Samsung PN**B450 Picture Settings - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 02-28-2010, 08:33 AM
dallows's Avatar
Quoted: 14 Post(s)
Originally Posted by jangaboo View Post
yep its better, it also helped lowering sharpness to around 10 on my ps3 and no problemo
I'm not sure if i'll keep it yet...the TV does have great looking colors, motion is much better than LCD but I find LCD better in the way it draws or displays objects on the screen especially for games and web pages
and here's 3x zoomed macro shot closeup of TV PN42B450 - not sure i want to say pixels cuz i don't know how Plasmas work
I don't understand the purpose of this image.
dallows is online now
Old 02-28-2010, 10:21 AM
jangaboo's Avatar
on LCDs the pixel structure differs on each set, S-IPS has pixels that look like arrows pointing west, e-ips verticals and some VA panels circles with horizontal lines
some of the patterns look quite nice like art lol
there wasn't really a point other than to show a macro shot closeup of a plasma, maybe learn more about how it displays images
jangaboo is offline
Old 02-28-2010, 11:15 AM
jangaboo's Avatar
Originally Posted by bobbyy9 View Post
What do you mean by objects? because i find games look much better on the plasma than lcd...however like i said when recommending the tv if your using it as a computer monitor a 720p plasma is not a good idea...definately need 1080p for use as a computer monitor..unless your using it strictly to stream video or play games but sitting up close ad surfing the web wont looks good..not to mention overscan on hdmi or stretch on vga
borders of text, grass outlines, 3D objects like the outlines of the zebras,
i think it is the lower resolution and the scaling causing this as its not as defined/detailed looking vs a screen that supports the real resolution
but true 1080p plasmas are much more expensive
otherwise the screen looks amazing
Samsung PN42B450
LG xxLH30
Samsung PN42B450
LG xxLH30
jangaboo is offline
Old 02-28-2010, 11:42 AM
shibez's Avatar
Quoted: 22 Post(s)
Samsung PN42B450
LG xxLH30
Samsung PN42B450
LG xxLH30
i dont know if its just me but i think the sammy pics look better and "more detailed" definitely more sharper
Proud Owner of 55EG9100
shibez is offline
Old 02-28-2010, 05:41 PM
bobbyy9's Avatar
me to haha i prefer the sammy...jangaboo if you don't like it..just take it back haha
bobbyy9 is offline
Old 02-28-2010, 06:10 PM
bobbyy9's Avatar
Jangaboo..i asked before but you probably missed it, what setting are you using? just the presets or?
bobbyy9 is offline
Old 02-28-2010, 06:11 PM
bobbyy9's Avatar
damn has anyone seen the c450? very nice looking....i mean the tv itself...they really improved the styling.
bobbyy9 is offline
Old 02-28-2010, 07:21 PM
shibez's Avatar
Quoted: 22 Post(s)
yup i saw it...i was wondering what the difference was between the d450 and the new C(other than the obvious new design) I think it has less connections but it has gained a ethernet port?(i doubt its for internet content..)
btw it is definitely an improvement on style..i think the "ToC" is more prevalent.
shibez is offline
Old 02-28-2010, 07:28 PM
jangaboo's Avatar
i've tried a bit of everything, turning dynamic contrast off to setting it to medium
right now for PS3 its on Standard, 10 cell, 80 contrast, 50 brightness, 13 sharpness, 67 color
jangaboo is offline
Old 02-28-2010, 08:16 PM
bobbyy9's Avatar
O M G ........colour is at 67 hahaha
could be part of your problem lol...when colour is set to high it can really wash out detail as well...much like contrast and other setting can affect detail...with a setting that high...and i'm assuming you have dynamic contrast on as well you wont see a single detail in colours..for instance i just tryed that setting and a guy wearing a football jersey made of mesh turned into one solid red jersey...uncharted at the title page lost all detail
bobbyy9 is offline
Old 02-28-2010, 09:25 PM
shibez's Avatar
Quoted: 22 Post(s)
Try my settings ...
