151 Speaker question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-17-2009, 05:19 PM - Thread Starter
ByteTV01's Avatar
I just picked up the 151, great picture btw. I hooked up the speakers that come with it, but I'm not getting any sound out of them. I have a hdmi cable going from the cable box to hdmi port 4 on the tv. Speaker wires are hooked up right.
Even tried hooking up those red/white audio cables from the cable box to the tv, still no sound.
When i hit that Tv/Dtv button on the remote the pictures goes static but then i do hear static sound on the speakers.
Is there some setting in setup to get the audio through hdmi input #4?
ByteTV01 is offline
post #2 of 8 Old 04-17-2009, 05:22 PM
Juan's Avatar
Make sure the 151 is not set for AV Sound, in the menu there is a section to switch to AV Sound.
Juan
My HT
Juan is offline
post #3 of 8 Old 04-17-2009, 06:34 PM - Thread Starter
ByteTV01's Avatar
I cant find that setting. How do you get to that setting after hitting the home button on the remote?
ByteTV01 is offline
post #4 of 8 Old 04-17-2009, 07:29 PM - Thread Starter
ByteTV01's Avatar
When I hook up the Xbox 360 to the component inputs, I do hear sound, so I know the speakers are working but they just arent working when watching regular TV, something with the hdmi cable or cable box or something?
ByteTV01 is offline
post #5 of 8 Old 04-17-2009, 07:37 PM - Thread Starter
ByteTV01's Avatar
Update: Used the component cables + red/white audio cable from the cable box to the tv and I do get sound. Therefore it looks like its the hdmi cable, but its band new just bought it, i'll try a different hdmi cable from the cable box to the tv.
ByteTV01 is offline
post #6 of 8 Old 04-17-2009, 07:59 PM - Thread Starter
ByteTV01's Avatar
Solved: The sound only works on the TV speakers when the HDMI is going from the cable box to HDMI Input #1, the one on the side of the tv (not 4,5 or 6). Xbox hdmi works on all of the hdmi inputs, strange.
Well all is well.
ByteTV01 is offline
post #7 of 8 Old 04-17-2009, 09:01 PM
Bushman4's Avatar
Well all is well.
SOMETHINGS NOT RIGHT!~!!~ I Have my cable box hooked up to HDMI #4 and the sound works great. You have something set wrong. The sound should work on all the HDMI inputs!!!
Bushman4 is offline
post #8 of 8 Old 04-18-2009, 12:16 AM - Thread Starter
ByteTV01's Avatar
The sound still doesn't work on HDMI 4,5 or 6. And now the picture isn't coming on on HDMI 1 but the picture does work on 4,5,6, of course still no sound on 4,5 or 6. What should I try?
ByteTV01 is offline
