The Official Panasonic 12G Settings/Issues Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 4419 Old 03-14-2009, 06:16 PM
whiteboy714's Avatar
Originally Posted by D-Nice View Post
And please remember that my settings are never ment to be substitutes for a full blown calibrating. They will get you close to a full calibration, just not 100%.
And thats good enough for me, I can't see spending 250+ to calibrate on a set I paid $900 for.
That being said D-Nice thanks for your time and effort on this my picture looks great imo.
whiteboy714 is offline
post #182 of 4419 Old 03-14-2009, 07:49 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
I too have shared service menu offsets with other Panasonic owners. I have done this for the px75u and the px80u. I have changed the service menu values on friends' Panasonic TVs using the offset method and have verified by instrumentation that it works just fine.
I too have been told that 'each set is different' and sharing offsets does not work. However, those saying such have self serving purposes and/or have no experience in the manufacturing of electronic devices.
My retort to those who say that each set is different is: 'so how come all those inexpensive digital cameras are totally interchangeable?' Variations in electronic products coming off an assembly line are negligible.
Thanks, D-Nice.
Larry
LarryInRI is offline
post #183 of 4419 Old 03-14-2009, 08:54 PM
LeM22's Avatar
I have enjoyed my first HDTV a lot (TC-P50X1). I have many people, forums, and guides to thank. My experience has been relatively easy and fun. I have watched my tv, mostly HD and full screen, through the first 50 hours. I then spent the last week using Evangelo2's burn in cd to get me to 180 hours. I followed D-Nice's advice and wrote everything down (and took pics). The plasma really looks great now. The green push is mostly gone but I will have to wait until my wife looks at it to make sure. I hope some of this info will help you too!
Follow at your own risk:
My opinion is that if you just don’t touch the Volume buttons you will be fine. Also, if you are used to exploring technologies and computers, you’ll be fine.
To enter the service menu:
• Hold down the [- VOL ] button on the TV
• Press the [INFO] button 3 times on the remote.
• The Service Menu(s) will be displayed.
Here is how you will move around in the menus:
• Use [1] [2] on remote to move in main menu items.
• Use [3] [4] on remote to move in sub-menu items.
• Use [+VOL] [-VOL] on remote to change item value.
• Hold in the TV Power button to exit service mode and save.
For my TC-P50X1 only:
1. Small blue service menu to the left
Service
Adjust
WB-ADJ
Option
Aging
RM-Set
SRV-Tool
2. Large blue menu to the right
DTVSOC SOFT 1.07 RB Cnt 000
DTVSOC EEP 1.04.0592
LSI DATA 1.03.02
STBY SOFT 1.03.00
STBY EEP 01.00.0598
PDP Soft 02.00
PDP EEP 59.42
PDP FPGA 11.03
PDP PDROM 59.41
Attachment 136745
3. You will navigate #1, the Small blue service menu to the left.
4. Make sure your TV signal is 1080i/p or 720i/p. Both are shown as “HD” under the 1st column names (ex. R-Drv). I discontinued showing it because it’s monotonous.
Adjust menu
SUB-BRT 000 NEW FFF (-1)
Attachment 136744
WB-Adjust Menu (1st column name that is cycled, 2nd column original setting, third column new setting, and parentheses is the value change based on + and – volume on the remote per D-Nice’s settings.
R-Drv E2 E0(-2)
Before 80
Format HD
Method 03
Color Temp Warm
G-Drv DE C0(-30)
B-Drv 90 84(-12)
R-Cut 80 5F(-33)
G-Cut 80 65 (-27)
B-Cut 80 68 (-24)
Attachment 136743
5. After all changes are made, change your signal to 480i/p. I noticed that the Adjust Menu was already adjusted, but the WB-Adjust Menu had to be changed for SD (Standard Definition). For me, I just used the Satellite remote and for Dish, went into the HDTV setup and changed the signal. If you have Dish and this Panny remote, the Info button will allow you to see the full screen and get the service menu out of the way for 10 seconds at a time so that you can view the Satellite menus.
To check your Plasma's time used:
Follow the instructions to enter the service menu(s) {above}
Press the {2} button once
Then press the {OK} button to access it.