Mode- standard
Cell light - 6
Contrast - 90
Brightness - 52
Sharpness - 90
Color -45(i jacked my color up a bit from dans..)
Tint- g42/r58
Advanced - everything off or zero except edge enhancement on and colorspace - native
White balance -
R-offset - 21
G-offset - 25
B-offset - 15
R-gain - 25
G-grain - 0
B-gain - 27
and i have energy saver on low
I have pretty much taken a mixture from everyone on here
ALSO for gaming...you do know this tv has a Game mode right? I dont game so i havent had a chance to test it...
shibez is offline
Old 02-28-2010, 10:12 PM
jangaboo's Avatar
its not the color i have problems with, i like jacking up saturation on sets i use
i understand raising it too high will destroy some detail
the problem i have is the resolution scaling causing a blotchy look of objects on the screen, the outlines of objects like i mentioned have a blocky look to them instead of being defined
the pics i posted don't do justice if you were to see it in person the zebras outlines because of the scaling look blocky instead of having a smoothness to them
i will try your settings tomorrow shibez, thanks
jangaboo is offline
Old 03-01-2010, 12:50 AM
bobbyy9's Avatar
Jangaboo i would not recommend shibez's settings for gaming...you dont want reference settings for gaming it just doesnt work...ive found the best thing to do for games...is to switch to game mode...then adjust cell to 10 contrast to 80-85 ....brightness to 50 and just leave the rest alone....this works the best for games
just incase you havent found the game mode yet you hit menu..scroll down to plug and play and you find it in that menu
bobbyy9 is offline
Old 03-01-2010, 01:09 AM
bobbyy9's Avatar
While on the setting topic here are my updated settings as i to started to find movie had too much of a weird tinge to it..the white balance change corrects it..i use these settings strictly for blu-ray/dvd on my ps3, looks excellent with the lights down. i find them too dim for hd cable..mostly due to varying quality on different channels..i finally settled on setting for my hd cable viewing that look good on all channels/sources after about a month of adjusting all the time..if you guys want those settings let me know and i can post them
--Picture menu
Mode: Movie
Cell Light: 10
Contrast: 99
Brightness:48 (checked with my DVE Blu-ray 49 was to high 48 is perfect)
Sharpness: 20 (i cant tell a difference when changing this...so left it at default)
Color: 48
Tint: G50/R50
Advanced settings submenu
Black tone: Off
Dynamic contrast: Off
Gamma: 0
Color space: Auto
Flesh tone: 0
Edge enhancement: Off
White balance submenu
R-Offset: 25
G-Offset: 25
B-Offset: 25
R-Gain: 25
G-Gain: 15 (down from 21 can)
B-Gain: 21
try them and let me know what you think
bobbyy9 is offline
Old 03-01-2010, 08:32 AM
dallows's Avatar
Quoted: 14 Post(s)
I'm sure you could calibrate game mode for it to display properly, but I don't see the point. I've never noticed any issues with running my games in standard. Everything looks sharp, clear, and fantastic.
Old 03-01-2010, 02:52 PM
bobbyy9's Avatar
Ya, when i put the same setting on game mode and standard i ohnestly cant tell a difference..i mean game mode uses the standard setting...just thought maybe it might be cutting down on input lag even if its so slight i cant tell..need every advantage i can get for shooters online haha...but its really not n issue since this tv has no perceivable input lag like lcd's due..purely a mental thing
bobbyy9 is offline
Old 03-01-2010, 10:17 PM
dallows's Avatar
Quoted: 14 Post(s)
Camera made this shot a little fleshy, if you know what I mean. He's supposed to be more pale. I'll be trying again. These were just quick shots.
