look for, or at least a link to somewhere that explains this better. I don't want to ruin a $1000 tv on my first try.
I have never liked running any of my tvs in warm color temp. It's too red/yellow to me. I prefer normal. If that is the case does this basically make all of your settings useless to me?
Is there any way to disable overscan in the service menu?
StinDaWg is offline
post #76 of 4419 Old 03-11-2009, 12:14 PM
Quoted: 17 Post(s)
The green trails and so called "rainbow effect" are the same thing.
How are you seeing them on a paused image? Are you shaking your head back and forth?
post #77 of 4419 Old 03-11-2009, 12:37 PM
noc_noc's Avatar
I'm not shaking my head, it's enough to move my eyes.
I always thought that the RBE and phosphor trails are two different phenomenons which are both caused by the different latencys of the phosphor. To see the phosphor trails on the Kuro is quite hard in my opinion. Only with some specific test sequences from the Burosch DVD I noticed the yellow trails.
noc_noc is offline
post #78 of 4419 Old 03-11-2009, 12:46 PM
Quoted: 17 Post(s)
Okay, yeah moving your eyes would be enough to do it. I just wanted to make sure we were talking about the same thing.
I think the trails and "rainbow effect" are pretty much the same thing, it just depends on your sensitivity to the different decay speeds of the phosphors. Most people don't really see any effect, some see green/yellow trails, some see the colors separate completely. That's my understanding of it, at least.
post #79 of 4419 Old 03-11-2009, 01:47 PM
benareeno's Avatar
Quoted: 21 Post(s)
If the black levels are no better on the 2009 models, then what are we getting here? Just a more power efficient monitor? Primary color and greyscale were quite good on the PZ800, so unless black is better...I don't see why anyone would want a 2009.
benareeno is offline
post #80 of 4419 Old 03-11-2009, 01:58 PM
DFitty's Avatar
So I thought I'd check out the service menu. Went into it and the screen went extremely bright with a blue menu.
I pushed the arrow keys on the remote attempting to navigate and nothing happened.
I figured since I didn't know how to get around the service menu I should just get out of there.
Turned off the TV and back on and all was normal.
Don't think I could have damaged anything doing that do you?
I'd love to have a properly calibrated display but at the same time don't want to damage my new TV.
Sound about right?
anyway, why does the display go so bright when you enter service mode?
DFitty is offline
post #81 of 4419 Old 03-11-2009, 02:06 PM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
Sound about right?
I'll post SM naviagation instructions later today. If you can't wait, its already posted somewhere in the owner's thread. Just do a search.
D-Nice is offline
post #82 of 4419 Old 03-11-2009, 02:17 PM
HeadRush's Avatar
Here you go:
http://www.avsforum.com/avs-vb/showp...&postcount=109
HeadRush is offline
post #83 of 4419 Old 03-11-2009, 02:30 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
TC-P42X1/50X1 Reference Settings
Picture:
Picture Mode: Cinema
Contrast: 80
Brightness: 62
Color: 30
Tint: G8
Sharpness: 42
Color Temp: Warm
C.A.T.S: Off
Video NR: Off
Advance Options
MPEG NR: Off
Black Level: Light
Cnet has posted a review and settings for the S1 series. Here are the numbers.
--Picture menu
Picture mode: Cinema
Contrast: +55
Brightness: +63
Color: +32
Tint: 0
Sharpness: 0
Color temp: Warm
C.A.T.S.: Off
Video NR: Off
Zoom adjustments: [grayed out]
-Advanced picture submenu
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: Off
Black level: Light
HD Size: Size 2
H size: [grayed out]
These are similar to what D-Nice posted for the X1. Since the S series is a lot brighter than the X1, it makes sense that the contrast would be much lower on the S1.
StinDaWg is offline
post #84 of 4419 Old 03-11-2009, 02:33 PM
hoodlum's Avatar
CNET didn't make any adjustments in the service menu ,which would have an impact on the results.
hoodlum is offline
post #85 of 4419 Old 03-11-2009, 03:30 PM
D.Rowe's Avatar
Liked: 24
Awesome! I have patience. Thanks D-Nice.
D.Rowe is offline
post #86 of 4419 Old 03-11-2009, 04:29 PM
TopperMcFly's Avatar
Liked: 36
David always seems to contradict himself.
Starts with this:
Its picture quality is also very good, starting with deep black levels that nearly rival the all-time champ in that department, Pioneer's Kuro models.
Then ends up with this:
Compared with the displays we did have on hand, it couldn't compete with the Kuro
He even says motion resolution is better than the elite.
If his main issue seems to be with color, with service mode adjustments, this may change things quite a bit. If the color is dialed in, should this be on the same shelf as the Kuro?
Cryptic review at best but still leaves me thinking there is more potential here than has been disclosed thus far.
Gunga Gulunga..... Gunga Kunga Galunga..... On your deathbed you will receive total consciousness. So I got that goin' for me.
TopperMcFly is offline
post #87 of 4419 Old 03-11-2009, 04:32 PM
Zorfunk's Avatar
D-Nice - What slide show speed setting should I use for break-in? Thanks for all your hard work!
Zorfunk is offline
post #88 of 4419 Old 03-11-2009, 04:37 PM
MattSeven's Avatar
[color=red][size=2][b]Recommended 120 Hour Break-In settings for all 12G Panasonic models (ONLY to be used with Evangelo2's Break-in DVD
Is this supposed to be just a white screen? That's all I get with this iso.
nvm...I found the TS_Video folder version of the download and that worked fine.
MattSeven is offline
post #89 of 4419 Old 03-11-2009, 04:56 PM
xPUNGENTODORx's Avatar
Ok, I hate to do this and go back to page 1, but I'm trying to understand this break in time on the tv. I currently have 66hrs on my set and all of which were watched on the standard/vivid mode, with the last 5 hours or so on some custom settings I obtained from the owners thread.
In order to do a proper break in (please correct me if this is all messed up) I should do this... I need to buy/download one of the two recommended break in discs/software? Then turn on tv for the first time and run this program at the given settings for 120hrs? Then I'll be able to apply the final settings for optimal viewing?
Will I ever be able to use these final pic settings if I start with this break now or not because I've been watching tv for 66hrs already?
Please forgive my ignorance...
xPUNGENTODORx is offline
post #90 of 4419 Old 03-11-2009, 05:10 PM
chadmak09's Avatar
Starts with this:
wheres the contradiction?
chadmak09 is offline