Using the cursor keys, highlight the empty box
on the right side of the last option: PTCT :00.00.00.00.00
Then press and hold the {MUTE} button for 3 seconds.
Time and Count will be displayed in red color.
To exit, press and hold the {POWER} button
on the Plasma for few seconds
Attachment 136742
LeM22 is offline
post #184 of 4419 Old 03-14-2009, 09:28 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
LeM22,
A few comments:
Your first line in #2 -- the 'Cut' is actually 'Cnt' for 'count'.
Your #4 item is irrelevant. It is necessary to make sure that the color temperature (remote button number 7) is set for 'warm'.
I don't have my X1 yet, but the factory sub-brightness value of 000 is a departure from the last three generations. They had the sub-brt set at about 800h.
Larry
post #185 of 4419 Old 03-14-2009, 09:56 PM
irishdawg's Avatar
Picture:
Picture Mode: Vivid
Contrast: 100
Brightness: 55
Color: 65
Tint: 0
Sharpness: 50
Color Temp: Cool
C.A.T.S: Off
Video NR: Off
Advance Options
MPEG NR: Off
Black Level: Light
When I go in to change the Advance setting the Black level setting is grayed and will not allow me to adjust it. Anyone know how I can change this so I can start D's break in process? Right now it is set on dark.
irishdawg is offline
post #186 of 4419 Old 03-14-2009, 10:06 PM
joebarrett23's Avatar
Originally Posted by irishdawg View Post
Picture:
Picture Mode: Vivid
Contrast: 100
Brightness: 55
Color: 65
Tint: 0
Sharpness: 50
Color Temp: Cool
C.A.T.S: Off
Video NR: Off
Advance Options
MPEG NR: Off
Black Level: Light
It's only selectable when viewing my BD player. Unfortunately I'm using an SD card so I'm stuck without changing that setting.
joebarrett23 is offline
post #187 of 4419 Old 03-14-2009, 10:38 PM
irishdawg's Avatar
Will the outcome be the same?
Also, I do not have hd at this time. Is it still a good idea to do the break in and cal. without hd?
post #188 of 4419 Old 03-15-2009, 04:48 AM
LeM22's Avatar
Originally Posted by LarryInRI View Post
LeM22,
A few comments:
Larry
Larry,
Thanks for the edit.
Question...so the mode that shows can be any, just as long as it is in the "warm" setting? I was following D-Nice's settings, and when I entered the service menu, the tv adjusted to Vivid. I had to use the 9key (on the remote) to change the mode to Cinema as he showed in his calibration settings.
LeM22 is offline
post #189 of 4419 Old 03-15-2009, 08:40 AM
Ok I have a question. I used the service menu offsets. Then adjusted my picture settings to D-nices settings for custom mode.
I read his first post about cinema mode, then when he posted custom mode settings he said the offsets needed to be used for them as well.
So I use the same off sets is my understanding. The thing is I didn't change the mode out of vivid in the service menu. Does this mean I only affected vivid mode? Or will they apply to all modes?
post #190 of 4419 Old 03-15-2009, 09:50 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 526 Post(s)
Liked: 781
It would be helpful if you say what source you're using.
This Light/Dark setting is only available when using external sources like a DVD Player or Cable Box or Satellite Receiver etc. It's not accessible if you're using the TV's internal tuner - it will be grayed out. Were you using the tuner? If not, what is your source and how is it connected to the TV?
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo 2-Tuner Premiere, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #191 of 4419 Old 03-15-2009, 09:53 AM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
The RGB controls are global so entering the offsets while it is in Vivid mode is fine.
It would matter what picture mode is was in if you were actually calibrating the set with calibration equipment.
D-Nice is offline
post #192 of 4419 Old 03-15-2009, 10:56 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Crap, I'm good with computers but I've never done this and I don't particularly want a $1000 test trial.
StinDaWg is offline
post #193 of 4419 Old 03-15-2009, 11:04 AM
hoodlum's Avatar
Go for it... You only live once.
hoodlum is offline
post #194 of 4419 Old 03-15-2009, 11:19 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Has anyone used D-Nice offsets, and noticed a big difference between just using his standard settings and then settings with the offsets? Like, is it a night and day difference with the offsets applied?