Old 03-01-2010, 11:16 PM
shibez's Avatar
Quoted: 22 Post(s)
those pics look great
shibez is offline
Old 03-01-2010, 11:38 PM
bobbyy9's Avatar
I just tryed this demo>>>WOW its pretty cool...looks really good on the tv as well..havent actually had time to try a game for more than about ten seconds since i got it thanks to exams until now...im impressed...dallows do you have the full game?
bobbyy9 is offline
Old 03-01-2010, 11:40 PM
bobbyy9's Avatar
and i just thought i'd mention....jangaboo...it totally slipped my mind while we were talking about it..you do know most all ps3 games are only 720p?
bobbyy9 is offline
Old 03-01-2010, 11:42 PM
bobbyy9's Avatar
Dallows do you use different setting for games? or just the same ones you already posted?
bobbyy9 is offline
Old 03-02-2010, 12:19 AM
shibez's Avatar
Quoted: 22 Post(s)
i found this site that had calibration settings for a similar model(pn50b550)
I plugged in the settings in my tv and I think i am in love O.O
reviews.plasmatv buyingguide.com/plasmatvreviews/samsung-pn50b550-review.html
I believe the only difference of the models is 1080p...
White Balance Settings
Red-Offset 22 Red-Gain 33
Green-Offset 25 Green-Gain 25
Blue-Offset 12 Blue-Gain 33
Picture Settings
Picture Mode - Movie Black Tone: Off
Color Temp- Warm 2 Dynamic Contrast: Off
Brightness- 56 Gamma: 0
Contrast - 90 Color Space: Auto
Color -53 Flesh Tone: Off
Tint - G35/R65 Edge Enhancement: Off
Sharpness -10 Digital NR: Auto
Cell Light -8 HDMI Black Level: Low
Film Mode: Auto
shibez is offline
Old 03-02-2010, 08:07 AM
dallows's Avatar
Quoted: 14 Post(s)
It's the full game. Great so far, very different from normal games.
Same settings. I'll try for some better shots tonight if I have time.
Old 03-02-2010, 01:37 PM
bobbyy9's Avatar
nice..ive been waiting for someone i know to buy it..is it a a buy or a rent?
bobbyy9 is offline
Old 03-02-2010, 01:38 PM
dallows's Avatar
Quoted: 14 Post(s)
I bought it. I don't like to rent. Not sure why. If you have a problem with Quicktime Events I might avoid it. Or rent/borrow it to try it out.
I'm find the gameplay and story to be pretty good though. Some of the stuff is intense.
Old 03-02-2010, 02:05 PM
mike091's Avatar
beat the game.... only game ive played that had me questioning which decision i was going to make....4 different endings, and their are trophies, that you cannot get depending on which decision you make, so definitely buy it. it has replay value. Downloadable content also coming, its a prequel
***** 5 star game
i also have this tv. a 50inch purchased in feb of 09
out the box looked great on ps3 and 360. changed to cinema movde, and turned down sharpness, and energy saver off. nothing else to tweak.
some burn ins in the lower right part of the screen, bery subtle. if i leave the tv offf while i sleep, i dont see them the next morning
was questioning if this tv was worth the 850 i spent for it, was going to take it back. after playing heavy rain, its worth keeping.
mike091 is offline
Old 03-02-2010, 08:35 PM
bobbyy9's Avatar
cool..i'll buy it this week then...soo many good games are coming out...im going to be broke after buying this tv then heavy rain,gow3,bioshock2,ff13 lol
bobbyy9 is offline
Old 03-02-2010, 08:39 PM
bobbyy9's Avatar
Picture Settings
Film Mode: Auto
Shibez i changed the cell light to 10 and brightness to 55 and i must say...amazing find...with the changes these are bar far the best settings in this thread...im watching lost in hd right now and its the first time ive been able to sit through the show without playing with the settings....colours are extremely accurate..just amazing...THANK YOU SO MUCH!!!!
bobbyy9 is offline
Old 03-02-2010, 08:48 PM
bobbyy9's Avatar
Shibez...seriously i am in love ..still cant believe how good this looks!!
bobbyy9 is offline
Old 03-02-2010, 10:50 PM
shibez's Avatar
Quoted: 22 Post(s)
you're very welcome i changed the cell to 10 just now too and i think its even better..I didnt think i could actually like the movie mode/warm 2 but i definitely do now. looks amazing
shibez is offline
Samsung