StinDaWg is offline
post #195 of 4419 Old 03-15-2009, 02:03 PM
No its not night and day bit I'd say its worth it, like stated before do not touch the volume controls until you want to change something.
And write down EVERYTHING that you change or take a pic with a digital cam.
Awesome thanks so much for your help dude thats the answer I was hoping for!!!
post #196 of 4419 Old 03-15-2009, 02:40 PM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
I don't understand how you can really damage the set though. If you can go back and change settings then what is the big worry about? It's not like the tv is going to explode if you hit the wrong button?
StinDaWg is offline
post #197 of 4419 Old 03-15-2009, 03:06 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
Then why do the Panasonic service manuals state maximum values for DRV settings?
Larry
post #198 of 4419 Old 03-15-2009, 10:53 PM
sanne's Avatar
DNice any idea on when you're gonna get your hands on an S1?
sanne is offline
post #199 of 4419 Old 03-16-2009, 01:11 AM
Stoykata's Avatar
Originally Posted by GEE 04 View Post
Larry is there anyway you can share your sm offsets or point me in the right direction? I have the 42px80u. Thanks in advance.
+1 on that, Larry. Would be really much appreciated.
Stoykata is offline
post #200 of 4419 Old 03-16-2009, 05:49 AM
hoodlum's Avatar
He felt that SM changes were not required with the PX80.
http://www.avsforum.com/avs-vb/showt...php?p=13569687
hoodlum is offline
post #201 of 4419 Old 03-16-2009, 01:49 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 190
This is not the thread to discuss the px80u. It is way off topic.
I have not released my px80u offsets to any public forum but I have sent them to those that have requested. I don't recall saying that service menu changes were not required. However, it is true that the changes needed to the px80u white balance warm mode via the service menu are quite minimal and the result is only apparent to those who are discerning enough to appreciate them.
Larry
post #202 of 4419 Old 03-16-2009, 01:57 PM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
Not yet, but I'm suppose to have a G10 on hand by the end of next week.
D-Nice is offline
post #203 of 4419 Old 03-16-2009, 02:04 PM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
Oh, and new X1 series SM offsets should be posted tonight. I figured out to improve the grayscale.... specifically 10% and 80% stimuli.
D-Nice is offline
post #204 of 4419 Old 03-16-2009, 02:09 PM
sanne's Avatar
I'm noticing a very strong green tint on my S1, didn't notice this on my previous 42P700U. Did you notice this on the X1 series pre-calibration?
sanne is offline
post #205 of 4419 Old 03-16-2009, 02:19 PM - Thread Starter
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1490
Yes.
D-Nice is offline
post #206 of 4419 Old 03-16-2009, 02:59 PM
D.Rowe's Avatar
Liked: 24
D-Nice...excused my ignorance here but is it safe to say that improving greyscale will = improve PQ overall? Just trying to better understand what this means.
Dave
D.Rowe is offline
post #207 of 4419 Old 03-16-2009, 03:11 PM
sanne's Avatar
I just want to say D-Nice this is a wonderful thing you're doing for the community. I've learned a lot about calibration I didn't even know before.
I'm curious as to how this whole break-in method came about....was it something discovered via trial and error? And when did you realize that you could calibrate a wide range of individual plasma units via this offsetting method and still maintain relatively good results?
sanne is offline
post #208 of 4419 Old 03-16-2009, 03:57 PM
jchauncey's Avatar
I am having this same problem. Can you only do this using a non ANT source (meaning only through a source plugged in through HDMI or component?)
jchauncey is offline
post #209 of 4419 Old 03-16-2009, 04:13 PM
Yes someone said before if its on antenna its not available. I have 2 things hooked up via hdmi and one via rca jacks and its available on all.
post #210 of 4419 Old 03-16-2009, 04:50 PM
chrisherbert's Avatar
Quoted: 17 Post(s)
Black level controls the point at which black should be, which can differ depending on whether the source uses video or PC levels. 95% of the time you'll want to use "light."
"Light" would be hardcoded into the antenna input since all OTA and QAM sources would use video levels.
chrisherbert is offline
